XJ Screamers-The cherokee audio thread - Page 47 - JeepForum.com
 3Likes
post #691 of 1059 Old 07-06-2013, 07:45 PM
alexrule123
alexrule123's Avatar
Originally Posted by Teeeejay View Post
I thought I saw a round one once... Guess not. Haha. I'm looking at possibly a sundown.
Yes go with the Sundown! Which line sundown are you looking at, the SA series?
Also take a look at soundqubed, aka audioque.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #692 of 1059 Old 07-06-2013, 08:06 PM
Teej
Looking at SA. Not sure how they perform sealed, though.
Instagram:
CoTM March 2014
CoTM May 2015
Teej is offline
post #693 of 1059 Old 07-07-2013, 01:57 AM
bobthecatkiller
I'm running 900w and my volts meter drops on higher volumes, it doesn't move to much but enough that at night it makes my already ****ty headlights dim.
Can I prevent this by upgrading my wiring from the battery to the alternator, grounds, and my headlight harness?
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #694 of 1059 Old 07-07-2013, 02:24 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
You need a power cap. 1 farad is all you need for 900w. I use a 1.5 farad cap and I'm pushing 2000w, works great, but barely enuf.
D3<!L!>3D
S8NNG8 is online now
post #695 of 1059 Old 07-07-2013, 10:39 AM
alexrule123
The big 3 is always a good upgrade (upgrade wires from alt to battery, chassis ground to battery and engine ground). How much does the voltage drop? If it is dropping a lot then I would suggest you first check and make sure you amp ground is a good ground.
The only way to prevent the dimming is to upgrade the charging system but an extra battery can help hide the lacking charging system.
post #696 of 1059 Old 08-30-2013, 10:08 AM
Teej
Okay, I have no idea if I'm doing something wrong. I've posted on other audio forums, and people just say XJs suck for midbass because of how the standing waves are. I believe this because if I put my head over the steering wheel, or below chest level of my driver/passenger seat, there is midbass. If I open either front door, there is midbass. If I have my head where it normally would be when driving or in the passenger seat, there is absolutely no midbass. The peak of the deadzone is 80 Hz, where there isn't a response at all. My sub with its box should peak around 70-75 Hz, and I have my crossovers set so the sub goes above 80 Hz and the speakers go below 80 Hz. I'm not sure if I have to relocate speakers to fix the midbass, or if I'm just SOL. Any ideas?
Teej is offline
post #697 of 1059 Old 08-30-2013, 10:18 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I've got my LPF at 120hz, HPF at 100hz. But I'm only running 5 1/4"s and the 10" subs.
D3<!L!>3D
post #698 of 1059 Old 08-30-2013, 11:18 AM
Teej
And I assume you have no deadzone around 80Hz?
Teej is offline
post #699 of 1059 Old 08-30-2013, 11:36 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
My Alpine deck has a Bass Center Frequency. I happen to have that set at 80hz, so no, it kicks you in the head everytime it hits 80.
D3<!L!>3D
post #700 of 1059 Old 08-30-2013, 11:55 AM
Teej
So does mine unless you're in the driver or passenger seat. I don't really get it.
Instagram:
CoTM March 2014
CoTM May 2015
Teej is offline
post #701 of 1059 Old 08-30-2013, 01:21 PM
sAe23
1995 XJ Cherokee
Please forgive the interruption, but I have a question about the filters (low pass / high pass) in a head unit and what they affect.
Do they only affect the head unit's amplified outputs, or do they also affect the preamp outputs??
It's a Kenwood KDC-MP6025 if that helps...
TIA
sAe23 is offline
post #702 of 1059 Old 08-30-2013, 01:32 PM
Teej
TIA
On mine, HPF affects speakers, and LPF affects the sub. Should be the same for yours.
Teej is offline
post #703 of 1059 Old 08-31-2013, 03:04 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Which way are your subs facing? Comparing my setup to how most people would set up 2 10"s...is unfair.
D3<!L!>3D
post #704 of 1059 Old 08-31-2013, 05:33 AM
Teej
I've had rear facing ported and currently have a side facing cubby sub. Had issues both ways.
Instagram:
CoTM March 2014
CoTM May 2015
Teej is offline
post #705 of 1059 Old 08-31-2013, 09:57 AM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
I always hated that my "bass obsession was in the way of using my cargo space. So I designed my own extreme custom install. I took a "wall" concept and moved it all the way back to being a false floor. All the detailed pics are in my build thread, if the pics are still there.
D3<!L!>3D
audio , audio components , jeep xj sound , sound system , stereo system
98 Cherokee se audio wiring question speeddemon651 XJ Cherokee Technical Forum 2 12-27-2009 09:39 PM
Cherokee misfortunes/stories thread makemusic116 XJ/MJ Cherokee Non-Technical Forum 32 12-13-2008 02:55 PM
my cherokee thread aircruiser XJ Cherokee Technical Forum 103 03-17-2008 10:09 PM
cherokee audio wiring problem Cherokee98_4x4 XJ Cherokee Technical Forum 4 06-09-2006 01:03 PM
89 jeep cherokee factory audio mud-dog27 XJ Cherokee Technical Forum 4 04-07-2006 11:46 PM
