XJ Screamers-The cherokee audio thread - Page 54 - JeepForum.com
 3Likes
post #796 of 1059 Old 02-03-2014, 11:36 AM
Teej
My only concern is the SS amp is CONSIDERABLY larger... I'm not sure where I'd put it.
Instagram:
CoTM March 2014
CoTM May 2015
Teej is offline
post #797 of 1059 Old 02-03-2014, 11:56 AM
Ozman94
Shouldn't be a problem... worst that happens is you build on to your box for a secure & safe place to mount it. You can worry about that after you buy the sub and have a box designed for it.
As long as you plan on sacrificing some of the area behind your seats anyways...
Ozman94 is offline
post #798 of 1059 Old 02-03-2014, 12:07 PM
Teej
Yeah, I'm gonna do something about a sub so yeah. I'll probably just do that. Only thing is I'll have to run a LOT of wire...
Instagram:
CoTM March 2014
CoTM May 2015
Teej is offline
post #799 of 1059 Old 02-03-2014, 12:19 PM
Teej
Just bought the REF4.760 and mm6501s
Now all I'm gonna have to do is find a place for the tweeters... Hmm.
Oh yeah, and I gotta deaden the doors...
Instagram:
CoTM March 2014
CoTM May 2015
Teej is offline
post #800 of 1059 Old 02-03-2014, 01:04 PM
Ozman94
I'd play around with them first before starting anything.
As for sound deadener, nobody works to help the customor like showdown:
http://www.sounddeadenershowdown.com/
Do some research on this website. Main concept for doors is to apply deadener and then use something like ensolite to cover ALL holes etc. Then use some type of sealant to make the door and the door panel act like an enclosure for your midwoofer.
Ozman94 is offline
post #801 of 1059 Old 02-03-2014, 01:10 PM
Ozman94
As for wiring, just run one line of 1/0 gauge wire to the back underneath your carpet. You'll never need anything bigger unless your working on more than a 2k system. And that' an expensive jump.
Use a D-block in the back to split the 1/0 to two 4 gauge inputs. This is expensive but it takes care of everything except speaker wire. I normally run 12 gauge since I have my amps in the back and the comps are up front. 50' of raptor 12 gauge on ebay is like 15 bucks. or for 31 you can get 100'.
knu wiring:
http://www.knukonceptz.com/productDe...rodID=KFX-PK20
raptor wiring:
http://www.ebay.com/itm/160560649564...%3AMEBIDX%3AIT
If you don't ever plan on getting a larger amp than that hifonics, you'll be okay running 4 gauge from your batt (if from knu, some lower brands skimp on their wiring by making larger rubber tubing).
Or to save some money, and you don't plan on ever running more than 250 amps worth of power, you could buy cca (copper-clad aluminum). It's a cheaper type of wire, but nonetheless noteworthy depending on your application. Best advice I can give is to buy the biggest wire that you think you'll end up using, ever. You'll save money in the long run.
http://www.knukonceptz.com/productDe...prodID=KCA-PK0
If you buy that, you should get a d-block as well and some 4 gauge wire along with ring terminals and any other accessories etc. And don't forget the speaker wiring
Ozman94 is offline
post #802 of 1059 Old 02-03-2014, 01:40 PM
Teej
knu wiring:
raptor wiring:
I'll check out the sound deadening stuff. Why don't I just run a second 4 gauge wire from the battery? It'd be a lot cheaper since I could just get a wiring kit.
Instagram:
CoTM March 2014
CoTM May 2015
Teej is offline
post #803 of 1059 Old 02-03-2014, 01:44 PM
Ozman94
I was assuming we were based off scratch. Two runs of 4 will be closer to 2 gauge then 1/0, depending on the brand. What 4 gauge wire do you have now?
Ozman94 is offline
post #804 of 1059 Old 02-10-2014, 09:10 PM
Teej
Look what showed up when I went home this weekend! Still waiting on my speakers. Also, Ozman94, text me, I lost your number.
Instagram:
CoTM March 2014
CoTM May 2015
Teej is offline
post #805 of 1059 Old 02-10-2014, 09:56 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Did you ever decide on subs?
D3<!L!>3D
S8NNG8 is offline
post #806 of 1059 Old 02-10-2014, 10:13 PM
Teej
Gonna do a single ported Sundown SA-12.
Instagram:
CoTM March 2014
CoTM May 2015
Teej is offline
post #807 of 1059 Old 02-13-2014, 11:45 AM
RisingJeeper
Protect mode yet again. I got a kenwood, 248U I believe. I have pretty low quality speakers, would just blowing them make it go into protect? Recently redid the speaker wires to the headliner so I think they wouldn't have insulation problems. Does that mean its gotta be front speakers or should I still check back for being blown? How can I check source, besides unplugging speaker wires one at a time? I unplugged RCA cable to amp that supplies sub and it was still on protect so should I rule out the sub?
RisingJeeper is offline
post #808 of 1059 Old 02-13-2014, 11:49 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Check the front doors first. Because of the doors get opened and closed and periodically slammed, the wiring can get jarred loose.
D3<!L!>3D
S8NNG8 is offline
post #809 of 1059 Old 02-14-2014, 07:54 AM Thread Starter
bluejunior
bluejunior's Avatar
An easy test to see if blown speakers are causing the protect is to check the resistance at the speaker wires going into the amp. It's not one hundred percent accurate but it's a quick, easy place to start
Lifted, Locked, Stiffened
bluejunior is offline
post #810 of 1059 Old 02-14-2014, 08:43 PM
JeepaholicNinja
I'm glad I found this thread and it's still active! I have a 2000 XJ and I just put in some new 5.25 door speakers and a new head unit. I'm looking to get a bit more bass and volume w/out distortion, but how do I know if the distortion is coming from my head unit or speakers?
Oh and if I installed a powered sub off the RCAs in the head unit, it would be okay even though it's a low-wattage head unit right? Since it has its own amp?
And this might sound stupid but my mom's car is a 2010 Kia Optima, with a stock sound system that imo has really good bass response...How big of a powered sub do I need to achieve the level of bass/quality of most new cars (think year 2000+Audi Bose)
2000 Cherokee Classic
3" Zone lift, THULE roof rack, Hella 500 Black Magics
JeepaholicNinja is offline
audio , audio components , jeep xj sound , sound system , stereo system
98 Cherokee se audio wiring question speeddemon651 XJ Cherokee Technical Forum 2 12-27-2009 09:39 PM
Cherokee misfortunes/stories thread makemusic116 XJ/MJ Cherokee Non-Technical Forum 32 12-13-2008 02:55 PM
my cherokee thread aircruiser XJ Cherokee Technical Forum 103 03-17-2008 10:09 PM
cherokee audio wiring problem Cherokee98_4x4 XJ Cherokee Technical Forum 4 06-09-2006 01:03 PM
89 jeep cherokee factory audio mud-dog27 XJ Cherokee Technical Forum 4 04-07-2006 11:46 PM
