XJ lift setups (read first post before replying!!!) - Page 28 - JeepForum.com
post #406 of 495 Old 02-09-2009, 09:18 PM
AuburnXJ
1993 XJ Cherokee
2001 Cherokee Limited
Rusty's 4.5" Full Leaf Lift on Icons w/ 265s
Same w/ 32x11.5s
1993 Cherokee
Rustys 6.5" Longarm kit on 33" TSLs
2001 Jeep Cherokee Limited - DD
4.5" Rusty's SA Kit-32x11.5 BFG AT-Super 44 w/ turndown-JKS Discos
1993 Jeep Cherokee - Trail Rig
6.5" Rusty's LA kit-33x12.5 TSL-Pacesetter Header w/Delta 40-JKS Discos-Tom Woods Driveshaft-Advanced Adapters SYE-Custom CAI
Coming This Summer: 44/9", 4 link rear, and 37s
AuburnXJ is offline
post #407 of 495 Old 02-14-2009, 05:21 PM
Pedro7
1999 XJ
Rustys 3" HD Full pack (actual about 4")
Rustys Shocks w/ Rustys BPE's
31X10.5 Goodyear MTRs
Cragar soft 8's 15x8, 3.75 BS
Notes: Kilby T-case/gas tank skid, doorless mod, JKS trackbar, Aussie Locker rear, some other things
KCCO
2013 WK2
Pedro7 is offline
post #408 of 495 Old 02-16-2009, 01:48 PM
phattysrt
98 vegas XJ
1998 XJ
Rough Country 3" spring pack lift w/ 1 inch front spacer and 1.5-2.0" adjustable shackle. Procomp MX6 shocks for a 5" lift. Procomp 31/10.50 all terrain tires on stock 15 inch rims with original backspacing. Front and rear swaybars still on. does not rub and no fender trimming at full flex. No SYE but has slight vibration at 71 mph.
phattysrt is offline
post #409 of 495 Old 02-20-2009, 02:27 PM
Crusher16
1991 XJ Cherokee
Year: 1991
Lift height: 2" Spacers up front and 1" lift shackles in rear
Shocks: Monroe Gas-Matics
Tire size: 30x9.5x15 BFG AT KOs
Wheel Size & backspacing: Stock 15x7 Honeycombs
Notes: Rear end is sagging from the shackles so actual lift is a little over an inch in the rear.
More pictures here.
Crusher16 is offline
post #410 of 495 Old 02-20-2009, 03:14 PM
lifted89xj
1989 MJ Comanche
rustys 3.5 lift
AR wagon wheels 15x8
Iron man 31x10.50x15
pro comp shocks
home made roof rack
pre runner bumper bar
Alpinestars Racing Ahead....
HOOD VENT/ LOUVER SALE Click Below
lifted89xj is offline
post #411 of 495 Old 02-22-2009, 08:24 PM
vx1kxj
1994 xj 5 speed
lift: 3" ROUGH COUNTRY FULL PACK KIT, rusty's control arms, skyjacker hydro 7000 shocks
tires: Smaller than stock 27" Bridgestone dueler apts (put on by PO) on Stock pizza wheels
I must admitt, these tires are very good in the snow though and would recommend them to anyone needing a DD tire!
00 xj clayton 3 link and yadda yadda yadda...
vx1kxj is offline
post #412 of 495 Old 02-23-2009, 09:04 AM
Determined2Rise
Year: 1996
Lift kit: Rough Country 4.5" lift Actual: a little over 5
Shocks: RC 4.5" Nitro 9000 upgrade shocks(could be better )
Tire size: 33x12.5 Super Swamper TSL Radials Actual: 32.8x12.70x15
Wheel size & backspacing: Pro Comp Rock Krawler Series 97 15x8 w/ 3.75 backspacing
Notes: Pretty bad rubbin only at full flex, rear sway bar removed, front disconnects. Hidden hitch
Future: C 4x4 Front Bumper with PreRunner bar, 4.56 gears, Tom Woods SYE and CV driveshaft, Rock sliders, etc Not necassarily in that order
Click Free?
http://i688.photobucket.com/albums/v...8/P1020357.jpg
Almost rolled STEEP hil to the left
http://i688.photobucket.com/albums/v...k/P1020401.jpg
I have that Jeep thing! Now it hurts when I pee.
