XJ Tune-up Guide - JeepForum.com
post #1 of 11 Old 04-25-2012, 02:43 PM Thread Starter
spectre853
XJ Tune-up Guide
In an attempt to distill all of the information available on the recommend items required to perform a tune-up on an XJ, here is everything I have gathered through my own research and some fairly extensive forum mining. Please feel free to add any recommendations and/or personal experiences to make this list as exhaustive as possible.
All items are for a 1996 XJ Cherokee Classic, though they should work for older model XJs, and may work for newer model XJs unless otherwise noted.
Spark plugs:
Champion Copper P/N RC12LYC
US$1.99 per (AutoZone)
Notes:
The AMC-designed I6, as well as it's Chrysler improved variants, seems to run best on these basic factory-installed plugs. On top of which, they are significantly cheaper than other "Platinum Grade" plugs on the market. Often held in stock at most auto parts stores.
Wireset:
Bosch P/N 098284
US$29.99 (AutoZone)
Notes:
While not all wiresets are created equally, they all serve the same purpose, and that is to deliver a charge from the distributor to the spark plugs. With this in mind, a Bosch wireset is recommended not because of any particular experience or function, but rather because they are a fairly basic, middle-of-the-road wireset, and are widely available. Essentially any wireset will do, but it is generally recommended that one not spend too much (for fear of wasting money on insignificant features) or too little (for fear of sacrificing quality for savings) on these essential electrical components. Often held in stock at most auto parts stores.
Distributor Cap:
Accel P/N 120330
US$16.99 (Pep Boys)
Notes:
This distributor cap features brass contacts, as opposed to the copper contacts of the Duralast cap. Additionally, in the case of AutoZone anyway, the Accel cap is actually US$1 less expensive. However, this product may need to be special ordered, depending of availability.
Ignition rotor:
Accel P/N 130330
US$10.99 (Pep Boys)
Notes:
This product was chosen simply due to the fact that it is from the same manufacturer as the chosen distributor cap. This product may need to be special ordered, depending on availability.
Oxygen sensors:
Upstream (before catylitic converter):
NGK P/N 23121
US$58.19 (NAPA Auto Parts)
Downstream (after catylitic converter):
NGK P/N 23014
US$60.76 (NAPA Auto Parts)
Notes:
While Bosch manufactures many fine products, to include oxygen sensors, theirs do not fare well in Jeep vehicles. This is due to a higher required voltage draw in the heating circuit as compared to the factory-installed NGK (NTK) brand sensors. This causes the Bosch sensors to take longer to heat up, and may affect the OBD computer. Note that the prices are taken from NAPA's website, due to local availability. They can be found for US$48.99 and US$51.99, respectively, at www.summitracing.com, but with a Delivering and Handling Charge of US$11.95 and estimated ship date often 2 weeks out, NAPA may be the best option when considering convenience. These items may also be purchased at the dealer, but due to the vagaries of dealer pricing depending on location, local taxes, and other factors, that option is not discussed here. Often held in stock at NAPA auto parts stores.
Fuel filter:
Az P/N FF676DL
US$12.99 (AutoZone)
Notes:
Simply a widely-available inline fuel filter. Often held in stock at most auto parts stores.
Air filter:
AMSOIL P/N EAA29
US$38.10 (AMSOIL)
Notes:
This air filter comes with a recommendation from the comments. Good for 100,000 or 4 years, which ever comes first, and a price point at just under twice what an average conventional cellulose filter would cost, AMSOIL air filters purport a more efficient nanofiber techonology that only requires a simple wipe-down and dust-off once a year. Unfortunately, this item may only be available through order (http://www.amsoil.com/catalog.aspx?code=EAA29-EA)
Again, please feel free to add any notes or comments to improve this list.
spectre853 is offline
post #2 of 11 Old 04-25-2012, 02:55 PM Thread Starter
spectre853
An excellent article on the pros and cons of conventional oil vs. synthetic: http://auto.howstuffworks.com/synthe...-motor-oil.htm
Further discussion on the oxygen sensor conundrum: http://www.jeepforum.com/forum/f13/w...ensor-1049729/
post #3 of 11 Old 04-25-2012, 03:20 PM
whitexj98
Rockauto typically beats everyone on price and fast shipping.
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline
post #4 of 11 Old 04-25-2012, 07:59 PM
whowey
1988 MJ Comanche
Accel uses brass not copper contacts on its caps and rotors. There are other caps out there that have the brass contacts that are cheaper than Accel.
There are a handful of thoughts on K&N filters specifically and oil soaked gauze filters in general. Many consider them to allow far too much dust and sand through them for proper filtration.
1988 MJ
1990 XJ A whole mess of stuff
1990 FSJ CS-130
1994 ZJ Happily gone
whowey is offline
post #5 of 11 Old 04-25-2012, 08:29 PM
NJXJ91
Hey man great list. I think you could expand a little but, but a good start
A buddy of mine (jeepkid03) recommended this filter : http://www.amsoil.com/catalog.aspx?code=EAA29-EA
instead of the k&n
NJXJ91 is offline
post #6 of 11 Old 04-26-2012, 10:44 AM Thread Starter
spectre853
Thanks for the catch. Difficult managing that wall of text. And do you have any specific recommendations for caps?
post #7 of 11 Old 04-26-2012, 10:47 AM Thread Starter
spectre853
instead of the k&n
Thanks for the tip!
post #8 of 11 Old 04-26-2012, 10:48 AM Thread Starter
spectre853
What other information would you like to see?
post #9 of 11 Old 04-27-2012, 02:19 AM
Shane1447
Hows about exhaust seals/gaskets, injector cleaning, and crankcase cleaning?
Shane1447 is offline
post #10 of 11 Old 04-30-2012, 05:05 PM
DezertTJ
About the distributor cap, the napa echland brand (ech) is a great cap too along with napa gold oil filters (wix brand)
DezertTJ is offline
post #11 of 11 Old 05-08-2012, 07:38 PM
IonlyBuyJeep
Bosch Platinum Plus
For late model Cherokee's with the 4.0L I6 that don't have a distributor go with the Bosch Platinum Plus spark plugs. I just put them in my stock Cherokee and they made a big difference. They are 20cents more than the copper but so worth it. You can get them at Pep Boys and Napa.
IonlyBuyJeep is offline
distributor cap , filter , oxygen sensor , spark plug , tune up
Is there a hardware guide out there anywhere? dover21 XJ Cherokee Technical Forum 8 05-03-2010 01:40 PM
XJ Tune Up and Performance Tune emcvay XJ Cherokee Technical Forum 7 09-04-2009 11:14 AM
XJ buyers guide... acoley XJ/MJ Cherokee Non-Technical Forum 5 07-30-2008 09:54 AM
2.8 performance guide tjpries XJ Cherokee Technical Forum 7 04-17-2008 11:59 AM
Buying Guide! *HELP* Tenny XJ Cherokee Technical Forum 1 04-13-2005 06:20 PM
