XJ V8 swap - JeepForum.com
post #1 of 13 Old 04-27-2011, 03:52 PM Thread Starter
PlatinumNiner
XJ V8 swap
Anyone done a fuel injected 5.2 or 5.9 swap? Looking to do this on my 95 XJ maybe use a zj, durango or dakota as a doner. Whatever i come across for the right price. Will the 5.2-5.9 bolt up to the AW4? My tranny and t-case are both new and id like to keep them. Any info would be awesome. Thanks guys
PlatinumNiner is offline
post #2 of 13 Old 04-27-2011, 04:00 PM
lowicz96
1995 XJ Cherokee
Sort answer NO, try searching. theres alot to a v8 swap
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #3 of 13 Old 04-27-2011, 04:28 PM Thread Starter
PlatinumNiner
I have found many v8 swaps on the TJ and some on the XJ but everyone drops in chevy motors when it comes to the XJ. I wana keep it Mopar.
post #4 of 13 Old 04-27-2011, 04:55 PM
CostcoPizza
Fresh Baked
CostcoPizza's Avatar
There's a guy on Mallcrawlin in the process of it...
CostcoPizza is offline
post #5 of 13 Old 04-27-2011, 05:05 PM Thread Starter
PlatinumNiner
Not a fan of that site honestly. Im a member visited 3-4 times didnt bother going back.
post #6 of 13 Old 04-27-2011, 07:57 PM
CostcoPizza
Fresh Baked
Me either, that's why I didn't bother linking you
Ran across it on another forum...
post #7 of 13 Old 04-27-2011, 08:41 PM Thread Starter
PlatinumNiner
You really like frozen pizza huh ol
post #8 of 13 Old 04-28-2011, 04:11 PM
KF4SQB
1994 XJ Cherokee
People drop GM engines into everything because of simplicity. My brother is almost done putting a 350 in his '90 YJ. Don't remember what year the 350 is, but its TBI. After he "trimmed the fat", and got everything dressed up properly, he had the grand total of five wires to tie into the YJ's electrical system. There's nothing out there any simpler. Also, the GM TBI system is nearly bulletproof, and extremely reliable. Parts are cheap and easy to find, too. I'm sure you can mechanically install the Mopar powerplant, but there will be a lot more to making it run than with a GM engine.
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
post #9 of 13 Old 04-28-2011, 04:43 PM Thread Starter
PlatinumNiner
Yea im not interested in doing that. I dont believe in it. If and when i do it, it's getting a magnum 5.2 or 5.9 and will stay injected.
post #10 of 13 Old 04-28-2011, 06:28 PM
KF4SQB
1994 XJ Cherokee
Don't misunderstand me, I'm not trying to talk you into GM instead of Mopar, just explaining why everyone does GM. If you want Mopar, by all means, go for it. Its just harder to do the electrical, and its not nearly as easy to find parts for the install. Personally, I think a 318 in a Cherokee would be awesome, but its not something I would want to do myself. Best of luck with the swap!
KF4SQB is offline
post #11 of 13 Old 04-28-2011, 10:20 PM
fasterthanlight
1994 XJ Cherokee
I'm curious myself on this one because i have a 94 XJ and I just got an older 318 with a carb and my 4.0 is toast due to an injector going out I am wanting to know if there is any kind of a kit that will help my bolt the auto trans to the back of the motor since i wont have the tbi it should b simpler or am i just getting into alot of trouble that wont b worth the payoff in the end.
fasterthanlight is offline
post #12 of 13 Old 04-29-2011, 12:15 AM
GregB_00XJ
I think the biggest issue would be the wiring. IIRC Painless makes some kits for the later model Mopar engines, you might be able to buy a harness that you can adapt into yours.
Trans etc, likely will not bolt right up, adapters, motor mounts etc...lots of work. Would be pretty kool however! Extreme 4x4 did a Hemi swap into a Wrangler last season... sweet rig.
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #13 of 13 Old 04-29-2011, 01:31 AM
Timo_90xj
Timo_90xj's Avatar
I say it's doable, but you propably need to do front uniframe notching & plating, some sort of custom wiring harness, engine & tranny mounts etc.. a lot of work. And do NOT forget cooling system updates if going v8- route.
You cannot use the aw4, and especially behind the 360 it's not a good option strength- wise. Go stock route and keep what's behind the donor engine.
***Under construction***
Timo_90xj is offline
np207 swap info needed for 2.8 v6 np231 dirrect swap? robdoggydog1 XJ Cherokee Technical Forum 6 01-26-2014 09:42 PM
8.8 swap needs 96fleXJ XJ Cherokee Technical Forum 3 05-14-2010 12:50 PM
Tranny swap ?s: AW4 to AX15 swap (or any other trannies for that matter)... Bryson XJ Cherokee Technical Forum 8 06-22-2009 02:01 AM
98 ZJ 4.0 swap into a '96 XJ. .....direct swap? possible probs? 4.0H.O.XJ XJ Cherokee Technical Forum 6 09-12-2008 07:57 AM
Cluster swap for '98 XJ... direct swap? TheDon427 XJ Cherokee Technical Forum 4 09-10-2007 07:49 PM
