Quantcast XJ Screamers-The cherokee audio thread - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > XJ Screamers-The cherokee audio thread
Old 02-05-2009, 05:20 PM   #151
lectrode
1987 XJ Cherokee
And then I went big or as big as I could afford.
Tried 1" dowel rod but later went to threaded rod.
This is a 26 cubic foot box with four Memphis Mojo 15's.
That big hole is my port tuned at 62Hz
Here is a pic when I was testing and moving things around adding batteries,etc. Go ahead and give me heck about my wires blue junior,
I deserve it after what I posted about your wires,
There are eight Memphis 1500D's totaling 12,000 watts,they are dual voice coil subs and I had one amp on each coil.3,000 watts per sub.
Then I dropped down a class and ran four Memphis Reference 1000's.
The one on top is a 4 channel running my mids & highs
lectrode is offline   Reply With Quote
Old 02-05-2009, 08:28 PM   #152
01LimitedXJ
nice setups! bet those were loud
1ton tj build
01LimitedXJ is offline   Reply With Quote
Old 02-05-2009, 08:53 PM   #153
lectrode
1987 XJ Cherokee
The big one hit 167.4 at the 03 World Finals.The best score was at a competition in Texas,it was cold & rainy and I hit 168dB's.
Old 02-05-2009, 09:00 PM   #154
01LimitedXJ
wow, nice man. Loudest I've hit was around 139 I believe, with my 2 15"s in a free air setup in a camry.
1ton tj build
Old 02-06-2009, 09:33 PM   #155
XJ Jay
140.1 with a signle 12 and 900watts in my Xcab S10, and that was on a TL not a mic.
XJ Jay is offline   Reply With Quote
Old 02-10-2009, 04:45 PM   #156
bluejunior
*XJ Jay*
great setups, and to be honest, i could care less about the wires, thats a lot of amps to manage. You seem to be the poster child for go big or go home, I have to ask where you find the time for all this?
bluejunior is offline   Reply With Quote
Old 02-11-2009, 02:59 PM   #157
lectrode
1987 XJ Cherokee
Originally Posted by bluejunior View Post
*XJ Jay*
I'm not XJ Jay,but I will answer for him,seein's how those are my systems.
I only messed with it for a few years back in 2001 thru 2004 during that time my oldest son was getting his drivers license and his first vehicle and he wanted a loud system.When I start something I tend to always go overboard
which almost always gets me in hot water with the wife.Anyway we started
competing in USAC Outlaw SPL and I just got carried away like always.As far
as finding time ,well there were alot of late nights.
Old 02-16-2009, 05:57 PM   #158
bluejunior
i do apologize scanning through posts I mix up the names of who posted what. Now i have a question for those with some experience building boxes, im building a box to go under the bench seat in my dads truck, and im trying to decide whether to go with an abs plastic tube port, or just to build a square port into the box, ive only used the plastic tube and slot ports in the past, since i mostly deal with sealed boxes. anyone got a strong opinion as to plastic tubes vs built-in square ports? in either case the port would be firing into the space under the drivers seat pointed at the drivers side panel (its a tight fit cuz its a ported box for an 8' sub with built in compartments for 4x6's all going under the bench seat of a c20)
Old 02-16-2009, 06:00 PM   #159
kboyts
I dont have much input on the port issue as I normally go sealed. But I would put 4x6 under the bench. Doesnt sound like a very good speaker location as it would be firing into the back of passenger legs (is the seat was occupied) or the back of the front seats, neither of which would be very desirable. But if you are set on putting them there since its a custom job anyway, why 4x6? Youd get much better sound out of a round speaker like a 5.25 or 6.5 .
kboyts is offline   Reply With Quote
Old 02-16-2009, 06:11 PM   #160
bluejunior
its a very short space and the trucks a restore job, no cutting or drilling to make better location. im replacing paper cone 4x10's under the bench with 4x6's and an 8' sub to open up the frequency range and give him the volume to hear it over that big old V8. the boxes for the 4x10's are almost too tall as it is, cant fit a 5.25 or a 6.5 without angling them up into the seat, which would kill the highs. its a 67 C20, its not exactly built with audio in mind, and has no factory speaker locations, just boxes under the bench. its not great, but it'll be a huge upgrade and doesnt mess up the factory condition and look of the interior. Its his baby, that restored look is WAY more important to him than the imaging quality of the speaker location.
Old 02-16-2009, 06:13 PM   #161
bluejunior
and its a single front bench seat. no back seat. so the speakers would be firing into the legroom area of the completely open cabin....sound actually carries better than you would think.....under 45mph anyway (he drives with the windows down mostly)
Old 02-16-2009, 06:19 PM   #162
kboyts
ok that makes sense then. With the size restrictions and situation you described though I would go with a sealed box. It would be a lot more forgiving on volume requirements. And it sounds like Im sure your dad isnt looking for every last Db of bass from the sub anyways.
Old 02-16-2009, 06:23 PM   #163
bluejunior
i originally had a sealed box planned, but the volume isnt hard to reach, cuz its a VERY wide and deep space, just very short.....and i figured the extra boost in the low end couldnt hurt cuz its just an 8"....I'll redo the measurements though...a sealed box is certainly always a safe bet...
Old 02-16-2009, 06:31 PM   #164
kboyts
If you dont already have the sub, Ive heard good things about this one - Tang Band 8
it has a very large excursion for an 8 and fairly affordable.
Old 02-16-2009, 06:35 PM   #165
bluejunior
great sub, i'll definitely take it into consideration thanks for the heads up....its less power hungry but deeper than the db 8" i was looking at, better frequency response too.
audio, audio components, jeep xj sound, sound system, stereo system
Glock Forum
