Quantcast XJ rear tow hooks - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > XJ rear tow hooks
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 03-26-2008, 10:29 AM   #1
Giviner
XJ rear tow hooks
Anyone make these? Were they ever a factory option?
I'm building up a beater 88XJ for my fiancee and I'd rather not drop a ton of coin on a custom rear bumper with D-ring tabs. I do want to have a recovery point on the back though.
Any help is appreciated.
2003 TJ Sahara
1988 XJ
www.jeepsofmcmurray.ca
Giviner is offline   Reply With Quote
Old 03-26-2008, 10:37 AM   #2
Meatroach
1992 XJ Cherokee
the only factory tow hook option I am awate of was a single tow hook on teh drivers side that bolted direct to the frame. For a cheaper option thean a bumper and better than a tow hook go to a wrecker and pick up a factory rear hitch. I go mine for about 30 bucks, Just make sure you get one with a 2" receiver. Then you can attach your tow strap to the hitch pin for a recovery point!
XJ
[COLOR="Red"]3.5" Warrior coils, Full leaf packs, Skyjacker Quick Disconnects, Rear swaybar delete, Pro Comp shocks, HD Steering stabilizer, BFG AT's, 1" drop shackles, Front tow hooks,Front skid, Warn T-case skid
bcjeepclub.ca
Meatroach is offline   Reply With Quote
Old 03-26-2008, 10:42 AM   #3
Guswut
Hey, I'd suggest getting a hitch if you need a recovery point and don't have the extra money to spend on a bumper. There are a few tow hook kits out there, try hitting up eBay.
Guswut is offline   Reply With Quote
Old 03-26-2008, 03:09 PM   #4
Giviner
Thanks guys, it's got a hitch on it right now, but it hangs down so damn low it will get caught on everything. I'm looking for an option that gives a bit more ground clearance
2003 TJ Sahara
1988 XJ
Old 03-26-2008, 03:19 PM   #5
Ski01xj
Ski01xj's Avatar
If your looking to do this on the cheap and you can weld, buy some shackle hangers and weld them to a plate that bolts up to the stock bumper location. I saw those somewhere and I'm looking for you, but I just can't remember exactly where it was.
Ski01xj is offline   Reply With Quote
Old 03-26-2008, 03:30 PM   #6
LBLjunkie
1997 XJ Cherokee
Got the cheapest hitch Reese offered and built a bracket out of that that I bolted to the pseudo frame rail. Not pretty but cheep, btw tow hooks for the front require you to do some drilling if you want to mount them on the back rails.
97 Cherokee SE with:Locker, sway bar disconnects, 98 I6
LBLjunkie is offline   Reply With Quote
Old 03-26-2008, 03:34 PM   #7
jshaab2
im also looking for rear tow hook. or hitch
01 xj sport . SS headlights sound system . dakota AT's 235/75 sound system and front and rear recovery, CB . AUX lighting EXIT 105 NJ
jshaab2 is offline   Reply With Quote
Old 03-26-2008, 06:08 PM   #8
Scottmc01
1993 XJ Cherokee
Look for a Hidden hitch. They tuck up under the bumper nicely.
93 Jeep Cherokee Country 4.0 AW4
Flowmaster / APN header
3" mismatched lift
30" Bighorns on V5's
Scottmc01 is offline   Reply With Quote
Old 03-26-2008, 06:30 PM   #9
itasor
2009 JK Wrangler
I put a factory rear tow hook on my 98. I made my own nut strip (welded nuts to strip of steel with holes drilled in in). If you don't to do that, the cost of the factory tow hook bracket + tow hook + nut strips will cost more than a cheap hitch. Downside to the hitch is that if you want to use nut strips you need to remove the rear bumper.
For the tow hook, it only needed 2 nuts on the nut strip, so I made mine small enough to slip into the frame rail without removing the bumper.
itasor is offline   Reply With Quote
Old 03-26-2008, 07:23 PM   #10
Tdad
X2
The U-haul hitch is a Hidden hitch with a U-haul sticker on top of the HH sticker (the u-haul one peels right off )
Got mine for $85.
Tdad is offline   Reply With Quote
Old 03-26-2008, 07:30 PM   #11
irish44j
1990 XJ Cherokee
here's what the rear factory tow hook assembly looks like (I think this is factory). I found it under the rear seat when cleaning. I don't know how it attached though, especially since my XJ has a factory hitch...
1990 XJ 2-door
Rack on the roof, rust on the floor, 31s on the wheels, and five speeds on the stick.....
irish44j is offline   Reply With Quote
Old 03-26-2008, 07:43 PM   #12
jshaab2
ill take it off your hands ?
Old 03-26-2008, 08:56 PM   #13
aircruiser
Moparrrrrrrr
aircruiser's Avatar
yeah just get a hitch. im upgrading to jcr bumpers so ive got mine off right now. it works when you need it to and i always trusted mine even though i only used it twice.
-2001 Dodge Dakota Quad Cab 4x4 - 4.7 V8, the new hotness!
-1997 Jeep Grand Cherokee Limited - 4.0, 4" lift, 33s, bilstiens, IRO stuff, FOR SALE
-1999 Jeep Cherokee Sport 2 door - 4.0, 8" lift, 35" KM2s, IRO stuff, Long Armed, Armored, Rolled, Parted
aircruiser is online now   Reply With Quote
Old 03-26-2008, 09:03 PM   #14
hoopdyxj
1997 XJ Cherokee
i have a rear class 3 hitch $50 plus shipping its 9 months old
hoopdyxj is offline   Reply With Quote
Old 03-26-2008, 09:04 PM   #15
itasor
2009 JK Wrangler
Yup, that's what I have. The bolt holes parallel to the hook (2 holes) are attached with a nut strip inside the frame rail. The other bolt attaches with a nut. I don't think you can use it with a hitch, but that would be unnecessary anyway. Someone probably threw it under the seat when they got the hitch installed.
Glock Forum
