XJ Wont Idle - JeepForum.com
post #1 of 8 Old 07-17-2012, 11:27 AM Thread Starter
Walkeraviator
XJ Wont Idle
My 98 is having an idle problem. First when I start it I have to pump the throttle like a carb to get it to run. Then I have to keep my foot on it to keep it at 1000 rpm. If i take my foot off, it dies. If I drive it around for a while i will eventually start idling when i come to a stop. Then it will work fine for a few weeks. Then one day I get up and she is doing it all over again. Though the first time it did it I had bought bad fuel. But now that it is doing it repeatedly I know there is something wrong.
Does this thing have a MAF sensor or a MAP or something else that could need a good cleaning???
Walkeraviator is offline
post #2 of 8 Old 07-17-2012, 11:31 AM
BUSA
[QUOTE="Walkeraviator"]My 98 is having an idle problem. First when I start it I have to pump the throttle like a carb to get it to run. Then I have to keep my foot on it to keep it at 1000 rpm. If i take my foot off, it dies. If I drive it around for a while i will eventually start idling when i come to a stop. Then it will work fine for a few weeks. Then one day I get up and she is doing it all over again. Though the first time it did it I had bought bad fuel. But now that it is doing it repeatedly I know there is something wrong.
BUSA is offline
post #3 of 8 Old 07-17-2012, 12:49 PM
glatt513
glatt513's Avatar
1994 XJ Cherokee
Replace your idle air control valve (IAC), it is simple, easy & will solve your problem. Get one at NAPA, the discount stores sell junkers that won't last more than a year.
glatt513 is offline
post #4 of 8 Old 07-17-2012, 12:54 PM
BillB7581
Check your battery and connections... if the pcm doesnt see a full 12 volts all kinds of wacky things can happen.
BillB7581 is offline
post #5 of 8 Old 07-17-2012, 05:46 PM
thenewguy79
Thanks for the advice. My 99 xj is doing the same. Wish it didnt cost so much for the part though, wow
thenewguy79 is offline
post #6 of 8 Old 07-17-2012, 06:36 PM
Finallyajeep
X2 on the battery and connections, I had a dying battery and had the same symptoms as you.
Firefighters Jeep Club
Finallyajeep is offline
post #7 of 8 Old 07-17-2012, 06:42 PM
cascadesdreamin
Same. I had a busted cell in my battery after wheeling and it was doing this. Parts store tested it for me to confirm it. I think I'll come up with some kind of foamy soft platform for my battery.
cascadesdreamin is offline
post #8 of 8 Old 07-17-2012, 07:34 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by Walkeraviator View Post
....when I start it I have to pump the throttle like a carb to get it to run. Then I have to keep my foot on it to keep it at 1000 rpm. If i take my foot off, it dies. If I drive it around for a while i will eventually start idling when i come to a stop.
You have a low voltage issue.
For 1996+ Jeeps, the OBD-II engine computer (ECU/PCM) re-boots, and the idle settings are deleted, when you: (1) let the battery run down by leaving the lights or radio on, (2) disconnect the battery for an extended period of time, (3) when the battery goes bad and needs replacing, (4) when the alternator is not properly charging the battery, (5) or when poor battery connections result in a voltage drop at the PCM or poor battery charging.
Low voltage symptoms are as follows: (1) having difficulties starting the engine without depressing the gas pedal, and (2) the engine will have a low idle and probably stall unless you keep your foot on the gas pedal. (3) The ECU will relearn the idle settings after a short period of driving and the engine will start and idle normally.
Loose, corroded, or damaged battery cables or ground wires may also cause or contribute to the problem. Begin with basic trouble shooting of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables and replace them as needed. Do the same for the grounding wires from the battery and engine to the Cherokee's frame/body.
If the symptoms reoccur, you need to have your battery and/or the alternator load tested at a repair shop or auto parts store. This is usually a free service they offer to bring in potential customers. Even with low battery voltage, the engine will start, but the ECU can re-boot multiple times and a new battery may be required.
Cleaning the Idle Air Controller (IAC), regular tune-ups, and using fuel injector cleaner should be part of your routine preventative maintenance.
CJ7-Tim is offline
bad battery , hard start , no idle , pump gas pedal , stalling
Still wont idle XJmallcruiser XJ Cherokee Technical Forum 8 09-14-2011 12:27 PM
wont idle right WCBROOKS XJ Cherokee Technical Forum 8 11-26-2008 12:20 PM
Wont idle mbaucom XJ Cherokee Technical Forum 2 07-02-2007 06:53 PM
Wont Idle.....help Me AzzKiker XJ Cherokee Technical Forum 10 08-18-2006 02:22 PM
2.8 wont idle GDSQDCR MJ Comanche Technical Forum 1 05-21-2005 10:35 PM
