XJ Screamers-The cherokee audio thread - Page 48 - JeepForum.com
 3Likes
post #706 of 1059 Old 09-02-2013, 01:10 AM
94jettameowpsst
Just metered my jeep today and all sealed up on the windshield I put down a 151.1 @ 38 hz. I peaked high but I also hit a 149.5 @ 32hz also
94jettameowpsst is offline
post #707 of 1059 Old 09-02-2013, 10:30 AM
alexrule123
alexrule123's Avatar
That's awesome!, did you post pictures of your setup earlier?
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #708 of 1059 Old 09-04-2013, 04:00 AM
Mike934
I'm curious here guys. I'm no audio nut at all, far from it. I'm looking to upgrade what I have currently.
I have a alpine deck (cde-102) and 4x 5.25 Sony explode speakers in stock locations & factory speaks under the lower dash bezel. my jeeps a 1988. I don't want a sub, but I want some bass..not ALOT but some. I'm more of a mods/highs kinda guy, but a little bass would be nice.
Currently I can turn up the deck about 3/4 of the way before the speakers become distorted. Again I want some more highs in my ears, and some more bass. Preferably keeping stock locations, i dont mind modifying them to fit larger speakers eithe rbut wanna keep it simple.
And a new deck..been looking at the Alpine's iDA-X001 or something similar. I like its basic setup, blue tooth and what not. If I had a budget I'd say 200-300 on speakers & whatever the deck is but preferably around 200 as well. I don't mind running an amp either but would have to go under the rear seat or passenger seat.
Overlanders do it over land via overlanding because they like to overland?
Mike934 is offline
post #709 of 1059 Old 09-04-2013, 06:34 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
If you're ok with cutting holes, I put 6.5's in all four doors running off a 4ch/ 500w amp. That's about all you'd need. The 102 sucks, I love Alpine, but that is their cheapest deck with very little sound options. High pass crossover would help you too. With little bass, you can set it at 70-80hz.
D3<!L!>3D
S8NNG8 is offline
post #710 of 1059 Old 09-04-2013, 01:19 PM
bobthecatkiller
Find some stock tweeters
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #711 of 1059 Old 09-07-2013, 08:30 PM Thread Starter
bluejunior
bluejunior's Avatar
a small external amp with a pair of component speakers up front does WONDERS. A good amp will also make up for some shortcomings in your deck by adding things like a high-pass filter. That lets you pull out the bass that's too low for your speakers to really produce, so that what they can produce comes out cleaner and can go louder with less distortion. Doesn't have to be huge, you'd be surprised what 40-60 watts per channel to decent speakers sounds like. I have useful frequency response well into the 30's out of my Polk MOMO components.
I strongly suggest keeping an eye on craigslist for basic upgrades like you're asking for. I personally tend to look for polk, alpine or kicker speakers out of the big brands for use without a sub, and any 4-channel amp in a 40-60 watts per channel area would provide a HUGE increase in sound without taxing your electrical system or needing a capacitor or anything. To buy new, I believe alpine type-s components are pretty reasonably priced on sonicelectronix.com You could also pick your own components somewhere like partsexpress.com, picking your own can get better results for the money but takes more research.
Lifted, Locked, Stiffened
bluejunior is offline
post #712 of 1059 Old 10-19-2013, 12:29 PM
NotSure
Just read 30+ pages and didn't find what I was looking for... So I've decided to sign up in hope that someone can help with my issue.
I recently bought a 2000 Cherokee with stock speakers and an after market Alpine head unit with interchangeable face with an AUX input.
About 2 weeks ago I began using the AUX input to play my iPod.
Since then, the head unit will intermittently cut off without fail any time the volume exceeds 14, or when around 12 or 13 when the A/C or heater is running or when putting up or down a window.
It will NOT cut out if I am just listening to the FM radio whilst trying any of the above to get it to cut out.
I replaced my battery the same time I bought the AUX cable to play my iPod. I've checked all kick panel fuses and all are fine. I've also pulled the head unit out far enough to inspect the rear for any issues, but aside from obvious broken or cracked wires, I don't know what I should be looking for
I've spent the last few hours searching the internet for help, but have come up short and any help with this will be greatly appreciated.
NotSure is offline
post #713 of 1059 Old 10-19-2013, 07:30 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Is the deck plugged in with a harness, or is it hard wired? If there's no harness, it's possible the installer found an inadequate power source. The power being requested is overloading that circuit.
D3<!L!>3D
S8NNG8 is offline
post #714 of 1059 Old 11-05-2013, 08:08 PM Thread Starter
bluejunior
bluejunior's Avatar
Double-check your ground wire as well, I've seen head units (certainly not my own after I changed a cable in a hurry <<...<<...>>) manage to ground poorly through other parts of the wiring and run while the actual ground isn't connected. That would choke down the power and depending on the circuitry of your head unit might cause the problem you're describing (as well as being a serious risk to kill the unit permanently)
post #715 of 1059 Old 11-19-2013, 05:56 PM
rrxjeeper71
Junior Member
rrxjeeper71's Avatar
Originally Posted by bluejunior View Post
Not having A huge mechanical knowledge base I'm starting this thread to take questions on what I AM an expert at. XJ audio. I've installed four completely different sound systems in Cherokees, all of them beyond what internet fit guides claim is possible, and all but one able to withstand everything but a rockcrawler tumble of a cliff. I'm also great with Wranglers and CJ's and can figure out anything else. To give you an idea of what ive been able to do:
Cherokee: Four 6.5" speakers 2 5.25" and an 8" sub with no cargo space lost and all bolted in tight enough to take rollovers with nothing but a cd skip
Cherokee: Same speaker sizes with dual 10's and dual amps, has withstood spins, wrecks, and a couple trail rides
Wrangler: twin component 6.5" speakers with twin 8" subs, bolt on and marine rated...blows the crap out of a soundbar (although he kept that too)
Cherokee: four 5.25" speakers with a 10" sub bolted in.....tilt tested but not roll over (should work, just haven't tried it)
and of course, the stock upgrade, with all aftermarket marine rated speakers with better size and durability to drown out the muffler and survive the elements.
