XJ Roll Cage - JeepForum.com
post #1 of 41 Old 01-20-2013, 08:17 AM Thread Starter
rmeyer332
XJ Roll Cage
I need some advise on building a roll cage for my XJ. I will be completely removing the top from the A-pillar back due to rolling the vehicle, it still drives straight, I know this first hand. I have done simple roll cages before on the standard trucks utilizing the frame to build off of. But since this is a unibody and something that going to be a daily driver. I want to do it right.
rmeyer332 is offline
post #2 of 41 Old 01-20-2013, 12:25 PM
166154
Sounds like one heck of an awesome project
Disclaimer is, I know nothing about fabrication or rollcages, but I have seen a thread of something similar!
A guy mates a Volvo Amazon (body on frame) to a Lexus (unibody)
http://forums.turbobricks.com/showthread.php?t=217930
The guy builds offroaders that are just like what you're looking to do too.
There might be some handy tips in that thread. Honestly it looks like he just reinforces what is left of the unibody 'pan' and builds a complete cage around it.
166154 is offline
post #3 of 41 Old 01-20-2013, 05:37 PM
whitexj98
First off the Unibody rails need plated front to rear to build a "frame". Then you have a more solid base to start from. Research other builds and steel the good ideas!
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline
post #4 of 41 Old 01-20-2013, 06:05 PM
KF4SQB
1994 XJ Cherokee
Isn't the front of the MJ ("frame" wise) the same as the front of the XJ? I know the rear is quite a bit different, but that's what I'm getting at. How is the rear frame of the MJ tied in to the front? Go get the rear of an MJ from the JY, and graft in onto the front of your old XJ.
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
post #5 of 41 Old 01-20-2013, 06:44 PM
KG8893
To be completely honest if it was me I would drive it just like that haha
I'm not saying we should kill stupid people... Just get rid of all the warning labels...
If you find my comments to "infer" something, they don't. Go to hell.
Built Not Bought #666
KG8893 is offline
post #6 of 41 Old 01-20-2013, 06:48 PM Thread Starter
rmeyer332
XJ's don't have a front clip or frame rails, it's a unibody.
post #7 of 41 Old 02-18-2013, 01:30 PM
Project1
SO any new work on this. I think your best bet is to do a 2x6 rocker replacment and work from there. LIke the Genright ones or make your own. Get a frame stiffener and weld the rocker and the frame stiffiner together.... so like the genright kit w/ frame stiffener, and that's a good working base for your A, B, & C pillar, the D pillar will be different. ill try and post a pic in a bit.
I have some good pics some where, how people replaced their apiller with a roll cage and its awesome.
You could go 10mr glass for the front window and get rid of the doors and the hatch ... maybe even an MJ tail gate ... if you look at my build thread you can see .. it looks sweet. and then cage the rest,
But the truth is once your jeeps that hard core ... your going to have to get dana 60's, 37's and hydro.... just saying
Or just go all the way and dove tail ... go for the gold ... its not over till its over
youll look like this when your done, just maybe door less, your xj would be SIIIIIIIIIIIICK .......
Project1 is offline
post #8 of 41 Old 02-18-2013, 01:55 PM
Project1
anyways .. heres a pic how to start your roll cage, like i said in the other post. Pics worth 1000 words
Project1 is offline
post #9 of 41 Old 02-18-2013, 02:42 PM
Project1
oh one more thing... (cough couch) build thread lots of pics (cough cough)
Project1 is offline
post #10 of 41 Old 02-18-2013, 02:55 PM
Motorcharge
MJs are exactly the same as the XJs as far as the frame/body goes except the MJ bed bolts on instead of being welded so it can be removed.
They have both. There IS a frame in the XJ, it's merely welded to the body rather than bolted. It is entirely possible to cut the frame from the body on an XJ and it's been done before.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #11 of 41 Old 02-18-2013, 03:04 PM
ibjeepin95
Attachment 546917
Personally, I'd scrap it and get another XJ. I like a full body XJ, but that's me. Another thing, what you will dump into that thing to do the cage "right", well, it's going to cost you. Do you plan to drive it on the street again?
If you are going to actually go through with it, start researching unibody plating, reinforcing, and cage work here: http://www.pirate4x4.com/forum/83-jeep-cherokee/
ibjeepin95 is offline
post #12 of 41 Old 02-18-2013, 03:28 PM
Project1
x2 .... I wouldn't spend much money on that xj but thats just me and each their own, and if you want to make it bad @$$ then go for it ... just depends what you want the end result to be
a pic of my favorite xj .. hopefully one day mine looks like that
Project1 is offline
post #13 of 41 Old 02-18-2013, 10:20 PM Thread Starter
rmeyer332
The plan is to chop the top and put a roll cage in it. It still drives straight and I'm partial to the 5 speed manual in it. This is going to turn into my warm weather jeep. I don't plan on buying kits, I can fab and weld. This was a slow roll over on this truck, it rolled onto a stump which caused most the damage to the top.
Stage one is:
Gutting and chopping everything from the A pillar back. This is where I'm at right know, waiting for warmer weather. Weather man is calling for up to 10" of snow by Friday.
post #14 of 41 Old 02-18-2013, 10:33 PM
EricsXJ
The Post man
EricsXJ's Avatar
If you are chopping the top I'd use 1.75" DOM. The rest is up to however you want to design it.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #15 of 41 Old 02-20-2013, 10:21 AM
Project1
the plan is to chop the top and put a roll cage in it. It still drives straight and i'm partial to the 5 speed manual in it. This is going to turn into my warm weather jeep. I don't plan on buying kits, i can fab and weld. This was a slow roll over on this truck, it rolled onto a stump which caused most the damage to the top.
Stage one is:
Gutting and chopping everything from the a pillar back. This is where i'm at right know, waiting for warmer weather. Weather man is calling for up to 10" of snow by friday.
pics or lies :d:d
This could be a bad @$$ build .. I'm stocked ... take lots of pics
Project1 is offline
