Xj lift and gearing help! - JeepForum.com
post #1 of 17 Old 05-11-2013, 07:47 PM Thread Starter
AM92
1992 XJ Cherokee
I want to lift my jeep and keep as a daily and wheeler.
92 jeep cherokee 4.0 HO
5 speed manual
rear axle is chrysler 8.25
does come with towing packing
175000 (miles)
my questions are what is a decent size lift and tires to run without regearing?
AM92 is offline
post #2 of 17 Old 05-11-2013, 09:00 PM
flexyxj
2009 XK Commander
2" and 30x9.50-15's would be max assuming you have 3:07 gears stock. IMHO
flexyxj is offline
post #3 of 17 Old 05-11-2013, 09:41 PM Thread Starter
AM92
1992 XJ Cherokee
Don't they come stock 3:73?
AM92 is offline
post #4 of 17 Old 05-11-2013, 09:58 PM
Muddy97Cherokee
1997 XJ Cherokee
You most likely have 3.07's. 3.73's only came with the tow and Upcountry package auto's.
Gearing
3.07 - used with 4.0L engine / manual transmission
3.31 - only available on older (pre87?) 2 door XJs with "Fuel Economy" package
3.55 - used with 4.0L engine / automatic transmission
3.73 - found in some XJs with the towing package
4.10 - used with 2.5L engine usually, and older XJs with the "Off-Highway Vehicle" package.
Onto your question. 3" would be great. its a great starting height and you only have to change a few things to lift it. And its one of the most economical kits available. Throw some 31's under it And you'll have a perfect DD and weekend warrior! You will lose power since your gearing is so low but you can change that by buying new gears and installing them. If you do not plan on regearing, which should be done anytime you install bigger tires, It would be hard to run 30's. 30's can easily at stock height but you won't have much flex. A simple budget boost would work with 30's but you would still lose power since you gearing is so low.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
post #5 of 17 Old 05-11-2013, 10:09 PM
flexyxj
2009 XK Commander
The difference between 235/75-15's and 30x9.50-15's will be minimal but noticeable on the highway or towing or in windy conditions.
flexyxj is offline
post #6 of 17 Old 05-11-2013, 10:57 PM Thread Starter
AM92
1992 XJ Cherokee
Ok I'm determined it is the 3:73 I have the towing package and there is alot of torque so what route would I have to take if I wanted to do 4 to 4.5 in
AM92 is offline
post #7 of 17 Old 05-11-2013, 11:00 PM Thread Starter
AM92
1992 XJ Cherokee
Gearing
Is it really to much work to buy gears and install them myself or have a shop do them?
AM92 is offline
post #8 of 17 Old 05-11-2013, 11:09 PM
flexyxj
2009 XK Commander
Just because you have a hitch doesn't mean you have a factory towing package with 3:73 gears. What size tires do you want to run? 31's or 32's would probably be OK with 3:73's. 33's or bigger and you would want 4:10's minimum and 4:56's would be better. You can figure about 500-700$ per axle to regear. If you have the skills,specialty tools and knowledge to do it yourself,you could do it for less. If I had to do it again, I'd do a 3.5in lift and run 31's or 32's and leave the stock gearing alone.My .02 worth....
flexyxj is offline
post #9 of 17 Old 05-11-2013, 11:18 PM Thread Starter
AM92
1992 XJ Cherokee
32's at the least is what Id like to run
AM92 is offline
post #10 of 17 Old 05-11-2013, 11:20 PM Thread Starter
AM92
1992 XJ Cherokee
Originally Posted by am92 View Post
32's at the least is what id like to run
32/10.5
AM92 is offline
post #11 of 17 Old 05-11-2013, 11:46 PM
flexyxj
2009 XK Commander
32's are 11.5 in wide. 3.5 - 4.5 in lift will work depending on what you intend on doing. Lift prices vary greatly and you get what you pay for. Do your research.
flexyxj is offline
post #12 of 17 Old 05-12-2013, 12:36 AM
Muddy97Cherokee
1997 XJ Cherokee
You have 3.07's. All manuals come with 3.07's that I know of. 3.73's only came with the up country package.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
post #13 of 17 Old 05-12-2013, 12:55 AM
Muddy97Cherokee
1997 XJ Cherokee
One you get up over 3.5 you are going to pay a considerable more amount of cash for kits. You start getting into territories that you don't want to mess with as a beginner also. If you have experience then why not. To fit 32's you will need at least 4" to clear without any kind of trimming. With less lift you will have to trim the fenders. 3" and 31's are perfect fit what you are wanting. Check out the non tech forum to look at lifts and tire set ups and also use Google. You will find that 3" is the main starting point for most xj owners.
And if you are wanting to run 32's, you will most definitely need to regear to gain all of your lost power back.
My $.02 is get a 3" kit and 31"s and see where you want to go with your jeep from there. You will also get a feel for what kind of gearing you will want if you want to go bigger. I am running 3.5" and 31's on stock 3.55 gearing and I have noticed a loss in power from the tire increase. I plan on lifting my jeep again and going to a bigger tire so 4.56 gears are in my future. Not saying that you need that low of gearing but you will get the feel of what you want. I am happy with what my jeep will go through but I have bigger plans and more difficult wheeling ahead of me.
Its your jeep and you can do what you want, we are just trying to get you to understand that lifting and gearing is a complicated business.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
post #14 of 17 Old 05-12-2013, 06:37 AM
flexyxj
2009 XK Commander
Lifting,bigger tires, and re-gearing can be very expensive and you can open a whole new can of worms like vibrations,alignment issues, and death wobble. if you have the mechanical ability and tools-go for it. If you're on a shoestring budget and are going to pay to have everything done-it will be very expensive. A 2" budget boost and tires with an alignment can be done fairly reasonable and without the issues I've described.....
flexyxj is offline
post #15 of 17 Old 05-12-2013, 10:31 AM Thread Starter
AM92
1992 XJ Cherokee
I have the budget boost Kit right now I like it but I want a little more lift I only spent 100.00 for the rear 2" blocks and front 2 in spacers in total
AM92 is offline
