Xj help!!! - JeepForum.com
post #1 of 10 Old 08-18-2017, 07:28 PM Thread Starter
Xjlover24
Xj help!!!
Ok so I saved this xj after it sat for 10 years I just have lifted it done a bunch of work and took it around the block today and it will only go to about 35 mph no faster any ideas?
Xjlover24 is offline
post #2 of 10 Old 08-18-2017, 07:36 PM
Hank826
we need more info than that it it not shifting gears... is the gearing stock.... are the tires 45 in... how big is the lift....etc.etc.etc.
Hank826 is offline
post #3 of 10 Old 08-18-2017, 07:40 PM Thread Starter
Xjlover24
Sorry 4.5 inch lift 33 inch tire 355 gears and i actually didn't notice if it shifted or not but I believe it did shift
post #4 of 10 Old 08-19-2017, 02:30 AM
Timo_90xj
Timo_90xj's Avatar
Engine, transmission, year model?
There can be a number of reasons for that kind of behavior, but it depends on the drivetrain what all can cause it.
It's always worth checking the fault codes if it's '91 or newer.
***Under construction***
Timo_90xj is online now
post #5 of 10 Old 08-19-2017, 11:37 AM Thread Starter
Xjlover24
Its a 1988 renix motor 4.0 auto trans from what I have found in Google a lot seems to point to the tps sensor would I want to start there?
post #6 of 10 Old 08-20-2017, 04:21 PM
RLE
RLE's Avatar
Did it go more than 35 mph before the work?
What kind of work was done on the engine?
RLE is offline
post #7 of 10 Old 08-20-2017, 06:10 PM Thread Starter
Xjlover24
I'm not sure it sat on the side of a house for 13 years without moving so I have no idea what kind of work was done to the engine I haven't ever driven it yet this was the first ever test drive
post #8 of 10 Old 08-21-2017, 08:29 AM Thread Starter
Xjlover24
The only work I've done to the engine has been an oil change, plugs, wires,cap and rotor it also has a new brake booster/master cylinder new power steering pump all new brake stuff in the rear, could it be a vacuum leak? And if so what's the most common? I'm just at a stand still I'm thinking of buying a new tps tonight for it and see what happens
post #9 of 10 Old 08-21-2017, 09:57 AM
RLE
RLE's Avatar
Don't have a Renix, but this is the site that will tell you all about it.
www.cruiser54.com
RLE is offline
post #10 of 10 Old 08-21-2017, 12:19 PM Thread Starter
Xjlover24
Ok thank you!
