Quantcast XJ lift setups (read first post before replying!!!) - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > XJ lift setups (read first post before replying!!!)
Closed Thread
Old 04-07-2004, 12:05 PM   #16
rocknerd
Lift: 3.5" RE super ride + 2" coil spacers up front, 2" blocks in the back. total: ~4.75 front & back.
Tires: 33x12.5 TSL's
Wheels: 15x8 Rock Crawlers. 4.5" bs
Engine Mods: 62mm throttle body spacer, custom air intake, flowmaster 40 series exhaust.
Quick discos
Body work: tin snip and hammer special.
This post has been edited by the moderator. Please refer to the beginning of this thread for rules.
rocknerd is offline
Old 05-10-2004, 11:09 PM   #17
EricsXJ
The Post man
EricsXJ's Avatar
Another old setup - see ericsxj.com for current specs
Here's my 2nd lift. The first one was RE4.5" with a small coil spacer. Specs:
Year: 2000
Lift height: listed - RE 5.5" kit actual - estimated 6.5". Because I kept my old RE1462 leaf packs that were already broken in, I replaced the RE shackle witha TeraFlex shackle which is about an inch taller.
Tire size: 33x12.50 MT/R's (actual diameter = 32.8")
Wheels: 15x8 Tech 1's with 4.5" backspace
Fenders: trimmed and the stock flares moved up
Notes: No flex pics yet, but tires will clear fenders. Tires rub the LCAs a little at full turn. Wishing I had a slightly wider stance with this set up. I'm going to keep these wheels however and if I do a hub conversion, that should move the tires out just enough to make me happy.
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline
Old 05-11-2004, 11:17 AM   #18
dm7297
1995 XJ Cherokee
my rig
see sig for specs
1995 Jeep Cherokee Country, 6.5" Long arm lift, front & rear arbs, 35" superswamper trxus m/t's 8.8, ridigco winch bumper, roof rack,
[b][URL=http://forum-fever.com/forum/]Forum-Fever A general discussion forum[/URL][/b]
Check it out.
dm7297 is offline
Old 05-12-2004, 11:21 AM   #19
joshsg
Year: 1990
Lift: RE 4.5 with full Leafs
Tires: 33x12.50 TrXus M/T
Wheels: Pro Comp Extreme Alloy 15x8
Notes: Iv'e started trimming the fenders some. Nothing too much, just the front and back corners. It still rubs a little but it's fixing itself. No T-case drop, no vibes, and no bumpstops.
'90 xj Laredo
15% tint all around
RE 4.5 and TrXus 33's
joshsg is offline
Old 05-14-2004, 09:54 PM   #20
silverxj2001
Year: 2001
Lift: Rustys 3" w/2" coil spacers front
Shocks: Rustys
Tires: 31x10.50 Dakota RVTs
Wheels: 15x8" Rockcrawlers w/3/75" BS
Notes: Heavy trimming front & rear, no rubbing anywhere at all
2001 2-door XJ prerunner
6.5" RE
33x10.5" BFG A/T KO
15x8" rockcrawlers w/3.75" bs
hannemann 6" bulge flat top fiberglass fenders
bilstein 11" travel 5150's
RE XD trackbar / frame mount
RE adj. LCA/UCA's
beard triple thick limit straps
rusty's steering box brace
truckfarm pre-runner bumper
intake / exhaust
procomp lighting
system... yada yada yada
[URL=http://www.cardomain.com/memberpage/437678/1]PICS OF MY XJ[/URL]
silverxj2001 is offline
Old 06-12-2004, 03:35 PM   #21
b(k)ill94xj
Year: 1994
Lift height 3.5 front 4.0 rear (rubicon express)
Shocks: skyjacker nitro shocks (for 3 to 5 inchs of lift)
Tire size 31" kumho Venture MT's
Wheel Size & backspacing: stock 15x7
there is minor fender rubbing at full flex from both the front and rear tires but nothing that has damaged anything yet. the tires rub LCA's at full lock. the shocks are to short they limit my flex. (you can see in thepicture were the tire is still off the ground)
Rocks bite hard, but trees just piss me off...
97 Wrangler sport - 2 inch RE BB - Teraflex adjustable trac bar - 3.73's d30 and d35 - 31x10.5 yokhama geolander's - 15X8 American Racing Outlaw 2 wheels 3.75 backspacing - JKS LCA skids - hella vision headlights - Alpine amp and 6.5 type S speakers
94 Cherokee Sport - 3.5 Rubicon Express Kit - RE adjustable trac bar- 31X10.5 Kumho Venture MT's - 15X8 Crager Soft 8 Class III Hidden Hitch - Hand Throttle - High flow cat w/ Delta Flow 40 muffler Transfer Case Skid Plate Removable Doors --SOLD :( :( i miss it so much
b(k)ill94xj is offline
Old 06-24-2004, 01:32 PM   #22
nfinkbe
Year: 2001
Lift height: listed - RE 3.5" kit actual - estimated 4.5".
