XJ lift setups (read first post before replying!!!) - Page 17 - JeepForum.com
post #241 of 495 Old 02-07-2007, 09:19 PM
silvergreentj
silvergreentj's Avatar
my buddy jakes xj just finished
rockkrawler 8in (8.3 net)
37" maxxis comp. trepadors(37.1")
dana 44 front, yukon moly inners outers 5.13, detroit
dana 60 rear, chopped to fit, bored to 35 spline, detroit
some more goodies on there too just too lazy to list em all...
Slow Life-02TJ-35 Trepadors
98TJ-33 Mtzs
Low Life-87 slammed e30
silvergreentj is offline
post #242 of 495 Old 02-08-2007, 08:15 PM
Krazors001
2014 JK Wrangler
Year: 2001
Lift kit: Daystar 1 3/4" Coil Spring Spacers and 1" Rear Shackles
Shocks: Stock sizes
Tire size: 30x9.5 R15(Actual Height 29.5")
Wheel size & backspacing: ZJ Orvis Wheels 15x7 with 5.25" BS and 1.25" Wheel Spacers
Notes: No rubbing with swaybars connected
Krazors001 is offline
post #243 of 495 Old 02-09-2007, 11:28 PM
pig_pen7
1990 XJ
6.5 Inch Custom Long Arms, Fabtech Shocks, Currie HD Steering, RE HD Trackbar
33/12.5/r15 Baja Clam MTs on AR 15x8
D44 456's Detriot
Warn 6014
[/IMG]
[IMG][/IMG]
Surrey Jeep!
pig_pen7 is offline
post #244 of 495 Old 02-10-2007, 02:00 PM
sjd78
sjd78's Avatar
Originally Posted by pig_pen7
1990 XJ
D44 456's Detriot
Warn 6014
[/IMG]
[IMG][/IMG]
Here ya go!
1998 Cherokee XJ
AW4,NP231 W/SYE & CV Drive Shaft
D30 W/Detroit, Alloy's & 4.88's, D44 W/Detroit, Alloy's & 4.88's
35" BFG M/T's On 15x8 Soft 8's
5.5" T&T/RE Long Arm Lift, T&T Frame Stiffeners, JKS Sway Bar Dico's, RE Monotube's, T&T Steering Box Reinforcement, and much more!
sjd78 is offline
post #245 of 495 Old 02-17-2007, 11:50 AM
kmontemerlo
Kevin's XJ
Year: 1996
Lift height (listed & actual): RE 3.5" SF w/Full leaf packs; actual 4.25"
Shocks: OME shocks
Tire size (Listed & actual):Truxus MT 31 10.5 R15
Notes: No clearance issuses at all. I needed a 1" crossmember drop. That's all. Rides way better then stock.
Parked on flat ground
flexed on a stump in the yard
kmontemerlo is offline
post #246 of 495 Old 02-17-2007, 01:14 PM
Steamer98
Steamer98's Avatar
Originally Posted by kmontemerlo
Year: 1996
Shocks: OME shocks
Click free
98 XJ Limited
Stock XJ tire carrier for sale
Steamer98 is offline
post #247 of 495 Old 02-21-2007, 08:10 AM
RckRdyXJ
RckRdyXJ's Avatar
2005 WK
Here are some updated pics since xmas etc...
RE 5.5" x duty lift, home made front bumper, Surco Safari rack with Reverse lights and PIAA 520 front lights, K&N drop in filter, Rubicon Moab wheels with 295/75/16 BFG AT's. Detours Off Road Products rear bumper with tire carrier, Optima yellow top battery, Eclipse CD deck with Rockford Fosgate speakers, PowerAcoustic amp and 2 Kicker CVR 12" subs. Clear side markers and turn signals and custom tail lights from Revotec. Flowmaster series 40 welded exhaust and high flow cat, Doestch Tech 3000 shocks and bushwacker flares.
Getting 305/70/16 Cooper Discoverer STT's in the spring, For now 3:55's and rear limited slip in 8.25. (upgrading to 4:56 and No Slip rear) Building Rock rails in my welding class, Upgrading to JCR 1 ton steering and RE drop pitman arm with ome steering stabalizer, full skids by summer.
2005 WK Limited 4.7 V8, Custom CAI, Custom Exhaust, 08 Overland front end
2006 Jeep Liberty Sport 2.8L CRD
RckRdyXJ is offline
post #248 of 495 Old 02-21-2007, 03:25 PM
95ckee
my 99
here is my 99 xj. 5.5"rubicon express, 34x12.50x16 trxus mt, rubicon wheels with spidertrax 1.25" wheel spacers, edelbrock sdt muffler with magnaflow highflow cat, 3:55's for now but thinking about going 4:56 since i got the 8.25 rear and put a detroit in it with the auburn ected in front. oh yeah it also has the rustys knuckle to knuckle tie rod.
ok this pick it was sittin at 7.5". i took out the 2" spacers and blocks later.
here it is at 5.5". man does it steer alot better
95ckee is offline
post #249 of 495 Old 02-22-2007, 09:38 AM
KPS
2001, 6.5 RK LA, RE 4.5 leafs, Rockyroad shackles, 30/8.8(4.88's) 35x12.50x15 MT's
-05 LJ
KPS is offline
post #250 of 495 Old 02-22-2007, 10:48 AM
RuffedUpXJ
RuffedUpXJ's Avatar
1988 XJ Cherokee
here you go . Looking good bud
88 XJ Red
| 5" of lift | Custom Bumpers | Black Rockcrawlers with 35x12.50 BFG MT's | Custom Rock Rails | Homebrewed OBA | Custom Roof Rack Loaded | Tube Doors |
Play 4x4Country.
