Quantcast xj front discs on a rear 8.25? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > xj front discs on a rear 8.25?
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 12-03-2005, 09:43 PM   #1
ktmracer419
1997 XJ Cherokee
well i have a couple parts xj's with almost brand new front brake setups. i would like to have rear discs in the back of my dd xj.
now everyone knows about using zj brakes, but do you think it would be possible to use an xj front disc setup on the rear axle? i know i'll have to do some home fabrication. But is there any reason this will not work/ would not be safe/will not be worth it?
and if it matters I have the chrysler 8.25.
thanks in advance
97 xj
44 front, detroit, alloyed
60 rear, detroit, 35 spline alloyed
35" beadlocked km2's
3" midarmed
more bells and whistles than you can shake a stick at
ktmracer419 is offline   Reply With Quote
Old 12-04-2005, 12:15 AM   #2
EricsXJ
The Post man
EricsXJ's Avatar
The number one reason it won't work is the backing plate needed to mount the calipers is totally different than the front steering knuckles.
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Old 12-04-2005, 11:24 AM   #3
twisted_ed
i would also worry about the fact that when you do the Zj conversion unless you change the proportioning valve the calipers in the rear don't get as much fluid as they should, and the front calipers need substantially more fluid as they are alot bigger so even with the zj proportioning valve i wonder if they would get enough fluid to actually make a difference in braking. id stick with the zj setup and use the extra time and skills and money to swap in a master cylinder and propoting valve off the same year zj you robbed the brake parts from that way you will essentially have zj brakes on an zj (since according to my dealership both zjs and xjz used the same brakes up front) and you will be laughing since zjs ive been in stop so will with 4 wheel discs and the cherokee should be lighter.. as well
1990 Jeep Cherokee Laredo
4.0L
Automatic Tranny
NP242 Transfer case
Dana 30 front, 35 custom rear differentials
Mods:
RE 4.5" Lift
32x11.50 BFGoodRich M/T KM's
American Eagle 058 Polished Aluminum Wheels, 3.63" BS.
Grand Cherokee Rear Disc Brake setup
Custom Downpipe W/ Cat Removed.
Dynomax Super Turbo Muffler.
Surco Roof Rack
My Jeep
twisted_ed is offline   Reply With Quote
Old 12-04-2005, 01:04 PM   #4
MGrobe
Man In Black
MGrobe's Avatar
Also you will be left without an emergency brake. All in all I doubt it would be worth it. Sell your parts to help pay for a much easier ZJ setup.
MGrobe is offline   Reply With Quote
Old 12-04-2005, 02:23 PM   #5
ktmracer419
1997 XJ Cherokee
i would like to find me a zj disc setup in good condition for not a ton of money. i'm just toying around with this idea, because i will be able to do it for cheap.
i think i will take a closer look at it once a warmer, less snowy day comes along
97 xj
3" midarmed
Old 12-04-2005, 02:26 PM   #6
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
If you have the tools to fabricate parts, you can adapt any disc setup to go onto your 8.25. It would be easier to get ZJ discs though. They bolt right on after you clearance the hole for the axle tube.
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? "
Roger Waters
Matt Gertsch is offline   Reply With Quote
Old 12-04-2005, 04:25 PM   #7
twisted_ed
like me you can get the crappyest looking bracket and dustsheild, it looked like crap all rusty and whatnot and others passed on it but it was the only parts available to me and once i sandblasted both the shield and brackets and painted them EXCEPT FOR THE MOUNTING SURFACES, you dont want to paint them they looked like new
4.0L
Automatic Tranny
NP242 Transfer case
Mods:
RE 4.5" Lift
Surco Roof Rack
My Jeep
Glock Forum
