XJ (sort of)- Ford driveshaft question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > XJ (sort of)- Ford driveshaft question
IRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-10-2014, 07:53 PM   #1
Nightpath
I'll make this short and simple (tired, stepdad just died, can't stop thinking about things).
I had a XJ, used the drivetrain in another vehicle (plus the rear axle and all the other parts...it's an AMC Eagle, the XJ's father, the firewalls are identical... but that's another story)
Anyways, I've come across an issue. The rear driveshaft has to be 39" long and I've found that the Ford Expedition driveshaft is almost the perfect length. Would I be correct in thinking that a 1310 ujoint will allow me to adapt the Expedition driveshaft the Jeep t-case and rear axle yolks?
Also need a 29" front driveshaft. Anyone have any ideas?
Nightpath is offline   Reply With Quote Quick reply to this message
Unread 11-11-2014, 12:22 AM   #2
bluejunior
I'd have to do a little googling on the rear DS question, but that sounds right based on what I was reading for my 8.8 swap. I know I've seen a 29" stock shaft recently. it was either the front shaft for the pre-2000 XJ's that had the HP30 (the higher pinion's closer to the TC, thus shorter) or it's the ZJ's that had a long-pinioned D30. Worth checking parts lists.
"I just need to do a couple tweaks on my jeep, I'll be done in a couple hours." - gone 3 days
bluejunior is offline   Reply With Quote Quick reply to this message
Unread 11-11-2014, 07:20 AM   #3
Nightpath
Any news?
Unread 11-11-2014, 05:40 PM   #4
rugsucka
Searching for yourself is the way to find the answers you are looking for. You are not proposing a common swap so don't expect much input.
Here's a handy dandy link EVERY Jeep owner should tuck away to compare DS styles, types of joints, size of joints, and where to find them. It's a bit dated, but then again so are XJ's.
Sounds like you should find a ZJ front DS from an Automatic. I run one front and rear and carry a common spare at ~5" front and rear. Usually picked up for ~$50 in part outs, I just picked one up off the classifieds here for $60 shipped.
'00 XJ - Somewhat modified
'01 Venture - high mileage, paid for, shut it
rugsucka is offline   Reply With Quote Quick reply to this message
Unread 11-11-2014, 08:18 PM   #5
Nightpath
Sorry but I've been a bit distracted with a few things and won't have a lot of time for Internet fun.
Thanks for the post thougj.
