XJ Idle issue! - JeepForum.com
post #1 of 3 Old 04-08-2008, 10:29 PM Thread Starter
Traxion
Xj XJ Idle issue!
My '97 XJ 4.0 (150k) has recently started lowering its idle for a few seconds after I stop when I put it in park or neutral. It drops for a few seconds but then comes right back up to normal. I have since gone over the PCV/CCV system including cleaning both tubes, replacing both grommets, and replacing the rear breather elbow/valve. There has been no change. I'm gonna check the IAC this afternoon I guess, but are there any other suggestions? What vacuum hoses should I check? Any help would be greatly appreciated!
Traxion is offline
post #2 of 3 Old 04-09-2008, 06:05 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
It's not an IAC issue, or it would be a continuous problem. Let me know what you find though, mine has been doing the same thing for a while now and I can't figure it out.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #3 of 3 Old 04-09-2008, 11:37 AM
hardlineoffroad
1990 XJ Cherokee
check your emmisions system for built up carbon....that was what was wrong with mine
SAVE TELLICO!!!!!!
May 22-25 HARDLINE OFFROAD CLUB TRAIL RIDE IN TELLICO. COME JOIN US...HOPEFULLY ITS NOT OUR LAST TRAIL RIDE IN TELLICO.
~"FIRE UP THE FLUX-CAPACITOR,MARTY!"
hardlineoffroad is offline
idle issue still Willy36 XJ Cherokee Technical Forum 8 01-03-2010 12:47 PM
Idle issue verbalkint99 XJ Cherokee Technical Forum 2 08-25-2009 02:32 PM
need help with fast idle issue pistilnoon XJ Cherokee Technical Forum 10 12-22-2008 06:00 AM
Another Comanche Issue. . . Idle 97_4popper XJ Cherokee Technical Forum 5 03-21-2006 06:22 AM
Another Comanche Issue. . . Idle 97_4popper MJ Comanche Technical Forum 3 03-21-2006 06:21 AM
