xj steering box - JeepForum.com
post #1 of 3 Old 07-31-2006, 01:29 AM Thread Starter
trev6q8z
xj steering box
My jeep has a heavy knook in the front when I turn the steering. A friend and myself are pretty sure it's the steering box. Can anyone tell me if this is a common problem with XJ's? I have owned XJ's for the past 6 years now and have not heard of this.
trev6q8z is offline
post #2 of 3 Old 07-31-2006, 01:58 AM
XJING
Most likely not the steering box
Try the trackbar first, common on all xj's that the trackbar becomes loose on one side or the other, the other thing to do is jack the truck up and put stands behind the lower control arms. and have someone move the steering from right to left to see if anything is bent or binding. give all the components a good shake, you could have loose or worn TRE'S, but my bet is on the trackbar. Steering boxes get sloppy, unless you get in an accident you usually dont get a "knook" out of them Good Luck.
XJING is offline
post #3 of 3 Old 07-31-2006, 08:24 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
You guys nee dto check teh steering box mount. These are prone to cracking especially with big tires and no bracing of any kind.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
Changed out steering box and now steering wheel won't lock... what did I do wrong? bizzo15 XJ Cherokee Technical Forum 2 11-12-2009 06:43 PM
Steering still a tad jerky low speed, power steering issue? Swagger_Wagon XJ Cherokee Technical Forum 7 05-15-2009 07:54 PM
Whinning power steering; replace steering box or pinion seal? myriad360 XJ Cherokee Technical Forum 1 05-12-2009 09:15 PM
Steering Issue!, steering wheel and tires wobbling Swagger_Wagon XJ Cherokee Technical Forum 10 07-27-2008 01:17 PM
loose steering + steering wheel shimmy Witt XJ Cherokee Technical Forum 1 07-28-2003 02:12 AM
