XJ Flat Belly/ X member Build. Is it possible? Let's see.... - Page 3 - JeepForum.com
post #31 of 77 Old 01-08-2013, 06:40 PM
BriansCJ
1994 XJ Cherokee
Thanks. I was hoping it would be something besides a pain in the d!ck. Sounds like fun
Whats really a pain is when they break and your leaf spring nuts snap off in the same day.
Hopefully I'll be doing something similar soon.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #32 of 77 Old 01-08-2013, 07:16 PM
DoctorTim
did you already drill out the holes on the trans? i wanna see how this is done. might do it myself but without the jig.
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #33 of 77 Old 01-08-2013, 08:08 PM Thread Starter
ibjeepin95
Not yet. I'll be doing this last.
ibjeepin95 is offline
post #34 of 77 Old 01-09-2013, 09:03 AM
jeepnatv4life
did u use any wd-40 or pb or anti seize on the bolt? hand tools arent gonna be able to pull the bolt back out a quick zip with an impact may save u from a loose nutsert and a bolt stuck in it. Here at the shop with some fasteners u can get away with putting bolts with nuts in a bind and a quick hit with an impact will loosen it.
I your nutsert is shot which is very likely you dont have much options besides opening up the inside of ur frame to get a wrench on it or cutting it out from the bottom......
XJ 35's locked Gas Tank in the Trunk Shox Hoops in the rear.
'13 RZR 570
jeepnatv4life is offline
post #35 of 77 Old 01-09-2013, 10:24 AM Thread Starter
ibjeepin95
Like I said, this sounds fun. I'm pulling the stock cross member back off tomorrow to finish up the new one. I'll see what's up with it then....
post #36 of 77 Old 01-09-2013, 07:43 PM
SaxManClay
Subscribed. This actually looks like a viable solution to not buying one.
My Jeeps name is TUG!
What I'm all about.
SaxManClay is offline
post #37 of 77 Old 01-09-2013, 08:34 PM Thread Starter
ibjeepin95
Yup, and you won't get a flat belly anyway else.
post #38 of 77 Old 01-09-2013, 09:55 PM
aircruiser
aircruiser's Avatar
Unless you do 40 sit-ups a day on a strict diet :P
aircruiser is offline
post #39 of 77 Old 01-10-2013, 06:41 AM
haloperformance
1991 XJ Cherokee
This looks great. I was looking at the beefed up stock replacement, but this looks Like a good alternative
91 XJ: 35"s, 4:56s 5"LA lift 3"stretch, locked, skids, cage, high steer, spray paint.
98 XJ: Stock
haloperformance is offline
post #40 of 77 Old 01-10-2013, 08:47 PM Thread Starter
ibjeepin95
No pics, but I took Alex's advice, welded the nuts to the studs, and twisted them out. Also, I enlarged the slots to fit the bolts better. Hopefully, I finish this heavy bastard up this weekend....
post #41 of 77 Old 01-11-2013, 08:50 AM Thread Starter
ibjeepin95
Originally Posted by CTeunuch View Post
Sack up and build a 44. Then wish you built a 60. Wanna buy a built 44?
Hahahaha. 44/9" is something I'm always thinking about.
post #42 of 77 Old 01-13-2013, 05:10 PM Thread Starter
ibjeepin95
UPDATEZ!
Bent the sides to "hug" the frame....
Bolted up...
Painted...
Now I need to clock the case. I'll probably start on that Thursday. Also, I plan to build a transfer case skid and a trans skid off the x member very soon out of 2" square tube and 3/16" plate.
post #43 of 77 Old 01-19-2013, 11:04 PM Thread Starter
ibjeepin95
ERMAGHERRD this skid is a pig....
post #44 of 77 Old 01-19-2013, 11:06 PM
alexrule123
alexrule123's Avatar
Looks good but my god how much does that thing weight!?
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #45 of 77 Old 01-19-2013, 11:18 PM Thread Starter
ibjeepin95
I don't want to know lol. But it's not as bad as I thought. My buddy had a flat skid in his TJ, which is basically just a big piece of plate and it weighs 60 pounds. I can't imagine mine being much more if not any more than that. I'm ditching the wet carpet so it will off set it lol. Plus, as long as I keep the heavy weight low, it doesn't bother me as bad...
