xj overheating - JeepForum.com
post #1 of 3 Old 01-24-2011, 02:49 PM Thread Starter
skimsurf
xj overheating
alright so here's what I did. my 96 xjs heater sucked. I flushed the core did away with the control valve and ran a bit of water through the pump thru the whole system to make sure it circulated. come to find out the problem was the vent on the blower. I zip tied it open and the heater worked great. the next day I started it waited for it to warm up and it didn't. it overheated. I changed both the water pump and the thermostat and ran the return line of the pump into the suction still overheats. it has plenty of coolant just kinda stuck. maybe the water froze somewhere? its been really cold where im at. any ideas? im gonna get at it wednesday im out of town now just need an idea here. help!
skimsurf is offline
post #2 of 3 Old 01-24-2011, 02:55 PM
adkjeepxj
There has got to be a blockage someplace, Did you burp the system after doing all this work, air in the system would produce these symptoms.
adkjeepxj is offline
post #3 of 3 Old 01-24-2011, 04:53 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Did you have a verified concentration of coolant to water?
Replace radiator cap if hasn't been done recently. A $5.00 investment that is often overlooked.
Radiator is in play here. Either frozen or faulty.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
Overheating!!!!! XJ-Obi XJ Cherokee Technical Forum 5 01-25-2010 05:31 PM
Overheating when really hot outside 95cherokee33s XJ Cherokee Technical Forum 7 08-19-2007 02:06 PM
Overheating? btfury XJ Cherokee Technical Forum 1 08-15-2007 07:48 AM
overheating 92 bigbluezj94 XJ Cherokee Technical Forum 1 08-12-2007 05:05 PM
overheating ChipsXJ XJ Cherokee Technical Forum 18 01-27-2006 10:33 PM
