XJ Flat Belly/ X member Build. Is it possible? Let's see.... - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > XJ Flat Belly/ X member Build. Is it possible? Let's see....
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 01-07-2013, 10:56 AM   #16
Timo_90xj
Timo_90xj's Avatar
Kinda thinking the same way Swap in a D44?
I'd do that, if there weren't the stupid laws here in Finland that prevents me from deleting abs- brakes and running wider track axles..
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
Timo_90xj is offline   Reply With Quote Quick reply to this message
Unread 01-07-2013, 11:25 AM   #17
ibjeepin95
I'm so stuck on the fence on this.I'm a college student so I don't make all kinds of money. I keep telling myself to stay on 35's until I'm done with school. If I did a 44 swap, I'd then want a 9" or 60 and 37's, do a mid arm 3link, blah blah blah.........
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 01-07-2013, 11:36 AM   #18
Luke95
Do you have the cash $$$ for 37 and a set of axles? Or to break stuff? If not stay on 35s
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is offline   Reply With Quote Quick reply to this message
Unread 01-07-2013, 12:15 PM   #19
ibjeepin95
I'll stay on 35's until I'm done with school. I can afford 30 and 8.25 parts all day long.
Unread 01-07-2013, 12:33 PM   #20
Luke95
My thoughts exactly! I'd father have a 8.8 it's cheap I really want a 70 or 14b on 37s but I can't afford it
Unread 01-07-2013, 12:39 PM   #21
Timo_90xj
Timo_90xj's Avatar
14b and it's parts are actually fairly cheap, but fitting under the XJ is another thing - and that's even more so with HP D60 fronts
Unread 01-07-2013, 05:15 PM   #22
ibjeepin95
The thing is, I have no desire to run over 37's/38's.
Unread 01-07-2013, 05:43 PM   #23
Timo_90xj
Timo_90xj's Avatar
Yeap.. for those a D44 + D60 or a D60 + 14b combo would be perfect, depending on available power under the hood and/ or driving style.
Until that, keep the 30 and run 35s with not-so-heavy-pedal I had 35s on my XJ with 4.88s, stock shafts (large u-joints) for a couple years and I wasn't too easy on it - yet I never managed to break even a u-joint. My ARB and R&P took a dump on me, but that was because of a casting failure on the ARB and was covered by warranty. D30 actually holds up suprisingly well under an XJ even with 35s as long as you don't do anything overly stupid, like heavy landings at full throttle after launching over a rock ledge Then again, I've broken three shafts on my ZJ niner, I guess the V8 power is a bit too much for the poor turdy.. they were CVs though, let's see how well AlloyUSA cromo- shafts can take the grunt. I'm seeing tooth-fairy paying a visit at the R&P in the future
edit: But enough of the BS about this stuff, let's get back to your original subject of the thread, flat belly on the XJ
Unread 01-07-2013, 06:30 PM   #24
1990JEEPXJ
1990 XJ Cherokee
I will be watching this thread closely. Better not let me down
My POS
1990JEEPXJ is offline   Reply With Quote Quick reply to this message
Unread 01-07-2013, 06:41 PM   #25
ibjeepin95
I won't dude! Hopefully I'll get a little work done between classes tomorrow.
Unread 01-08-2013, 07:20 PM   #26
ibjeepin95
Started back to school today but between classes I got some work done on the cross member. First off, it fits and all the bolt holes line up....
Then I cut some access slots to the trans mount bolts. No, they aren't perfectly square, but it's going to get thrashed on so who cares? I took one of the pieces of metal I cut out and welded it across the slots on the inside for a little added strength...
Here is a pic of the whole cross member...
So I slapped another stock cross member (not bent up one) on so I could get it out of the garage. Tightening up the bolts, one of the bolts just spins in the frame. Did I break a nutsert? What do I do with that?
Unread 01-08-2013, 07:28 PM   #27
BriansCJ
1994 XJ Cherokee
2 options IMO
1. Cut a hole in the side of the frame for new bolts. Not the best idea. It was done on my previous XJ.
2. Cut out both bolts(stud and nut), weld 2 nuts to a piece of 1/8 and weld in place of the old ones.
5 Speed XJ Build - Daily Driver & Weekend Wheeler
1978 CJ5 Resto, w/ heavy mods - Slow
BriansCJ is offline   Reply With Quote Quick reply to this message
Unread 01-08-2013, 07:33 PM   #28
ibjeepin95
Originally Posted by BriansCJ View Post
2 options IMO
Thanks. I was hoping it would be something besides a pain in the d!ck. Sounds like fun
Unread 01-08-2013, 07:38 PM   #29
aircruiser
Pain in the dick indeed, welds broke, you know how it goes
aircruiser is offline   Reply With Quote Quick reply to this message
Unread 01-08-2013, 07:40 PM   #30
CTeunuch
I've thrown this idea around a good bit. I just can't justify putting that much work into a Dana 30!
Sack up and build a 44. Then wish you built a 60. Wanna buy a built 44?
I vote weld some 1/2x13 nuts to a piece of plate, and add a few more while you're add it. I'd say 3 or 4 per side, overkill is always better.
Think Twice Garage
"Yeah, that might work, pass me the grinder..."
94ZJ AX15/HP44/8.8/5.13's/35'' MTZ's SOLD
99XJ 4.0/AW4/HP30/8.25 build coming soon...
www.undergroundjeeps.net
CTeunuch is offline   Reply With Quote Quick reply to this message