Driveshaft: RE hack-n-tap with cv driveshaft
Tire size: 31x10.50 Kumho MT's
before
after
nfinkbe is offline
Old 06-25-2004, 04:30 PM   #23
Sterling90XJ
Year: 1990
Lift height: 6" Total - 4.5" Leafs, 1.5" Shackles / 3" Coils, ACOS
Driveshaft: AA SYE & Tom Woods CV Shaft
Tire size: 33x12.50x15 Goodyear MTR's
Wheels: 15x8 American Racing 136's (Venturas) 3.75" BS, 19mm offset
Front Fenders trimmed at line traced on top of stock flare. Flare relocated. Rear, slight trimming.
[B][I][COLOR=INDIGO]Username should now be SilverstoneXJ[/COLOR][/I][/B]
[B][COLOR=silver]'00 XJ 'Freedom Edition'
6" Lift and 33" MTRs[/COLOR][/B]
[COLOR=darkslateblue][URL=www.arcticoffroad.com]www.arcticoffroad.com[/URL] [/COLOR]
[url=http://www.cardomain.com/memberpage/637794]My Jeep Site[/url]
Sterling90XJ is offline
Old 07-08-2004, 01:51 PM   #24
tdwjeep
here's Johnny
Year: 2000
Lift height: RE 3.5 SuperRide - Actual 3.5 Front, 4.5 Rear
Shocks: DT 3000
Tire size: 31x10.50 R15 Kumho Venture MT
Wheel Size & backspacing: Factory
Notes: No rubbing - adding BB soon though.
TDWJeep
"Last time I checked, my name was Ron Burgundy! What's yours?" - Ron Burgundy
2000 Sport, 4 Door, RE 3.5 SR w/ 1" BB, RE H&T and RE DS, RE HD Track Bar, DT3000s, 31x10.50R15 Kumhos, KargoMaster Roof Rack, JKS Discos, JKS BPEs (rear), RRO BPEs (front), K&N FIPK, IPF Headlight Harness, Hidden Hitch, yada yada yada.
PICs @ Car Domain Pictures
tdwjeep is offline
Old 07-17-2004, 10:34 PM   #25
jasfro
Stock
After
3.5RE W/32x11.5
Jason
'89 Jeep Cherokee [color=white]White Jeep Club Member #1111[/color]
jasfro is offline
Old 07-21-2004, 01:10 PM   #26
redjeepguy
Year:92
Lift height (listed & actual):rusty's 4.5-gave 5.5 + longarms
Shocks: trailmaster ssv for 4" lift
Tire size (Listed & actual):33x12.50
Wheel Size & backspacing:15x8 with 3.5" backspacing
Notes:no sye was needed, integrated a 1" drop in the custom crossmember. rub on longarms at full steering lock, and bumpstopped up front to keep from rubbing.
Mark
current--93 zj limited-3"-31" bfg at's
former--92 xj-d44's-locked-36" TSL's-caged-rear 3 link
redjeepguy is offline
Old 07-28-2004, 03:17 PM   #27
homerscj7
RE 2" Lift
30" Cooper STT's
Trimmed front air dam
Tow Hooks and Skidz
[size=1]
The road to destruction is paved with good intentions[/size]
homerscj7 is offline
Old 08-10-2004, 10:34 AM   #28
blk2000xjc
Black Bear
Year: 2000
Lift kit: RE 5.5" XD w/ .75" coil spacer for bull bar, JKS discos
Shocks: Rancho 9000x
Tire size: 285 75 R15 Goodyear MT/Rs
Wheel size & backspacing: AEV Argent 16x8 4.7" BS
blk2000xjc is offline
Old 08-28-2004, 01:53 PM   #29
xjninja
Year: 2000 Cherokee Sport
Lift Kit: Rusty's 2" BB
Shocks: Stock
Tire Size: Stock on day of post, new 30x9.50x15 BFG A/T Tomorrow
Wheels: Stock
Before:
After: 2" BB
xjninja is offline
Old 08-29-2004, 05:59 PM   #30
atfrith
1990 Cherokee
Rusty's 3" AAL kit (4" rear, 3" front"
shocks: some blue monroe shocks (dunno the actual name or anything)
tires/wheels: stock
no vibes at all, but do have some death wobble.
90 Sport 2dr
4.0 L Straight 6
Auto Transmission (AW4)
Rusty's Air Tube and K&N Filter
Dynomax Cat-Back
Cobra 19Gtl CB Radio w/PA system
2 Cheapo Baja Driving Lights mounted on front bumper
3" Rusty Coils up front, 3.5" RE leaf springs in the rear
31" Dunlop Mud Rovers on 15x8 Cragar Soft 8's
[COLOR=red]Under 21 XJ CLUB member #9[/COLOR]
Hondas Are Like Tampons...Every Pu**y Has One
atfrith is offline
Closed Thread
Glock Forum
