XJ Steering Upgrade - JeepForum.com
post #1 of 9 Old 12-17-2009, 04:10 PM Thread Starter
Art101
XJ Steering Upgrade
Ok so I am looking to upgrade my steering. I am more concerned about quality than I am concerned about parts. My rig is a 2001 xj, it has 6.5" lift with 35s, lockers, gears, axles out of a 99 xj. I have stock steering right now and it is loose and ****ty. My steering box is not loose, its got to be something else. What I want is super responsive steering, that is strong enough for the future hydro assist in the future. I hear currie is a good way to go. Send me some links and give me advice. Thanks.
Art101 is offline
post #2 of 9 Old 12-17-2009, 08:28 PM
the_weirdo
the_weirdo's Avatar
I have the JCR 1-ton UTK steering. It's plenty beefy but if I could do it over, I would probably go Currie
- no reaming the knuckles or Pitman arm
- no "dead spot" in the steering
Only downside is that you cannot replace the tie-rod ends on the Currie - you gotta replace the whole drag link.
the_weirdo is offline
post #3 of 9 Old 12-17-2009, 09:38 PM
beneharris
1995 XJ Cherokee
Kevins offroad has a pretty good looking hd steerign. Its on sale right now too
1995 Jeep Cherokee- 5" lift, Locked Up Fab Long arms, 31" Km2's. AA SYE kit, with Xj front driveshaft. Dual 12" Pioneer Subs
1967 Restored Volkswagon Bug- DD
Christian Jeep Member #133
beneharris is offline
post #4 of 9 Old 12-18-2009, 03:52 AM
USMC_XJ
2003 WJ
If it is loose, I would make sure that your caster and toe-in are within specs. Also make sure the steering components are good.
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
post #5 of 9 Old 12-18-2009, 05:11 AM
Muddeprived
Muddeprived's Avatar
He shouldn't even be running stock steering with 35's and 6.5" lift.
Go with a crossover steering setup. You are too high for the currie steering. It will work but you are pushing it.
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #6 of 9 Old 12-18-2009, 05:14 AM
USMC_XJ
2003 WJ
I agree. However, if he is, or didn't set the caster or toe-in correctly, that could definitely cause loose steering. That was what I was addressing as I don't have a lot of info on aftermarket steering short of the ZJ V8 tie rod upgrade.
USMC_XJ is offline
post #7 of 9 Old 12-18-2009, 05:37 AM
redhanded
the kevins off road setup looks good. a little pricey, but its bolt in and looks beefy.
2000 xj. 4.0/auto/np231. completely stock
redhanded is offline
post #8 of 9 Old 12-18-2009, 05:38 AM
Muddeprived
Yeah that's true.
post #9 of 9 Old 12-18-2009, 11:37 PM Thread Starter
Art101
ok so i found on the axle side mount of the tracbar, the bolt was too small allowing the whole trackbar to shift... got a bigger bolt and that made a freaking amazing difference... i am still looking into beefier steering though
Art101 is offline
steering box upgrade xjhavens XJ Cherokee Technical Forum 19 04-18-2010 08:19 PM
Steering box upgrade?? XJ Splug XJ/MJ Cherokee Non-Technical Forum 4 01-10-2010 02:47 PM
need to upgrade steering what to do? halfleft XJ Cherokee Technical Forum 5 12-22-2009 12:18 PM
Steering Upgrade MTXJ XJ Cherokee Technical Forum 8 04-05-2009 12:22 PM
Steering Upgrade xjrrrdx XJ Cherokee Technical Forum 0 06-18-2006 04:46 PM
