-   -   XJ OEM factory front skidplate questions (http://www.jeepforum.com/forum/f11/xj-oem-factory-front-skidplate-questions-1507355/)
Charley3 04-10-2013 06:09 PM
I have read on Web that OEM front skidplate not very useful on XJ with 3"+ lift.
That implies it is useful on stock height XJ. Is it useful on stock height XJ?
Would it be useful on an XJ with 1" to 1.5" lift?
Rusty's also makes something called Front End Strenthener and Skidplate http://www.rustysoffroad.com/rustys-...kid-plate.html
See in pic on Rusty page. Not the bumper skid, but the skidplate below it. Would that be of any use? Looks like less coverage than stock front skid, but I'm not sure since Jeep in pic is lifted a lot.
Charley3 04-11-2013 03:40 PM
Humpily dumpily bump
Any ideas where I could buy an OEM front skidplate?
chris87xj 04-11-2013 09:36 PM
A lot of people pick them up from junkyards. I took mine off to derust and repaint but a year later haven't been able to bring myself to put it back on yet since it makes access, inspection, and maintenance much more difficult. I like the intended functionality but it's in my way far too frequently for what I get out of it.
Charley3 04-12-2013 02:13 AM
Junkyards are a major pain in my butt for several reasons. The main reason being the nearest good junkyard is a 1 hour drive. The second reason is they are U-pull it type, but I am to handicapped. So then I'd have to pay my cousin to go with me. Not cost effective.
Maybe I could pay the junkyard to remove, but all the JY are 1 hr to 1.5 hr drive. So still a lot of time.
Are there any more convenient places to buy one? Online places?
Charley3 04-12-2013 02:28 AM
Does this look like the OEM front skidplate?
http://www.quadratec.com/products/S-52018009.htm
This Mopar Overstock place is selling a new one for $10.27, if I understand their website correctly. But says for XJ years 87-90. My XJ is a 99. Edited in Later: No longer available from Mopar Overstock.
http://www.moparpartsoverstock.com/p.../82200613.html
Here's a new one for 84-96 for $165. But my XJ is 99.
http://www.discountjeepparts.com/pro...ducts_id/23817
They also have new OEM gas tank skids cheap for 96 and older. Might have some for 97 and newer.
chris87xj 04-12-2013 02:39 AM
Yes it does, very much so. Even down to the heat lines visible from welding the angle reinforcement on the backside
Charley3 04-12-2013 02:59 AM
I added a couple more possible sources to that post after you saw it. Please revisit post # 5.
I'm notorius for posting, then editing-adding the same post several times as I find more info.
Charley3 04-12-2013 03:03 AM
BTW - How much do you think it weighs? I ask because I'm figuring out what spring rate I want for front lift springs. I want to go soft as possible. Making a Jeepillac or a Jeep Deville.
Please see-revisit my prior two posts.
chris87xj 04-12-2013 03:05 AM
The Mopar overstock site price would be a dang good deal if it were later model. The XJ saw significant changes going into '91 and I can see differences in the skid on the Mopar exploded parts diagrams on their page, so I don't think it would be a direct fit onto your XJ. Not sure why they call it a Comanche skid if XJ/Comanche are interchangeable like I'm thinking.
Those exploded diagram views are great for finding every bolt and connector needed for the installation.
The Discount Jeep Parts link pic is the exact same picture as the Quadratec site.
chris87xj 04-12-2013 03:07 AM
I'm notorius for posting, then adding-editing the same post several times as I find more info.
Got it, no prob. See my previous post.
Originally Posted by Charley3 (Post 15284661)
BTW - How much do you think it weighs? I ask because I'm figuring out what spring rate I want for lift springs.
Just a wild swag on the weight and only because I recently moved it from where I hung it a year ago for the paint to cure, I'd say about 20-25lbs.
Charley3 04-12-2013 03:18 AM
You are a great help. Thanks.
Quadratec is only source I found (so far) that claims to fit a 99, but I am skeptical because Qtec claims it fits 84 to 01. Is that possible?
I suspect Qtec is selling the same skid as the MoparOverstock and DiscountJeepParts places, but maybe Qtec mistaken about which years it fits.
chris87xj 04-12-2013 03:36 AM
I have 1987, '88 and '96 XJ's so my intimate familiarity fades with the later models, but I'm sure someone will check in later this morning that knows.
When I go to the Mopar Overstock site and plug in specs for your XJ, it comes up with an appropriate exploded parts diagram but the option to add the front skid (part #1) to my cart isn't there. :dunno:
Charley3 04-12-2013 04:14 AM
Maybe the front skidplate wasn't made for XJs after 96?
rugsucka 04-12-2013 08:01 AM
I put a first gen front and gas skid from an '88 on my '00. The front skid bolts on in factory mounting locations with bolts and nuts - I used 3 on the cross member, 2 on the drivers side, and 1 on the passenger.
The first gen gas skid will also fit if you trim the back portion a few inches and notch the side there as well to fit the larger plastic tank. It also mounts is factory mounting locations.
Not much really changed in the unibody from start to finish.
Charley3 04-12-2013 01:43 PM
So an 87-90 front skidplate will fit my 99? That means I can buy a new front skidplate for $10.27 from MoparPartOverstock.com if I can figure out how to order from their website. I find it confusing.
The time now is 11:26 AM.
