XJ and TJ compatibility? - JeepForum.com
post #1 of 5 Old 10-18-2007, 01:56 PM Thread Starter
mknherhappy
I currently own a 98 TJ, I'm in the process of buying a 2001 XJ. The engine is the same, so I assume, most engine items are the same. Are there other parts that are interchangeable between the two? Are Wheels? Etc.?
Thank you for your input.
mknherhappy is offline
post #2 of 5 Old 10-18-2007, 02:02 PM
dyna
Good lordy, dont put parts off the TJ on the XJ, You`ll jink the poor thing..
dyna is offline
post #3 of 5 Old 10-18-2007, 04:13 PM
drewguere
drewguere's Avatar
Wheels are, most drivetrain parts are (minus axles) interior could prolly be switched over if you wanted...Thats about all I can think of
2002 GMC 2500HD 8.1L - Tow Rig
1998 Jeep Cherokee - Wheelin Rig
1988 Jeep Wrangler - In progress...
drewguere is offline
post #4 of 5 Old 10-18-2007, 08:04 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Front D30 from the TJ will bolt right up. Both will be LP by the way. You could bolt up a HP D30 from a 99 or older XJ to your TJ or the new XJ. The TJ may have clearence issues with front driveshaft if it's not lifted.
Pretty much the extact same engine with the XJ having a extra sensor or two (like the aux fan one).
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #5 of 5 Old 10-29-2007, 04:38 PM
Forrest_bell
Is the front driveline the same between the two?
I saw you said that there might be clearance issues using a XJ d30 in a tj.
My buddy needs a new front shaft for his tj with a budget boost and i wonder if an xj one will do the trick.
Forrest_bell is offline
motor compatibility?? bigdummy30 XJ Cherokee Technical Forum 4 01-11-2010 12:16 AM
Dana 30 compatibility XJ90 XJ Cherokee Technical Forum 8 03-28-2009 03:12 PM
2.5l compatibility czaker MJ Comanche Technical Forum 1 03-22-2009 09:40 PM
Body compatibility tylerdj XJ Cherokee Technical Forum 1 12-14-2007 10:43 AM
compatibility? jftimbo MJ Comanche Technical Forum 7 10-06-2005 01:04 PM
