XJ Flat Belly/ X member Build. Is it possible? Let's see.... - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > XJ Flat Belly/ X member Build. Is it possible? Let's see....
ORS4x4: New Product!Aluminum Quick Release Fire Extinguisher Mounts from ORS4xKinetic Recovery Rope from ORS4x4
Unread 01-08-2013, 07:40 PM   #31
BriansCJ
1994 XJ Cherokee
Thanks. I was hoping it would be something besides a pain in the d!ck. Sounds like fun
Whats really a pain is when they break and your leaf spring nuts snap off in the same day.
Hopefully I'll be doing something similar soon.
5 Speed XJ Build - Daily Driver & Weekend Wheeler
1978 CJ5 Resto, w/ heavy mods - Slow
BriansCJ is offline   Reply With Quote Quick reply to this message
Unread 01-08-2013, 08:16 PM   #32
DoctorTim
did you already drill out the holes on the trans? i wanna see how this is done. might do it myself but without the jig.
http://www.jeepforum.com/forum/f11/96-xj-build-hybrid-1311863/
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline   Reply With Quote Quick reply to this message
Unread 01-08-2013, 09:08 PM   #33
ibjeepin95
Not yet. I'll be doing this last.
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 01-09-2013, 10:03 AM   #34
jeepnatv4life
did u use any wd-40 or pb or anti seize on the bolt? hand tools arent gonna be able to pull the bolt back out a quick zip with an impact may save u from a loose nutsert and a bolt stuck in it. Here at the shop with some fasteners u can get away with putting bolts with nuts in a bind and a quick hit with an impact will loosen it.
I your nutsert is shot which is very likely you dont have much options besides opening up the inside of ur frame to get a wrench on it or cutting it out from the bottom......
XJ 35's locked Gas Tank in the Trunk Shox Hoops in the rear.
'13 RZR 570
jeepnatv4life is offline   Reply With Quote Quick reply to this message
Unread 01-09-2013, 11:24 AM   #35
ibjeepin95
Like I said, this sounds fun. I'm pulling the stock cross member back off tomorrow to finish up the new one. I'll see what's up with it then....
Unread 01-09-2013, 08:43 PM   #36
SaxManClay
Subscribed. This actually looks like a viable solution to not buying one.
SaxManClay is offline   Reply With Quote Quick reply to this message
Unread 01-09-2013, 09:34 PM   #37
ibjeepin95
Yup, and you won't get a flat belly anyway else.
Unread 01-09-2013, 10:55 PM   #38
aircruiser
Unless you do 40 sit-ups a day on a strict diet :P
aircruiser is offline   Reply With Quote Quick reply to this message
Unread 01-10-2013, 07:41 AM   #39
haloperformance
1991 XJ Cherokee
This looks great. I was looking at the beefed up stock replacement, but this looks Like a good alternative
1991 XJ: 35"s, 4:56s 5.5"LA lift, stretched, locked, skids, caged, high steer, spray paint. I think it was stock at one point.
<-1978 CJ5 parts - click on my classified
haloperformance is offline   Reply With Quote Quick reply to this message
Unread 01-10-2013, 09:47 PM   #40
ibjeepin95
No pics, but I took Alex's advice, welded the nuts to the studs, and twisted them out. Also, I enlarged the slots to fit the bolts better. Hopefully, I finish this heavy bastard up this weekend....
Unread 01-11-2013, 09:50 AM   #41
ibjeepin95
Originally Posted by CTeunuch View Post
Sack up and build a 44. Then wish you built a 60. Wanna buy a built 44?
Hahahaha. 44/9" is something I'm always thinking about.
Unread 01-13-2013, 06:10 PM   #42
ibjeepin95
UPDATEZ!
Bent the sides to "hug" the frame....
Bolted up...
Painted...
Now I need to clock the case. I'll probably start on that Thursday. Also, I plan to build a transfer case skid and a trans skid off the x member very soon out of 2" square tube and 3/16" plate.
Unread 01-20-2013, 12:04 AM   #43
ibjeepin95
ERMAGHERRD this skid is a pig....
Unread 01-20-2013, 12:06 AM   #44
alexrule123
Looks good but my god how much does that thing weight!?
2001 Cherokee Limited: My Build Thread
2005 Pontiac GTO 6.0L (DD)
May 2013 COTM
alexrule123 is offline   Reply With Quote Quick reply to this message
Unread 01-20-2013, 12:18 AM   #45
ibjeepin95
I don't want to know lol. But it's not as bad as I thought. My buddy had a flat skid in his TJ, which is basically just a big piece of plate and it weighs 60 pounds. I can't imagine mine being much more if not any more than that. I'm ditching the wet carpet so it will off set it lol. Plus, as long as I keep the heavy weight low, it doesn't bother me as bad...
