xj exaust. - JeepForum.com
post #1 of 9 Old 02-26-2010, 08:18 PM Thread Starter
Telecaster31
xj exaust.
hey guys my cat on my 1996 jeep cherokee is rattling and stoped up. since there is no emmisions law where i live i was wanting to just take my cat off and add a new muffler in the place of the old one. i want a good deep sound that isnt crazy loud. what do you guys suggest?
Telecaster31 is offline
post #2 of 9 Old 02-26-2010, 08:20 PM
Holder350
1995 XJ Cherokee
Even tho there is no emission inspection in Tennessee it is still a federal offense to remove a converter on a vehicle that came with one from the factory.
As far as the muffler....I recommend the Thrush welded (looks like a flowmaster)
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 9 Old 02-26-2010, 08:59 PM
1stockjeep
1993 XJ Cherokee
Flow master super 40! Deep but not to loud inside! As for the cat I have been busted here in CA for modified emissions! Not good times. The judge took the fine off because it took me so long to find a ref because the budget cuts had em all closed! But definatley not worth the risk
1stockjeep is offline
post #4 of 9 Old 02-26-2010, 09:02 PM
Green4dr
i've heard that you want to keep your cat just to keep back pressure so you keep low end torque.
98 Green Cherokee Classic 4.0
3'' Rough Country II 33x12 bfg at
Spring Break Build thread/ makeover
http://www.jeepforum.com/forum/f22/98xj-classic-springbreak-makeover-1344754
Green4dr is offline
post #5 of 9 Old 02-26-2010, 09:17 PM
xjpete
1997 XJ Cherokee
And vehicle will run like crap with it removed.
xjpete is offline
post #6 of 9 Old 02-27-2010, 03:24 AM
01CHEEKEE
if you want deep sound....buy a V8...that's about the only advice i can give...
i have a welded thrush welded just after the cat w/ stock piping running to the rear of the xj...it is deeper at idle and up until 3k, after 3k you honestly can barely hear the rumble and at highway speeds you don't hear anything at all...you'd think it was a stock jeep...so i'd def reccomend it...
01CHEEKEE is offline
post #7 of 9 Old 02-27-2010, 05:11 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Leave the catalytic converter on. Illegal to remove and you'll have constant check engine lights with it removed.
You should be able to find a replacement for less than a hundred bucks.
Here is a link that might help.
http://www.jeepforum.com/forum/f11/t...-meows-976717/
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #8 of 9 Old 02-27-2010, 08:49 AM
wema628
just fyi. theres a recall on the cat. mine did the same thing i took it off punched it out put it back on and it runs fine. dont come to the nashville area cause there is an emmisions law and it has to be there. just call the dodge jeep dealer in your area about the recall
wema628 is offline
post #9 of 9 Old 02-27-2010, 10:56 AM Thread Starter
Telecaster31
thank you man. my friend was telling me they had a recall on my year model but i wasn't for sure.
cherokee , performance
Need NEw Exaust what should I get louisd11 XJ Cherokee Technical Forum 7 05-04-2007 07:26 AM
exaust xj&yjguy12 XJ Cherokee Technical Forum 3 01-26-2007 04:43 PM
New Exaust onlyinajeep07 XJ Cherokee Technical Forum 4 11-15-2004 06:34 PM
Best exaust set up??? monchichi8 XJ Cherokee Technical Forum 2 01-25-2004 01:28 PM
exaust ? 95sport XJ Cherokee Technical Forum 3 11-10-2003 02:26 PM
