XJ Rear D60 Swap Questions - Page 3 - JeepForum.com
post #31 of 45 Old 01-24-2013, 12:09 PM Thread Starter
fedx95
1993 XJ Cherokee
I would pay that as well, that's cheap
fedx95 is offline
post #32 of 45 Old 01-25-2013, 08:26 PM
ZeroGravity
Originally Posted by fedx95 View Post
Yup. I was reading up on ways of shortening a driveshaft. So far all looks good except for cutting the tube perfectly square. I'm not sure how i will be able to do that.
They Yoke has a small lip that fits into the drive shaft tube. Grind off the weld
And remove the yoke, cut the tube to length, then put the yoke back in and weld it up. I did this with a XJ front driveshaft for my wrangler, never had it balanced, and I have no vibrations.
$75 is outrageous.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #33 of 45 Old 01-26-2013, 04:35 AM
Timo_90xj
Timo_90xj's Avatar
What are your plans for unibody reinforcement if you haven't already done it? Without doing at least frame stiffeners from the front horns back to forward leaf spring pockets, you're looking at separating unibody pinch welds/ cracking the unibody in multiple areas. As stock, the XJ unibody will not handle the loads and stresses caused by full width axle swap.
With the 36s and D60s coupled with long arms, you've added a whole lot of unsprung weight and also leverage due to wider track width and heavier tires. I wheeled my Xj for a couple years with stock width axles and 35s without frame stiffeneres and I had multiple cracks on it. This has happened to a lot of guys.
If you haven't done any research on this or haven't burned in frame stiffeners, search on pirate4x4's Cherokee- section. Some info on this site as well (ie. look for EricXJ build thread).
***Under construction***
Timo_90xj is online now
post #34 of 45 Old 01-26-2013, 07:34 AM Thread Starter
fedx95
1993 XJ Cherokee
Not sure what approach I'm going to take with that. More research. I'm thinking rocksliders burned to the frame at a minimum. The long arm crossmember that I have will reduce frame flex a bit. Note sure what else
fedx95 is offline
post #35 of 45 Old 01-26-2013, 09:14 AM
ibjeepin95
Like Timo said. If you don't do frame stiffeners, you're wasting your time. Burning in frame stiffeners into your thin frame isn't going to do *****.
ibjeepin95 is offline
post #36 of 45 Old 01-26-2013, 11:23 AM
Climbit
Huh?
Climbit is offline
post #37 of 45 Old 01-26-2013, 11:37 AM
ZeroGravity
If you just weld plates over your frame,you will still have the same problems with spot welds separating form the body itself. You should use frame stiffeners in conjunction with outriggers that tie into the body. Speaking a priori; for example, frame stiffeners with rock sliders that are welded the the body (between the frame and rocker panel) and frame, as well as having the sliders welded to the pinch seam. Or you could cut out the rockers and weld in some rectangular tube for a more integral slider. I would also install a crossmember for a transfer case skid and cross members front and rear where the stock bumpers are.
91 YJ
98 XJ
2 door love
post #38 of 45 Old 01-26-2013, 01:14 PM
Timo_90xj
Timo_90xj's Avatar
This.
Also, cage is not a 100% but recommended. Once you go bigger, you gotta do quite a few things to do it the right way. Most important really = frame stiffeners + box steel rockers + connecting those together.
post #39 of 45 Old 01-26-2013, 09:27 PM Thread Starter
fedx95
1993 XJ Cherokee
You think if I ran a few stock crossmembers welded down the body, sliders burned at the frame and the rocker at the pinch seam, as well as the mega long arm crossmember I'll be good?
I like integrating the slider into the rocker but I don't know if I have those skills.
Anyways, waiting for the perches to ship in. $35 from a local shop.
fedx95 is offline
post #40 of 45 Old 01-26-2013, 10:52 PM
Climbit
Just buy the set from Hd OffRoad engineering. Don't **** with anything else.
Climbit is offline
post #41 of 45 Old 02-24-2013, 10:53 PM Thread Starter
fedx95
1993 XJ Cherokee
Rear 60 has been on. Need to find a brake line, driveshaft has to be made, and trim the rear fender to see how much I can lower the height from where its at. Been busy recently so haven't worked on it. I'm still looking for a junkyard priced front dana60.
Has 3" blocks for rolling purposes. Not sure what approach to take height wise.
fedx95 is offline
post #42 of 45 Old 02-25-2013, 12:13 AM
Climbit
height looks good actually, ditch the blocks, get some real leafs...
and WTF is that thing on your roof?
Climbit is offline
post #43 of 45 Old 02-25-2013, 10:52 AM Thread Starter
fedx95
1993 XJ Cherokee
It's a roofrack I picked up. I have to cut it up and weld it back to my dimensions, then paint it black lol.
I have the ram van 3500 leaf pack, I might get the main leaf from that. It will get my shackle angle right and give some lift. Otherwise I would need a full leaf pack. $$$
fedx95 is offline
post #44 of 45 Old 06-21-2013, 10:01 PM Thread Starter
fedx95
1993 XJ Cherokee
Update:
So it's back on stock leaf springs, with the dana 60. I bought a 1310 yoke ($40)and installed it. Then I shortened my original driveshaft to make up for the longer yoke.
Brakes: reflared the lines and bled all the brakes. Brakes work great now even with the stock MC.
It's on 31" tires. It's really, really fast. And it slides around anything with enough gas (great limited slip).
Downside: crazy wheel hop if hard on the gas. I need rear shocks. I only have one hooked up and it's bad.
fedx95 is offline
post #45 of 45 Old 06-21-2013, 10:03 PM Thread Starter
fedx95
1993 XJ Cherokee
Picture. 31s in the back and 30.5 in the front. The axle by itself gives around a 2" lift.
fedx95 is offline
d60 , dana 60 , full width , swap , xj
