XJ Flat Belly/ X member Build. Is it possible? Let's see.... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > XJ Flat Belly/ X member Build. Is it possible? Let's see....
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 01-05-2013, 08:39 PM   #1
ibjeepin95
Well, thought I'd do a build on this separate from my XJ build. For those who don't know, my XJ is on about 3" of lift and 35's. I wheel my XJ in big pointy rocks that love to rip on anything they can on the bottom of my rig. I love the low stance of my heep and it works well, but it has it's drawbacks. EVERYTHING under my XJ has been taken into consideration because of it's low height. When you are this low, you rub and drag on rocks a lot. Is this a bad thing? Well, if you have the right armor and have clearanced everything that should be, then no. However, I have left one of the most important items untouched and it's way overdue for a replacement. This would obviously be my cross member. The factory X member is weak and hangs below the frame rails. At the same time, the bottom portion of the transfer case also hangs below the frame rails. This holds me up. Some how, I have yet to have exploded my transfer case. In the wheeling trips I have had this year, I have managed to turn the factory X member into an upside down U shape, which actually lifted my transfer case above the frame rails. Still, the cross member hangs too low. In this next pic, I was denied from getting to the top of this rock, even after repeatedly slamming into it trying to bounce and slide the cross member over the rock....
So, where does this leave me? It leaves me wanting a completely-flat -to-the-frame-rails-cross member, one that is strong, and wanting my transfer case completely out of the way. So first, out with the old....
To do this cross member, I got a clocking jig
and some 2x6 3/16 wall
So after doing some measuring, finding the center, and how much material should be shoved up between the frame rails, I came up with this....
Using the center point, I kinda (yes, kinda) figured where the trans mount should go. I drilled holes and got this....
And this is where I leave you hangin' til I get some more work done!
ibjeepin95 is offline   Reply With Quote Quick reply to this message
Unread 01-05-2013, 10:24 PM   #2
YoureverydayXJ
Nice work! Can't wait to see how your plan turns out, I've got to do something for mine.
'00 XJ parts donor, '98 XJ body donor
YoureverydayXJ is offline   Reply With Quote Quick reply to this message
Unread 01-06-2013, 03:35 AM   #3
Timo_90xj
Timo_90xj's Avatar
What are you gonna do with the exhaust? Run a more compact- sized cat and muffler? It's pretty damn tight fight to get a muffler and cat tucked into a flat belly without cutting the floorboards.. Flat belly, low stance and large tires is the way to go IMO so you're on the right track
I'm guessing you don't even need to notch the tranny x-member for front DS with the clocked TC? How are you going to mount this thing, weld in an extra support plate to the "ears" and add vertical mounts with crush sleeves through the unibody? Sure looks like a good starting point
http://www.jeepforum.com/forum/f13/d...s-etc-1222317/
***Under construction***
Timo_90xj is offline   Reply With Quote Quick reply to this message
Unread 01-06-2013, 06:36 AM   #4
ibjeepin95
The exhaust actually is going to work I think. My exhaust has already self clearanced itself into my floor board. If it is too tight, I'll massage the floor or notch the crossmember. As far as mounting, for the time being I'm going to use the stock mounting holes just to get it on there. As you can see, the metal sticks out long that the frame rails are. I'm going to fold that metal up around the frame to "hug" it and then run mounting points through the frame. I'm sure the bottom factory bolts won't last long!
Unread 01-06-2013, 07:01 AM   #5
Project1
I like that : ) .. while your there... should put some long arms on : )
Project1 is offline   Reply With Quote Quick reply to this message
Unread 01-06-2013, 08:56 AM   #6
Luke95
No.
Resident XJ lowlife. 35 general reds on 3inches of lift.
Luke95 is online now   Reply With Quote Quick reply to this message
Unread 01-06-2013, 09:20 AM   #7
rugsucka
You should rent that jig out when you're done. 5 bucks to your paypal and mail it to the next guy.
I've seen a thread where a reamer just travels around from one person to the next for people going to 1T TRE.
I've thought about clocking my t-case if I decide to pull it for my SYE, but 45 bucks for a jig I could make for myself seems spendy.
I have an old stock x-member that looks close to yours.
rugsucka is offline   Reply With Quote Quick reply to this message
Unread 01-06-2013, 09:36 AM   #8
Timo_90xj
Timo_90xj's Avatar
Should work that way..
If I may suggest, you might want to use 10mm countersunk hex-head bolts (class 10.9 or 12.9 so they are hard stuff), then weld another 3/16 plate to the bottom of the "ears" and drill large enough holes where the mounting bolts go through - so large that the head just goes through the hole as well.
This way you will have countersunk bolts, and the additional 3/16" plate both gives you added strength on the key area, and also gives you just that much clearance over the bolt heads so they don't get smashed to rocks as easily. I did the x-member on my ZJ this way, and I've scraped the heck out of it on rocks and so far zero marks on the bolt heads
Unread 01-06-2013, 11:25 AM   #9
ibjeepin95
Thanks. No long arms on this XJ. I can make short arms work just as well. I'll also have more clearance and making what I'd want (mid arm 3 link) is way more work than I want to put into it right now.
Thanks dude!
Is it legal to be a jig pimp?
That sounds like a great idea! The studs in the frame, do they just twist out? I didn't want to try it to find out I couldn't put another bolt in there.
Unread 01-06-2013, 11:44 AM   #10
YoureverydayXJ
I'm sure you've seen these type of things before, but it's an alternative to the 3/8s plate idea. Plate would probably be cheaper anyway.
http://www.ballisticfabrication.com...sp?itemid=1684
Unread 01-06-2013, 03:13 PM   #11
alexrule123
Don't let the man keep you down!
Yes the twist out, the double nut technique works very well.... wait, what? Also, if you look in front of the factory cross member mounts there is a sleeved hole on each side, you can tap that and use that for a 3rd bolt to hold the cross member on.
2001 Cherokee Limited: My Build Thread
2005 Pontiac GTO 6.0L (DD)
May 2013 COTM
alexrule123 is offline   Reply With Quote Quick reply to this message
Unread 01-06-2013, 08:38 PM   #12
ibjeepin95
Actually, I have never seen those! Might actually order a few....
Thanks man. Good info. I'll replace those studs with new bolts.
I got a little more work done. I didn't get any pics but I will this week. I slotted holes for the factory mounting locations and all but got the X member completely under the XJ. I think I need to do a little more trimming on the middle boxed part.
Unread 01-07-2013, 07:21 AM   #13
Project1
3 links are really nice for sure
Unread 01-07-2013, 08:39 AM   #14
Timo_90xj
Timo_90xj's Avatar
I've been thinking about the idea of fabbing high clearance axle brackets, that way the lower arms would basically be flat up to around 3" of lift or so.. With a little extended wheelbase and adjustable arms that should work ok.
There are a couple issues though; you'd need to rebuild the upper mounts as well, basically needing to fab a truss (possible fitment issues at full bump). Another problem is the added leverage because of the mounts being fairly far behind axle centerline. Then again, with OTK steering and flat arms the on- road handling should be great, and axle articulation + obstacle climbing abilities when wheeling really good as well.
3- link mid arms or long arms would be great, but they sure are a lot of work.. but so would be high clearance brackets
Unread 01-07-2013, 10:41 AM   #15
ibjeepin95
I've thrown this idea around a good bit. I just can't justify putting that much work into a Dana 30!
