Quantcast XJ won't start. Can't figure out why? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > XJ won't start. Can't figure out why?
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 08-22-2009, 01:01 PM   #1
NH44XJ
1995 XJ Cherokee
The other night my 95 Cherokee would not start. All the lights came on but when I turned the ignition nothing happened. After playing with the Shifter I managed to start the Jeep. This happened one other time and then it would just flat out not start. I've replaced the neutral safety switch (tried cleaning the old one too) but I still can't get anything. I was told the starter is only about 6 months old but there's no way I can prove that. I haven't even heard the solenoid click though. I thought this was going to be another neutral safety story but apparently not. Any Ideas?
NH44XJ is offline   Reply With Quote
Old 08-22-2009, 01:11 PM   #2
Carl48
See if you get voltage to the small terminal on the starter solenoid when the key is in the "start" position. If no voltage, the problem is in the start circuit before the starter. If you see voltage, the solenoid/starter is no good. You will need to extend the leads on your voltmeter or get assistance to run this check safely.
Carl48 is offline   Reply With Quote
Old 08-22-2009, 01:17 PM   #3
cornbrizzle
1992 XJ Cherokee
Have you checked to make sure the NSS has not moved and is out of ajdustment? check to see if the adjustment bolt has backed out a little and the NSS has moved? Also could be starter relay wire or Ignition switch on steering column under dash ?
Brizzle
“Don’t Tread On Me”
www.highsprings.com
cornbrizzle is offline   Reply With Quote
Old 08-22-2009, 01:17 PM   #4
99Greenmachine
It sounds like NSS definitely, could also be a CPS issue perhaps
'99 XJ Sport MY BUILD
Thank You Hooligan!!!
XJ/TJ Heaterbox Seals for sale!!! NIB! Official Mopar made in USA!
99Greenmachine is offline   Reply With Quote
Old 08-22-2009, 01:24 PM   #5
natertots
1990 XJ Cherokee
Could be ignition switch. Mines bad, I have to turn the key very hard. or use a screwdriver after I unlock the cylinder. I dont know why, but it works.
Originally Posted by ancestralworm View Post
i wave at dog walkers and pink vw bugs and michelle pfeiffer look-a-likes and folks dressed like harry potter and two person bikes and pissed off squirrels and butterflys and day lilies and jump ropers and hobos with shotguns but there is no way in hell i will wave at a liberty. that's just gay.
natertots is offline   Reply With Quote
Old 08-22-2009, 01:49 PM   #6
NH44XJ
1995 XJ Cherokee
I've tried starting it with the NSS in several different adjustments and still nothing. My reverse lights work too so I guess the NSS is working fine. How could it be a CPS if the Jeep won't even crank?
Old 08-22-2009, 05:33 PM   #7
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
My ignition switch went out a few years ago and did the same thing. Sometimes it would start and other times it would do nothing. The CPS isn't the problem, it wont keep the engine from turning over.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 08-22-2009, 06:05 PM   #8
kyle90xj
1990 XJ Cherokee
i have the same prob; if i just push foward on the shifter it will start, but most of the time it starts right up. I thought maybe the switch in twas worn down so i needed to replace it, but idk.
kyle90xj is offline   Reply With Quote
Old 08-22-2009, 06:14 PM   #9
jreed80
Junior Member
Sounds like the N S S it is verycommon in chrysler products.
jreed80 is offline   Reply With Quote
Old 08-23-2009, 05:23 PM   #10
kyle90xj
1990 XJ Cherokee
what does nss stand for
Old 08-23-2009, 05:25 PM   #11
cornbrizzle
1992 XJ Cherokee
Neutral Safty Switch
Brizzle
“Don’t Tread On Me”
www.highsprings.com
Old 08-23-2009, 05:38 PM   #12
_litz
1997 XJ Cherokee
Which, in non-car-tech-ese, means "the switch that makes it so you can only start the car in PARK or NEUTRAL" ...
(I think that's actually part of the "standard" set of federally required safety equipment ...)
- _litz
1997 Jeep Cherokee Sport
1976 Fairmont MT-19
_litz is offline   Reply With Quote
Old 08-23-2009, 08:55 PM   #13
MaskedMallard
Have you checked your Battery Powers & Grounds?
My Negative Cable corroded out on me, & I'd be able to get lights & what not, but no started action until I hooked my jumber cables to the battery & the other end to the Engine Block.
MaskedMallard is offline   Reply With Quote
Glock Forum
