XJ Rear Hatch Dome Light Switch Repair - JeepForum.com
post #1 of 11 Old 02-24-2013, 08:59 AM Thread Starter
M35A2
1995 XJ Cherokee
I had an issue where the rear dome light would turn on with all the doors except for the rear hatch. I did notice there was a button on the rear dome light but it didn't do anything. I took the light apart and found the switch melted; turns out that is another little issue XJs have. After I fixed the switch by installing a new rocker switch in place of the burnt up one, I figured all was good 'cause the switch now turned the lights on/off when the hatch was open.
A few weeks later, we were out foolin' around in the dez, and all of a sudden the dome lights came on by themselves then went off, then came on and stayed on. I flipped the switch I had installed and the lights went out. Hmmm sumpin aint right. The following weekend I decided to try and locate a door switch for the hatch. The wiring diagram shows one, but doesn't state WHERE it is. I was figuring it likely a mercury tilt switch, but it ends up that the switch is in the gate where the latch is. If I stuffed my finger up in the hole, I could make the dome light flicker.
WTH, got nuthin' better to do, so I started taking things apart. Turns out it's pretty simple to fix and after fixing it and visiting the local junk...err, auto recycling yards and looking at the multitude of XJs there, this seems to be a very common problem. After the fix, your dome lights will come on with the hatch opening and you will be able to leave the hatch open and turn the lights off.
Tools needed;
Torx driver, vice, needle nose pliers, punch, drill and 3/16 bit, small ballpeen, small wire brush, piece of emery cloth, rivet gun with a short 3/16 rivet, your favorite adult beverage.
First thing to do is to make sure the switch works on the rear dome light. If it does, continue on, if not fix that first. Use a DVOM to check the switch operation. Resistance readings across the switch contacts should show an open circuit (OL), or a closed circuit (.002 ohms or so), based on position of switch.
After that, remove the panel on the hatch. I won't go into detail on that.
Disconnect the latch rod and use the torx driver to remove the cover plate and latch. You'll need to unplug the wires as you remove the latch as there's not enough room for one of them to be removed with the latch in place.
Volunteer, American Society of Military History. http://tankland.com/
Just got a 1989 YJ too!
M35A2 is offline
post #2 of 11 Old 02-24-2013, 09:06 AM Thread Starter
M35A2
1995 XJ Cherokee
Here's the latch removed. The switch is not located correctly, there is a slot on the latch plate and a tab on the switch. The switch is bent out from the latch plate AND the switch plunger is bent.
switch bent and not located right.jpg   switch bent on latch.jpg   switch plunger.jpg
M35A2 is offline
post #3 of 11 Old 02-24-2013, 09:08 AM Thread Starter
M35A2
1995 XJ Cherokee
Use a 3/16 drill bit and remove the switch from the latch plate. In pic 2 and 3 you can see the locating slot that the tab on the switch goes into. Use the punch to knock out the rest of the rivet.
drill out old mount rivit.jpg   switch removed1.jpg   switch removed.jpg   remove old rivit.jpg
M35A2 is offline
post #4 of 11 Old 02-24-2013, 09:21 AM Thread Starter
M35A2
1995 XJ Cherokee
Here is the removed switch. You can see it is bent in two places; one at the spot that it affixed to the latch plate, and also at the plunger and its fixed contact on the isolated tab. Put the switch in the vice, use the small hammer to straighten the mount and the plunger, do the plunger carefully. Use the wire brush and emery cloth to clean the contact areas. This switch is a ground completion switch, meaning it completes the lighting ground circuit to allow current flow through the bulb. Use the DVOM to check for a good closed and open circuit.
bent at mount hole.jpg   bent switch.jpg   straight contacts.jpg   colsed circuit.jpg   open circuit.jpg
M35A2 is offline
post #5 of 11 Old 02-24-2013, 09:29 AM Thread Starter
M35A2
1995 XJ Cherokee
Re-attach the newly refurbished switch onto the latch plate with the 3/16 rivet. I used a steel one and think an aluminum one might not withstand the stresses. Make sure you get the switch tab in its mounting plate slot. I also peened the protruding rivit over just 'cause I wanted to. Re-install the latch reversing the order removed, don't forget to plug the wires onto the switch BEFORE installing it. Re-assemble your hatch as needed. Your dome light should now come on when the hatch is opened and you should also be able to turn the light off with the hatch open with the switch on the rear dome light.
M35A2 is offline
post #6 of 11 Old 02-24-2013, 09:45 AM
AZ Jeff
2014 JK Wrangler
Nice work. This is another quirky weak link in XJ that can be fixed with some patience and skill. Thanks for posting the pictures.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #7 of 11 Old 02-26-2013, 05:09 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
With the OP's permission I went back and put a little polish on things here in order to help in understanding for anyone who's just getting ready to take on this repair. If you still have questions, feel free to respond post and I have a feeling M35A2 might be able to help you out.
I love these type of threads because they embody the essence of forums, in that with a little direction from someone like themselves that just went through it, anyone with a few simple hand tools and willingness to try can often easily fix problems for themselves that shops might charge hundreds of dollars for. Fix-it threads such as this one that address inherent model specific weaknesses are particularly prime material.
I'll be working on putting together a Cherokee Technical section sticky index for threads of this nature in order to make locating good information a little easier when needed. Please help me evalute the worthiness of this and similar threads for inclusion in a sticky index by posting a smilie in the thread whenever you find any information therein helpful and of value worth preservation.
I encourage anyone else interested in putting together a Fix-It thread to share with your jeepin family to go ahead and give it your best shot. Feel free to PM me a link if you want to make sure it doesn't slip past me. I'll also be happy to review any previous efforts along this line for possibly including in the Cherokee Fix-It index sticky.
***Chris***
chris87xj is online now
post #8 of 11 Old 04-19-2013, 08:12 PM
CherokeeTamer
1991 XJ Cherokee
Awesome writeup, the metal plunger was bent on mine and a quick fix with pliers was all it took, hope itll last. otherwise i may have to heat treat the steel to harden it a bit. imo should be a sticky lol.
CherokeeTamer is offline
post #9 of 11 Old 04-19-2013, 09:14 PM
bangarang
1981 CJ8
Nice write up, definitely gonna have to dive into this one at some point.
bangarang is offline
post #10 of 11 Old 04-20-2013, 11:19 AM
Rob K
1995 XJ Cherokee
Nice write up for a common problem. The switch is pretty crude and exposed to the elements so the metal will oxidize or corrode again unless you apply some dielectric(non-conductive) grease on the electrical contact areas after cleaning them. It's been quite a few years since I fixed mine and it is still working well, luckily all I had to do was clean the switch contact points.
Rob K is offline
post #11 of 11 Old 11-25-2013, 03:01 PM
worthington27
Very nice write up
worthington27 is offline
cherokee , dome light , fix , repair , switch , xj
