xj no fire from coil or fuel pump - JeepForum.com
post #1 of 6 Old 04-07-2009, 06:43 PM Thread Starter
chigger
1989 XJ Cherokee
I am purchasing a 89 xj limited from a friend I would like to here it run first it will turn over but will not start. We have tried two different coils and i can not find an ignition fuse. I was told that 89 was a black sheep year for some wiring in the ignitions and it is full of fusable links. I don't want to buy a p.o.s
he bought it and the seller told him he had previously had the trans out and that it ran ok but he never put the driveshafts back in it. I would like some helpful info on some thinks to check out like if theres any one thing that can shut power off to the coil and fuel pump. Thanks
chigger is offline
post #2 of 6 Old 04-07-2009, 08:17 PM
oldred89
1989 XJ Cherokee
there is a fuel pump ballast resistor on the drivers side inner fender. ceramic piece with two wires to it. if it is bad you wont get fire to the fuel pump. you can jump the wires together to test it. did you actually check if you were getting fire to the plugs or just changed coils?
ALWAYS SOMETHING
oldred89 is offline
post #3 of 6 Old 04-07-2009, 09:32 PM Thread Starter
chigger
1989 XJ Cherokee
yes we used a spark plug test light it did not work on either coil so we made sure the test light was good we tried it on one of our personal vehicles and it worked. I will try that so for i know where the fuel pump relay is now this ballast and the crankshaft sensor and the coolant sensor i am going back sat to try these thinks.
chigger is offline
post #4 of 6 Old 04-07-2009, 11:47 PM
ClarkXJ
Run a scan on the ECM and see if it's thrown any codes for a faulty crank or cam position sensor.
-Clark P.
2" BB, 4 hella 500 on front light bar, 15x8 rock crawlers, 31" BFG A/Ts, hi-lift, smittybilt receiver shackle.
ClarkXJ is offline
post #5 of 6 Old 04-08-2009, 10:47 AM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
Since you cannot pull codes on any 87-90 XJ, you need to look at either the ballast, fuel pump or CPS.
88XJSport is offline
post #6 of 6 Old 08-02-2009, 04:26 PM Thread Starter
chigger
1989 XJ Cherokee
Finally got my xj home and put the test light to it the coil has pwr but no power to fuel pump i bypass the ballast on driver side interfender still no fire I was told that ballast was for the ignition i have order a repair manual maybe that will help
chigger is offline
my cherokee has fire but no fire to the fuel pump billhunthunthun XJ Cherokee Technical Forum 3 12-27-2009 06:06 PM
new fuel pump, new CPS, still no fire omohundro XJ Cherokee Technical Forum 7 07-14-2009 06:10 PM
No Voltage at coil when cranking\recent fuel pump replacement KDools XJ Cherokee Technical Forum 0 03-03-2009 09:42 AM
No fire to coil? 96lt1z28 XJ Cherokee Technical Forum 6 12-28-2006 05:04 PM
ADVICE!!! Fuel Filter?Fuel Pump?Coil?HELP! ChaoticBastard XJ Cherokee Technical Forum 20 10-07-2005 06:47 PM
