XJ Cruise Control Wiring *HAVE DIAGRAM* Need Help - JeepForum.com
post #1 of 4 Old 01-22-2011, 05:14 PM Thread Starter
alexk243
1994 XJ Cherokee
Ok, I am trying to wire my 1994 XJ Cherokee with cruise control. Just picked up a servo from a junk yard for the cruise and all the wiring is there for it to hook up to and I verified that it is there on the PCM side as well. Now all I need to do is wire the control switches in and here lies the problem:
I want to make custom switches cause my model comes with the switches on the turn signal arm and I want toggles on the dash to control it. I have the wiring diagram I just cant decipher it.
This is what I got and I need to know what needs to be connected by a switch.
Wires:
"Coast/Set" = Brown/Red (To PCM)
"Resume/Accel" = White/Light Green (To PCM)
"unknown" = White (To F12 Splice)
"unknown" = Yellow/Red (To Harness under dash to Ignition on PCM)
Those are the four wires that go from the crusie switches on the turn signal arm to either the PCM, F12 Splice, or harness under the dash to PCM.
I have included the wiring diagrams for the speed control so you can check them out and see where I am.
I am stuck and not sure what I need to connect to the switch and what connection needs to be made when the switches are "on".
Oh and switch positions for the origional turn signal arm are as follows:
Set/Coast
Resume/Accelerate
Crusie On/Off
1994 Jeep Cherokee 4.0L
alexk243 is offline
post #2 of 4 Old 01-23-2011, 03:11 PM Thread Starter
alexk243
1994 XJ Cherokee
any ideas??? I am really stuck here
alexk243 is offline
post #3 of 4 Old 01-27-2011, 06:02 PM Thread Starter
alexk243
1994 XJ Cherokee
OK well I think I am pretty much talking to myself now lol, but I sat down with a few people and this diagram and I think we have it figured on how to make your own cruise control switches. I am in the process of getting a diagram. Let me know if you are also trying to do this. I would be happy to help.
alexk243 is offline
post #4 of 4 Old 06-20-2011, 08:06 AM
gaucho919
I need to add cruise control to my '92, I dont mine the turn signal switch, I found a cherokee at the junkyard with all the parts.. could you give me nay tips on how to do it?
"The journey is the destination"
gaucho919 is offline
cruise , cruise control , turn signal wiring , wiring , wiring connector
Cruise Control 1992 Wiring hanging down wont turn on Finaltheorem47 XJ Cherokee Technical Forum 5 09-06-2009 06:30 PM
Cruise Control not working...anyone have a CC Wiring Diagram?? j_dynomite XJ Cherokee Technical Forum 2 07-27-2009 07:27 PM
Cruise Control Wiring ID/ Pinouts JayIV XJ Cherokee Technical Forum 1 06-12-2006 11:27 PM
Need help: 1994 Cruise control wiring Mark_ZZ3 XJ Cherokee Technical Forum 2 03-26-2006 10:13 PM
96 wiring diagram/cruise control/horn electriczipper XJ Cherokee Technical Forum 3 07-27-2004 06:37 AM
