XJ Clutch fan replacement - JeepForum.com
post #1 of 12 Old 02-12-2013, 07:35 PM Thread Starter
Bmjames24
Okay so I've been doing a bit of driving in the jeep lately, I have an exhaust on my jeep, and it has come to my attention that I seriously hate the sound of the clutch fan being so loud that I can barely hear my exhaust. What I have set in mind is getting the electric fan/radiator combo. I have little to no knowledge on how much it takes to cool the jeep. I do know that the I6 4.0l HO likes to run hot (200). I absolutely hate the sound of the clutch fan. Please help me out guys give me some awesome knowledge!
Bmjames24 is offline
post #2 of 12 Old 02-12-2013, 07:38 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If it ain't broke, don't fix it.
CJ7-Tim is offline
post #3 of 12 Old 02-12-2013, 08:17 PM
Paradise XJ
1988 MJ Comanche
The e-fan swap is going to be noisier than a mechanical fan...all that on, off, on ,off. Then there's the CFM question. Is it enough, is the hype about plenty of air flow true...or?
So, you'd rather listen to your exhaust than a fan?? I have a ZJ HD fan on my XJ and my MJ and there are so many OTHER noises I don't even notice it. As far as airflow...it's a frikken hurricane under my hood. I've heard that the fan is noisy on some XJ's but...really?? I know I have exhaust...but I don't want to hear it...or ABOUT it.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #4 of 12 Old 02-12-2013, 09:18 PM Thread Starter
Bmjames24
I am a man of exhaust notes, what can i say. haha I just seriously hate the drowning noise from the clutch fan when it over powers the sound of my exhaust. I've had friends say that when i accelerate all they can hear is the clutch fan have a pretty loud exhaust. IDK maybe its just me being a young man but I seriously like my exhaust note.
post #5 of 12 Old 02-13-2013, 03:04 PM
lazyxj
You are not by any chance running a ZJ clutch?
Tried that and the constant noise drove me to remove it after only a couple of months, plus I saw a drop in freeway mileage.
The new XJ clutch, in comparison, only engages on hot summers day or on long climbs, the times you would expect it to.
You just might new a new clutch.
It's tough to beat the Factory cooling when it is operating correctly.
2001 Sport, 4" lift, 33 X 10.50 KOs, R.E. DB, R.E.-UCA, JKS-LCA, ACOS, 8.25-4.56-TruTrac, SYE, D-30 E-locker w/alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Lots of armor, Towing baseplate.
lazyxj is offline
post #6 of 12 Old 02-13-2013, 06:23 PM
Paradise XJ
1988 MJ Comanche
The fan clutch doesn't just suddenly "kick on". It operates on a percentage basis with RPM' s. It's always turning, just at a different rate.
post #7 of 12 Old 02-13-2013, 06:52 PM
djb383
If it's a stock XJ fan clutch in good condition and coolant temps are ok, constant fan roar ain't normal.
Man Law - hoods should be raised at least once a week.....have a look see.
djb383 is offline
post #8 of 12 Old 02-13-2013, 08:15 PM
Paradise XJ
1988 MJ Comanche
Mine never "roars", but, it's always turning. It's just turning faster when the engine is warmer. When it's up to temp it puts out more CFM than when cold. It puts out a @#&% load of air when hot, as I believe it's supposed to do.
It certainly doesn't drown out the sound of all the other noises going on. Maybe I need a glaspak or a cherry bomb. The chicks would love that. I may even get lucky.
post #9 of 12 Old 02-19-2013, 05:17 PM Thread Starter
Bmjames24
Right well I've done a bit of looking around and did a test to see if the clutch is bad on it. And in fact it is. I can easily spin it with my hand and it will turn not for long but say about 1/8 of a turn after a easy push. So now my question is should I go out and get a new clutch paired with new fan blades or should the fan blades not be an issue because they do not have such a great effect as the clutch itself. I've had a buddy in his Durango slap a new clutch on his and you can't even tell its there. (His sounded like a jet going down the road. You could easily hear it over his true dual exhaust)
post #10 of 12 Old 02-19-2013, 08:00 PM
jeepkid03
Winning
jeepkid03's Avatar
This. My fan only roars for a few seconds after just starting the jeep on a 100* day. Otherwise I don't notice it is there. I think a new clutch will solve your problem, you do not need new fan blades unless they are damaged.
BE AWARE:
The Autozone computer system is wrong. Any Cherokee after 1992 has the larger, louder ZJ clutch listed as the correct part. If you buy it from Autozone tell them you need one for a 1992 4.0L Cherokee in order to get the correct part. I told them they have the wrong one listed for 1993-2001 XJs but they didn't seem to care.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #11 of 12 Old 02-20-2013, 06:32 AM
Millermagic
What's wrong with the ZJ fan clutch? I can sit in a traffic jam on a 100* day with the A/C on full blast and not go above 210. Or, I can go wheeling on that same 100* day with the A/C on and not overheat.
Plus, the fan gives it character!
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #12 of 12 Old 02-20-2013, 11:03 AM
440_Magnum
Actually, it does pretty much "kick on" if its working right and is the correct, original equipment type XJ fan clutch. When it senses that the air temp is hot enough, it will gradually increase its coupling over a period of 5-10 seconds so that you DO, in effect, hear the fan "come on" as it starts to spin much faster as the clutch slips less. That's how it SHOULD work. Cheap aftermarket fan clutches without a thermal sensor work the way you describe. Just slipping about the same all the time, and varying with engine speed.
If you're hearing the fan ALL the time and its that loud, then I suspect someone swapped on one of the cheap parts-store "non-thermal" type clutches. They are ridiculously loud, and also make fuel economy much worse. I would not go all-electric. The beauty of the XJ cooling system, to me, is that it has both belt-driven and electric fans. Best of both worlds.
2011 Grand Cherokee Laredo 4x2, 3.6 Pentastar
1999 Cherokee 2door 4x4 5-speed (daughter's)
Two big-block Mopars, Challenger SRT8, and a Ram 1500
2001 Cherokee Sport automatic 4x2 (sold)
440_Magnum is offline
clutch fan , xj
