XJ Flat Belly/ X member Build. Is it possible? Let's see.... - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > XJ Flat Belly/ X member Build. Is it possible? Let's see....
Ruffstuff XJ Unirail Channel Reinforcement....The Original 3/8" Ruffstuff Diff Cover!Gibson WK HEMI 3" Catback - 5 Day Special!
Unread 03-26-2013, 12:16 PM   #61
DeftwillP
Great job on the crossmember. Do you still have the dimensions from when you cut it out? How the hell did you get your bends so precise?
DeftwillP is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 09:29 AM   #62
Simmbad
1976 CJ7
Simmbad is offline   Reply With Quote Quick reply to this message
Unread 06-19-2013, 11:40 AM   #63
ibjeepin95
ibjeepin95's Avatar
Sorry dude! Just saw the post. I don't have the dimensions but I will be doing a revision soon so I can get them now. The bends were easy. Basically, I just notched it and threw it in a vise. Bent it by hand until I was happy.
Thanks!
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 07-13-2013, 05:26 AM   #64
YoureverydayXJ
So how do you feel about that trans mount now that you've run this for a while? I am debating still between this and the way SFRautomotive made his mounts. I'm thinking I should get it as low as possible being at 4.5" (and maybe more someday).
'00 XJ not quite there..
'00 XJ parts donor, '98 XJ body donor
YoureverydayXJ is offline   Reply With Quote Quick reply to this message
Unread 07-13-2013, 05:45 AM   #65
Timo_90xj
Timo_90xj's Avatar
As low as possible Do you mean as high as possible? You really never want to drop the t-case, if you get driveline problems it's a caster- and pinon angle issue, not a TC being too high
Flat belly is the way to go
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
Timo_90xj is offline   Reply With Quote Quick reply to this message
Unread 07-13-2013, 06:21 AM   #66
YoureverydayXJ
Yes, down as in transfer case to crossmember relation. It won't be dropped really, since the new crossmember is actually pushing it up from stock location. I was just wondering if he has had any issues with his mount that way.
Haha I've got all kinds of current angle problems, trust me.
Unread 07-14-2013, 12:28 PM   #67
ibjeepin95
ibjeepin95's Avatar
I have had issues with the trans mount being as high as it was. Actually, yesterday I have started another round of mods to the cross member. Stay tuned for pics of my flat cross member V2.0
Unread 07-14-2013, 01:07 PM   #68
YoureverydayXJ
I'm in! Should be picking up steel to start mine this week!
Unread 07-14-2013, 02:56 PM   #69
ibjeepin95
ibjeepin95's Avatar
Cool! It's a lot if work, but well worth it if you can get it right. I think I may have to clock my t case this time though.
Unread 07-15-2013, 07:06 AM   #70
CobraMarty
Your idea inspired us for this for our 4" lowered street jeep, 'becauseracejeep'. Gained like 2" of ground clearance. It is 2WD auto.
1998 XJ 2D auto 4.0 160k Red Grey+Blk Si seats 32" MTR 4.5" RC Lift- full leaf Adj U+L Arm RE track bar JKS Disco SYE F+R Hitch SOLID Covers JCR Slider+Skid Plate Magnaflow TruckLites, 150rwHP/174rwTQ=>Sprintex S/C 6 lbs BOOST 7th Injector NO CEL'S 211rwhp/274rwtq 100-140* IAT's==>Now 12 lb BOOST! JeepM62superchargerkit.blogspot.com
CobraMarty is online now   Reply With Quote Quick reply to this message
Unread 07-15-2013, 07:25 AM   #71
ibjeepin95
ibjeepin95's Avatar
Awesome! Street Jeeps are cool too! Any pics?
Unread 07-16-2013, 01:38 PM   #72
CobraMarty
For Street Jeep- Lots of Pics
CLICK HERE
Unread 08-13-2013, 10:20 AM   #73
ibjeepin95
ibjeepin95's Avatar
So I finally put that IRO jig to good use and clocked the base. Trying to fix the contact of the fan to the pulleys, I hacked the ***** out of the skid (no pics of that yet) and will beef it up a little too. Hopefully I'll have it complete this Friday.
Cut that useless piece off the case...
Unread 03-07-2014, 09:07 AM   #74
VegasGT
Rustler of Jimmies
VegasGT's Avatar
I have got to do everything in this thread lol.
- '99 XJ Sport -
Lifted, Locked, Stiffened
July '13 and '14 COTM
- '88 MJ Pioneer -
Build In Progress
- '04 Sierra Z71 Crew Cab -
Daily/TowPig
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 09-04-2014, 07:25 AM   #75
jeeplesjeeper
BUMP?! what's going on with dis
-Jake
-98XJ 6.5lift w/ 33's and stuff-R.I.P
-Current- A Green Stock 98'
jeeplesjeeper is offline   Reply With Quote Quick reply to this message
