XJ Overheats w/AC On - JeepForum.com
post #1 of 5 Old 08-08-2010, 05:44 PM Thread Starter
scouperacer1994
1995 XJ Cherokee
My XJ wants to overheat when the A/C is on. I Checked and both fans are going strong. I cant figure out why this would happen. Without the A/C on the temp is fine just a hair over 210. It realy sucks cause the A/C actually works pretty good, (for an XJ) but I still cant use it.
-1995 XJ Country, 4.5 Rusty's Springs and 1.75" spacers Front,4.5" leafs & 1.5"shackles, 33x12.5-15 BFG Mud Terrain T/A Locked and 4.10 geared D30/35
-1997 TJ Sport, 4" Procomp, RE Monotubes, 33x12.5/15 Goodyear Wrangler MT/R Locked and 4.10 geared D30/35.
Anything is possible if you don't know what you are talking about.
scouperacer1994 is offline
post #2 of 5 Old 08-08-2010, 05:51 PM
austin6137
1990 XJ Cherokee
Try the clutch fan. I replaced mine. and that solved my overheating with A/C on.
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #3 of 5 Old 08-08-2010, 05:53 PM Thread Starter
scouperacer1994
1995 XJ Cherokee
Thanks I'll chek into that.
post #4 of 5 Old 08-08-2010, 07:32 PM
tucan69
1990 XJ Cherokee
check the electric fan it should kick on when ever you turn the ac on if its not that could be a problem there
tucan69 is offline
post #5 of 5 Old 08-08-2010, 07:50 PM
mybuick
also look for dirt in the radiator and comdencer fins
mybuick is offline
overheats on highway only.....please help! Erbo XJ Cherokee Technical Forum 12 07-06-2012 06:11 PM
4.0 still overheats after new parts sterfry2004 XJ Cherokee Technical Forum 25 09-29-2009 11:33 PM
1996 Overheats - Help!!! Konz XJ Cherokee Technical Forum 9 07-19-2009 08:14 PM
4.0 Overheats Going Uphill theonlyraphael XJ Cherokee Technical Forum 6 07-10-2009 01:21 AM
XJ overheats only when kongpheng XJ Cherokee Technical Forum 13 09-05-2008 03:26 AM