like i said open to all questions i can tell you where and what to get, how much it'll be and how to install it on a cherokee or wrangler and can help you with pretty much anything else. It seems frivolous but whats a jeep jamboree without tunes that can withstand the trails AND are loud enough to turn the whole site to a club when you take it camping?
please post pics of your setup!~!!!
2001 XJ Sport
3.5 RC lift
31" BFG
rrxjeeper71 is offline
post #716 of 1059 Old 11-19-2013, 07:25 PM Thread Starter
bluejunior
bluejunior's Avatar
That's not actually my set up anymore, my old jeep got totaled and I opted to go simpler with the new one (my hearing's already going and I'm 24, time to downsize). There are some pictures of rear door speaker installs farther back in the thread if that's what you're looking for. Not much to show of mine right now with the subs out and the speakers intentionally non-obtrusive.
Current:
Polk MOMO Components 6.5" front, 5.25" rear being powered by a 75Wx4 infinity amp.
Dayton Audio Ultimax UM10-22 waiting to go in a cubby enclosure. Will be powered by a Profile Baja 1000 amp running ~480W
Still running an old Kenwood MP828 head unit (5-volt preouts are awesome and the built in EQ/crossover controls are surprisingly good)
To-do's:
flush mount the tweets in the windshield columns and the pillars at the back of the rear windows.
get the box for the Ultimax in
clean up the underseat wiring
I do really like the location of the front tweeters, they're out of the way and the windshield does a good job of reflecting the sound back into the car. these particular tweets are a little harsh, so not having them pointed straight at the listener is a bonus for me. The rear ones.....well I was lazy and didn't have many of my tools with me, so they're just stuck on to one of the screws holding up the trim. Sounds good, though I have them eq'd down to account for being right in the listeners' ears.
Side note: the MOMO's are the only 5.25 speakers I've used that fit the factory holes perfectly. They're discontinued and getting harder to find, but they're by far my favorite car audio woofers (that I've used myself, obviously there are better in the world), and the tweeters do sound good once you get them toned down a bit (the "s" sound and high hats are REALLY harsh on a flat eq). They have a great volume/SQ balance and the doors actually have useful response into the low 30's if you treat them right.
My next post will have pics and I'll update with pics of the cubby sub once that box is installed.
post #717 of 1059 Old 11-19-2013, 07:34 PM Thread Starter
bluejunior
bluejunior's Avatar
Pics
post #718 of 1059 Old 11-20-2013, 01:47 PM
bobthecatkiller
If you want a more clean look you could get the stock infinity tweeters, I have a couple sets I snagged from my junkyard every time I go
post #719 of 1059 Old 11-20-2013, 01:54 PM Thread Starter
bluejunior
bluejunior's Avatar
Honestly I don't notice them at all now, but they will look better once I flush mount them. The stock tweets are a great add-on even to he stock paper cones, although I'd worry about them handling the power I'm running.
post #720 of 1059 Old 01-26-2014, 04:05 PM
Mike934
Hey guys I'm trying to buy a set of 6.5 speaks for my xj. I have a alpine cde-102 deck which I plan to keep. And have a few choices of speakers to choice from, can anyone help me out? No amp will be installed, nor a sub. Just 4 speakers & the current deck.
Looking for a bit more bass & better/louder sounds over my current pioneer 5.25" are producing. I don't mind running 2 different brands incase 1 is better for lows and another is better for highs. I'm looking on ebay currently, my price is about 100 for all 4.
Speaker choices are,
Rockford Fosgate Prime R1653 Car Speakers 6.5" 2 Way Full Range Coaxial Audio
PIONEER TS-G1644R TSG1644R 6.5" G-Series 2-Way 250W Car Audio Speakers
Rockford Fosgate R1652S 2-Way 6.5" Car Speaker
Alpine SPE-6000 2-Way 6.5" Car Speaker
Mike934 is offline
audio , audio components , jeep xj sound , sound system , stereo system
98 Cherokee se audio wiring question speeddemon651 XJ Cherokee Technical Forum 2 12-27-2009 09:39 PM
Cherokee misfortunes/stories thread makemusic116 XJ/MJ Cherokee Non-Technical Forum 32 12-13-2008 02:55 PM
my cherokee thread aircruiser XJ Cherokee Technical Forum 103 03-17-2008 10:09 PM
cherokee audio wiring problem Cherokee98_4x4 XJ Cherokee Technical Forum 4 06-09-2006 01:03 PM
89 jeep cherokee factory audio mud-dog27 XJ Cherokee Technical Forum 4 04-07-2006 11:46 PM