Determined2Rise is offline
post #413 of 495 Old 02-23-2009, 09:10 AM
nrpalmer32
1987 XJ Cherokee
Click Free
Originally Posted by Determined2Rise View Post
Year: 1996
Shocks: RC 4.5" kit shocks (could be better )
Click Free?
nrpalmer32 is offline
post #414 of 495 Old 02-23-2009, 09:05 PM
qwikxr
Lift height - listed (actual): Rough Country 6.5" (6")
Shocks: Rough Country 9177/9178 (4-6" lift) Nitros
Tire size Listed (actual): Trail Cutter 33x12.50 (32.5 x 13.7)
Wheel Size & backspacing: Jeep Gambler 15x8 5.5" BS
Notes: Stock flares get chewed on from about 3/4 flex - onward. full flex rubs the front's top coil perch pretty good, as does flat, full lock rubs the LCAs. Full flex with slight turning makes the tire grab the flare at the rear, and the front fender bracing. I'll be trimming the front of the fender (lower brace and section behind bumper caps), as well as changing wheels to one with less BS. Also going to add Bushwackers. No SYE (yet) but run the long slipyoke. very minute vibes from 20-30mph. Rear sway removed, rear bumps MIA. Front sway disco'd, stop bumps.
Flat:
Flexed:
'96 XJ - 8" RC lift - 33x12.50s, IRO long-Arm, Rusty's leafs, Boomerangs, etc.
qwikxr is offline
post #415 of 495 Old 02-24-2009, 06:20 PM
blackwaterjeep
Year:1999
Lift height rusty's 3in but actual 3.6 front and rear
Shocks: rusty's 3in
Tire size: 31x10.5 sport king allterrains
Wheel Size & backspacing: cragar soft 8's 4.0 bs
Notes:added coil spring insulator up front to level it. rusty's adj trac bar. exteneded sway bar links. warrior front bumper. ( added in custom tabs that tie in the bumper further back on the frame. welded on bumper end and bolted to frame) also rhino lined the rocker panels fender plans and back bumper. got a 4ft fiberglass cb antenna with cb
len. black water 4wheelers
blackwaterjeep is offline
post #416 of 495 Old 02-27-2009, 07:17 PM
Stout95YJ
2" AAL+spacer
33x12.50 BFG MT's on 15x8 soft 8's 4" bS
lots of front trimming
Stout95YJ is offline
post #417 of 495 Old 02-28-2009, 05:00 PM
gorman
gorman's Avatar
Year: 2000
Lift height (actual): 6" (RE 4.5" coils with spacer and OME CS034RA leafs with extra leaf and RE boomerang shackles)
Shocks: Front OME N35L (long travel) Rear OME N36 (normal length with raised shock mountings on axle)
Tire size: 33" Goodyear MTRs
Wheel Size & backspacing: Cragar D windows 15x8 with 4" backspacing
Notes: ARB bumper end caps were trimmed to line up with Bushwackers - tires still rub the bumper ends slightly on full flex
2000 Cherokee Country 4.0l, AW4 auto, NP242, RE/OME 6" lift, OME N35L & N36 shocks on raised mounts, JKS Quicker Disconnects, RE SYE, RE CV driveshaft, 33" Maxxis Bighorns, Cragar D window 15x8 with 4" backspacing, ARB bumper, Hella Comet 550's, Warn M8000 winch, GME GX300 29mhz, custom rocksliders, Gearmax Mod 89 rear axle, HP D30 front axle with WJ knuckles, steering and brakes, 4.56 ratios
gorman is offline
post #418 of 495 Old 03-04-2009, 01:20 AM
v2xj
Year:1999
Lift height:6.5" Rough Country
Shocks: RC all around
Tire size :32" with tread= 33"
Wheel Size & backspacing:15x1
Heights 4x4
Black Jeep Society
v2xj is offline
post #419 of 495 Old 03-08-2009, 04:46 PM
AustinTexasXJ
1987 MJ Comanche
Year: 2001
Lift kit: Stock
Shocks: Stock
Tire size: 235 75 R15 Hankook AT
Wheel size & backspacing: Stock 15x7
Notes: soon to get 2" RE BB
<img src="http://i41.photobucket.com/albums/e251/vivalaskaters78/PIC-0615.jpg" border="0" alt="Photobucket">
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
AustinTexasXJ is offline
post #420 of 495 Old 03-09-2009, 05:20 AM
nrpalmer32
1987 XJ Cherokee
Click Free and fuctional link
Originally Posted by BMWalive View Post
Year: 2001
Lift kit: Stock
Shocks: Stock
Closed Thread
opinions on 2 lift setups MidNightXJ XJ Cherokee Technical Forum 12 09-25-2008 01:41 PM
Need some quick help with lift and tire setups... L8 APEKS XJ Cherokee Technical Forum 40 04-27-2007 09:31 PM
lift help! READ THIS ATX XJ XJ Cherokee Technical Forum 15 04-17-2005 12:48 AM
My final post please read :( irish man hoe XJ Cherokee Technical Forum 6 08-02-2003 07:51 PM
RE, Tomken, Rustys, $ky jacker, or combo???? - I read the old post. thegoofster XJ Cherokee Technical Forum 7 04-07-2003 09:30 PM
