Xj CEL light on after changing all the fuses - JeepForum.com
post #1 of 3 Old 06-05-2014, 12:18 AM Thread Starter
Azxjeeper
I recently decided to change all the fuses on my xj in the fuse box in the passenger side panel. Inadvertantly I didnt disconnect my battery before doing this. I know, major mistake. After putting the fuses back, The check engine light came on. As a result my aux radiator fan is not engaging. I have replaced the fuse under the hood, and ran a bypass to check if the fan works and it does.however it does not come on when the temp gets to 210.it doesnt come on at all. What did I do to the ecm? im at a loss. Please help.
Azxjeeper is offline
post #2 of 3 Old 06-05-2014, 12:15 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I would suppose that you forgot to re-install a fuse, perhaps the one for the e-fan, or that the e-fan fuse blew.
To test the e-fan system, disconnect the wire plug from the Coolant temperature Sensor on the thermostat housing, if the e-fan starts up, everything is OK. The e-fan normally comes on at about 215-218*.
CJ7-Tim is offline
post #3 of 3 Old 06-05-2014, 01:32 PM
CCKen
CCKen's Avatar
#10 fuse in the JB is the one you want to look at. If you don't have a JB diagram, it's the 5th fuse up from the bottom, on the forward bank of fuses. A 15 Amp fuse.
CCKen is offline
cel , cooling issue , fan , radiator