RuffedUpXJ is offline
post #251 of 495 Old 02-22-2007, 04:46 PM
BigOrangeXJ
BigOrangeXJ's Avatar
Year: 1988 Laredo (Maaco - "Hugger Orange")
Lift height: RE 3.5" w/ full packs, actual about 4.5" - 4.75"
Shocks: Rubicon shocks that came w/ lift
Tire size: 32" BFG Mud Terrains
Wheel Size & backspacing: 15x8 American Racing (not sure what series) and not sure of backspacing (bought used w/ tires)
Axle: d30/d44 w/ 3.55s (really not as bad as I thought - don't feel like I really need to regear)
Notes: Haven't bumpstopped yet, and only rubs flares at full lock. Will be trimming soon and raising stock flares while shortening them. Near future will bring more minor accents and painting trim pieces to look newer. Please note that no SYE or extended driveshaft was used and seems ok so far. The future (10-12 months) will bring a 4.6L stroker and possible going higher (way down the road) to 5.5" LA w/ 35's
BigOrangeXJ is offline
post #252 of 495 Old 02-26-2007, 05:16 PM
BigMike80
2001 XJ
Procomp 2" BB
30x9.5 Pirelli Scorpions on Black Steelies
Are you gonna bark all day, little doggie, or are you gonna bite?
-Mr. Blonde
Originally Posted by JPJeeper
Ok, so instead of putting something cool on your jeep, you are going to go stare at women? Isn't that what the Internet is for?
BigMike80 is offline
post #253 of 495 Old 02-27-2007, 03:50 PM
JeepxGuy24
RE 3.5" Super Flex AAL *measures 4.5" front and 4" rear
w/ RE Trac Bar, RE Twin Tube Shocks, OME Steering Stabilizer, No Rear Sway Bar
TC drop
31x10.5x15 BFG A/T, on 15x8 RockCrawler Series 97
DynoMax Exhuast
Hella 500's
Not Shown:
Tow hooks, Hitch, Warn D-Ring, Straps
CB Radio and 4ft fiberglass antenna
Sound system (Pioneer, Polk, JL Audio)
Python Security/Starter
K&N Air Intake
Soon to come:
SYE Kit
Window Tint
Rack and Full Spare
Other Sweet Stuff, Idk
1999 Jeep Cherokee
3.5" RE Super-Flex (AAL)
32x11.5x15 BFG M/T
K&N Air Intake / APN Header / Hella 500's
Python Security w/ Remote Starter / SkidRow TC Skid / 20% Tints
CB Radio, Pioneer Head Unit, Polk 5.25" (COUNTRY AND CLASSIC ROCK ONLY)
JeepxGuy24 is offline
post #254 of 495 Old 03-04-2007, 10:23 PM
JeepnTXJ
Update:
6.5" Rusty's long arm
Tomken HD rear .5" shackles
35x12.50 Dunlop Mud Rovers
30/8.8 3.73's factory rear posi
Level:
Flexed:
'83 CJ7. 258, T5, D300. D30, M20 1 pc. shafts
4" Skyjacker, 33x12.5.15 Nokian Vatiiva on wagon wheels.
JeepnTXJ is offline
post #255 of 495 Old 03-05-2007, 09:53 AM
altierior
Y2KXJ
altierior's Avatar
My Y2K XJ
Year: 2000
Lift height: 3" BDS, full leafs
Shocks: BDS Gas shocks
Tire size: 31" General Grabber AT2s
Wheel Size & backspacing: 15" with 3.25 backspace
Notes: BDS quick-disconnects
before:
currently (but still a work in progress):
altierior is offline
Closed Thread
opinions on 2 lift setups MidNightXJ XJ Cherokee Technical Forum 12 09-25-2008 12:41 PM
Need some quick help with lift and tire setups... L8 APEKS XJ Cherokee Technical Forum 40 04-27-2007 08:31 PM
lift help! READ THIS ATX XJ XJ Cherokee Technical Forum 15 04-16-2005 11:48 PM
My final post please read :( irish man hoe XJ Cherokee Technical Forum 6 08-02-2003 06:51 PM
RE, Tomken, Rustys, $ky jacker, or combo???? - I read the old post. thegoofster XJ Cherokee Technical Forum 7 04-07-2003 08:30 PM
