#91 | ||
#92 |
Ok. So my turn for a question for those with a lil more experience with different brands. Im looking for a new amp on a budget. i need 300-500 RMSx1 at 4ohm. (current subs 4ohm load 400RMS, desired upgrades the pair would take up to 520RMS at a flexible resistance, based on my chosen exact model). Im looking at fosgate, profile, and alpine. And ive used visonik (read: crap), Blau, and MTX amps on top of those. Suggestions?preferences? Opinions on factory refurbs?
#93 | |
http://www.edesignaudio.com/product_info.php?cPath=1_22&products_id=45 normally $220, on sale for $125 100W x 2 @ 4 Ohm 200W x 2 @ 2 Ohm 400W x 1 @ 4 Ohm Height : 2.250" Width : 9.850" Length : 12.000" Overall Length(w/ feet) : 13.100" Its not a brand you mentioned but they are top notch and have great warranty and customer service. They design all of their own equipment ( not a rebadged generic item) and sell direct so no middle man markup. |
#94 |
Never heard of em, but the Wattage ratings and draw sound right.....and it should have enough to push the subs i wanna replace the rockfords with too, though i think when i get a real amp they should come to life and i may keep em (i havent measured, but based on sound i swear my "360" watt visonik is puttin out more like....200. Thanks for the heads up seems like a great deal. I knew this thread was a good idea lol
#95 | |
#96 |
with those surrounds it'd have to have a huge maximum excursion. And as my tastes have matured ive become a big fan of 6.5" and 8" subs. I really have no desire to compete and the smaller speaker provide an amazingly detailed and (depending on the enclosure) a much tighter, cleaner sound. I'll def keep them in mind in the future. I'm afraid its the curse of the fact that i just started this kinda stuff about a year and a half...so ive got the install experience from helping all my friends and ive done a lot for my age but i just havent been able to try out as many brands as some of you guys. or had the money for the JL or Focus types.
#97 | ||
Universal Cereal Bus
2001 Cherokee Limited My Build Thread: 6" IRO Long Arms and coils, JKS ACOS, OME 4" Leaf springs w/1.5" Teraflex shackles, RC Shackle Relocation Brackets, ~34" BFG KM2, RC Quick Discos, Fox 2.0 IPF Shocks, Rear Disk Brakes, 60mm Bored TB, Cobra Injectors, Rugged Ridge Header, 2.5" Exhaust with Borla Muffler |
#98 |
Bluejunior, nice info & ideas but you all need to check out this sub fab/install. I did it per his guide w/little variance or trouble. Sounds killer and takes NO precious cargo room. Beats the pod price hands down
XJ5150 Last edited by xj5150; 01-29-2009 at 10:11 PM.. Reason: change hyperlink |
#99 |
ED is awesome for home audio... I've heard their car audio (Where their company started) is top notch.
#100 |
The pod is one of my favorite suggestions cuz anyone can install it, all it takes is a power drill. That's def an awesome fab job, I'm just hesitant to suggest things since everyone has different levels of fabrication experience. Thanks again to everyone for the support and input, this thread really is becoming a good resource for ideas. Another note for those who may not have thought of it, ibe seen a large number of ppl cut speaker holes out of their rear gate plastic, and use the existing holes in the metal beaneath to house the magnet structures of the all-mighty 6X9. NO chance of keeping a factory look that way, but it can provide you with that precious mid-bass power that is SO hard to achieve without high end versions of the small round speakers that can be put in the doors and/or roof. they're hard on the hydraulic lifts for your gate, but those are easy to replace with beefier ones, and even my '01 wont hold the gate if its cold, so chances are you have or will have to replace them anyway. You lose the factory look, but a cheap pair of 6x9's puts out the bass depth and volume (if not clarity) equal to or beyond many good (good meaning polk, infinity, alpine, etc...we all know high-end stuff doesnt need that much help) 5 1/4's as a rear speaker. and though you'll never push them well, a head unit can drive these speakers to much better bass than the rear roof. Its something to keep in mind if you REALLY want better sound but are also, as i often am, REALLY not in a position to spend money on quality equipment. And if you're into having flashing speakers hanging out of your gate. As ive said, seen it done never done it. buts its an interesting idea i havent seen mentioned here.
#101 |
Good thread....
I used to have a Dakota with a high end Alpine head unit and all JL Audio speakers. 2 6.5 Components upfront and 2 6.5 2 ways in the rear factory locations all. For the record, with some tuning the JL speakers have an amazing sound for the money I spent. I was running 2 x 10 Clarion Pro Audio 10" subs in an MTX Thunderform enclosure.... awesome setup. My current ride....my XJ is running a Pioneer Premier head unit with full iPod and USB connectivity via a proper (included) iPod cable. It has a full 3 line OLE display and not only has full text display, but full search functions. I currently run an 8 GB High Speed (XPorter) USB thumb drive in the glove box....holds a lot of MP3's. I bought a 10 Infinity Dual Voice Coil sub in a Bassworx ported box and dropped a Premier 400 Watt class D amp and a Tsunami 1.2 Farrad cap on it. All connected with pro audio quality wiring.... which is all bolted nice and clean to the back of the box. My speakers are a set of 6.5" Alpine's, 2 x 2 ways in the overhead rear locations (2000 XJ) that I added insulation to, and the fronts are a set of components. I mounted the tweets in the door panel about 6 inches above the mids to give it a little separation. For now (because I was lazy) I used the stock speaker leads front and rear, but I will be upgrading those this spring. I WISH I could have squeezed the amp(s) and cap plus all the wiring into the rear seat compartment with a couple of vents, but alas, it was too big. I did look at the XJ rear panel box, but wanted a 10" sub again and got a SMOKIN deal on the combo I got. I will be following this thread, to see how it evolves... looking forward to more techie stuff on Car Audio. I love the stuff, and need my audio fix on the way to work every day! A couple of pics. Infinity in box... just a fluke it was same color as Jeep (honest) You can just see the Alpines in the door in this shot.... stealthy. Head unit in dash in a cheap *** fit kit (came with Jeep)
2000 Jeep Cherokee Classic 1992 M101 CDN2 1/4 Ton Off-road Trailer. 90% Daily Driver 100% Fun! ____=__= l l ,[_____], l---- L -[]lllllll[]- ()_) ()_)--o-)_) |
#102 |
Clean setup Gman Vimb...I like the color match too haha.
1ton tj build |
#103 |
a note on installing amps, if you remove that recessed portion of the panel just behind the right rear wheel well, then cover the hole, its a great place for all sorts of custom box work or just to stash an amp (if you cover the hole with something breathable, say color matched carpet, its very clean looking AND allows good airflow. Just a thought.
#104 |
SO this is just a question because im curious to see what everyone else's opinions are. Do you prefer a tight sounding sealed box, or that loud, boomy ported sound?
to cast the first vote, I prefer sealed, though i'm currently running a ported one. |
#105 |
I prefer a sealed box sound. Liked ported when I was younger but now theres always kids in the Jeep so I cant push the volume loud anyway, so I prefer the tight sealed sound.
| Tags |
| audio, audio components, jeep xj sound, sound system, stereo system |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
