XJ no start, code P1694, possible CPS or SKIM - Page 2 - JeepForum.com
post #16 of 20 Old 07-05-2010, 04:14 PM Thread Starter
XJMuscle98
Update: Changed CPS.
Still no start, however, if I crank it and then stop and it's on the ON position and I crank it again it was try to start to run to the point where I can give it a little throttle to try and get it to run but it just won't seem to.
I am at a lost here.
Anyone have any ideas?
I'm still getting the P1694 whenever I crank it on the first time, but on the second time there's no CEL.
I am currently using a new PCM from another Jeep.
1998 Jeep Cherokee 4.0L AW4/NP231 211k+
"Approximately 80 percent of our air pollution stems from hydrocarbons released by vegetation, so let's not go overboard in setting and enforcing tough emission standards from man-made sources."
Ronald Reagan
My goal is to have 20 lights around my XJ.
Currently: 10
XJMuscle98 is offline
post #17 of 20 Old 07-05-2010, 04:39 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by CJ7-Tim View Post
P1694 No CCD Messages Received From ECM. Bus communication failure to PCM.
P1694 is probably a short circuit or broken wire on one of the 5 volt sensors. Look for broken wires, loose or dirty connections, chafed or melted insulation, etc.
CJ7-Tim is offline
post #18 of 20 Old 07-05-2010, 05:25 PM Thread Starter
XJMuscle98
Yes, but why does it try to start?
Should I just place my assumptions on the CPS and just go ahead and hard wire it directly to the wire harness near the PCM?
Ronald Reagan
Currently: 10
post #19 of 20 Old 07-05-2010, 05:40 PM
CJ7-Tim
CJ7-Tim's Avatar
Does it cranks and crank or does it actual fire a few cylinders ? If it fires, use the gas pedal to get it started and keep it running. The ECU/PCM may have re-booted and deleted the idle settings. A 10 minute drive will let the ECU/PCM re-learn and then it will idle normally.
If you can't get rid of the P1694 you will have to physically inspect the wire harnesses for damage.
CJ7-Tim is offline
post #20 of 20 Old 07-05-2010, 05:48 PM Thread Starter
XJMuscle98
Well it'll crank and crank.
And then when I stop and restart then it'll start to try to run.
I think when I try to run it I'm just going to go WOT and try to get it to start and then once it starts it'll probably program everything within the PCM.
I just don't understand the cranking the first part time.
Ronald Reagan
Currently: 10
no , start , p1694 , cps , skim , cherokee
1998 4.0l cherokee P1694 (no bus) No Start 540itouring XJ Cherokee Technical Forum 16 09-24-2012 11:21 AM
99 XJ Won't start CEL P1694 detailed 69Restorod XJ Cherokee Technical Forum 2 06-06-2010 05:23 PM
Jeep Keeps Stalling and Shows Code P1694 PLEASE HELP cj11 XJ Cherokee Technical Forum 5 10-26-2009 10:04 AM
Accident with the Jeep now it wont start. Code P1694 Hella XJ Cherokee Technical Forum 3 01-18-2009 01:51 PM
problem code p1694, how do i fix it tonyv32 XJ Cherokee Technical Forum 0 10-03-2007 05:16 PM
