xj Brake upgrades - JeepForum.com
post #1 of 23 Old 07-05-2011, 11:26 AM Thread Starter
rlpetty43
xj Brake upgrades
I have seen it mentioned in several threads about swaping wj calipers and rotors into a xj. I cant speak for all wj's but my wj has a 5 on 5 bolt patern. are there only certain years or trim packages of wj that have 5 on 4.5? also are the calipers bolt on or is modification required I have tried searching for thread with some detail on this mod with no luck. thanks for any help in advance
rlpetty43 is offline
post #2 of 23 Old 07-05-2011, 12:54 PM
del94xj
1994 XJ Cherokee
Search wj knuckle swap you will find it
del94xj is offline
post #3 of 23 Old 07-05-2011, 01:04 PM
Holder350
1995 XJ Cherokee
99 was the change over from 4.5" to 5"
After you swap the knuckles the calipers, rotors, and other hardware is a direct fit to the new knuckles....and as long as you get knuckles from a 98 or earlier model the bolt pattern is the same
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #4 of 23 Old 07-05-2011, 03:50 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
but then a 98 and earlier wont be a WJ and thus would not be an upgrade. knuckles from a 99-04 grand cherokee are the ones to get. do a search and all of the info can be found. as for the bolt pattern, you retain your stock 5x4.5" with the swap since you use cherokee hubs.
1990JEEPXJ is offline
post #5 of 23 Old 07-05-2011, 03:57 PM
Holder350
1995 XJ Cherokee
Rotors would have to be stock then also....because the new rotors wont work with the original hubs.
post #6 of 23 Old 07-05-2011, 04:53 PM
newfieZJ
With the WJ set up , it goes like this .
WJ spindles
WJ ball joints
JKS spacer(need to be welded)
I think I used 2001 TJ wheel hub bearing (Ill have to confirm)
JKS tie rods
WJ TRE's
WJ double piston calipers
WJ rotors
OTK track bar may be required as well (I haven't "yet" but don't use it on the road)
My cost was very close to $1000 buying everything new but the spindles , but , it is the bomb
Only issue is some pitman arm TRE binding when flexing . I would use a ZJ pitman arm for sure (1" drop) on the XJ
I might have pics in my Orvis build
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #7 of 23 Old 07-05-2011, 05:30 PM
newfieZJ
If you want a cheaper option , do this (might have to regitster to see pics)
http://www.jeepsunlimited.com/forums...d.php?t=537460
newfieZJ is offline
post #8 of 23 Old 07-05-2011, 05:40 PM Thread Starter
rlpetty43
Thanks for all the useful information. can this been done as upgrade to the brakes without messing with the steering?
post #9 of 23 Old 07-05-2011, 05:56 PM Thread Starter
rlpetty43
WJ spindles
WJ ball joints
JKS tie rods
WJ TRE's
did you have the rotors machined or something? the wj rotors are a differant bolt pattern and will not fit a xj hub
post #10 of 23 Old 07-05-2011, 06:17 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
no they wouldnt. no offense, but have you read up on any of the WJ knuckle swaps?
you can redrill the WJ rotors yourself to the XJ bolt pattern.
nope, redrill them to the proper bolt pattern and go.
read this:
http://www.naxja.org/forum/showthrea...=913774&page=9
post #11 of 23 Old 07-05-2011, 07:04 PM Thread Starter
rlpetty43
thanks for the link that is most clear one I have seen thus far.
post #12 of 23 Old 07-05-2011, 07:52 PM
newfieZJ
Thanks , forgot to mention the rotors . Yes , I used WJ rotors and redrilled the bolt pattern
newfieZJ is offline
post #13 of 23 Old 07-06-2011, 07:49 AM
Holder350
1995 XJ Cherokee
I much prefer a setup where if I break something and need a new rotor to get home....I can get one from the kid at autozone.....and not try to find a machine shop open at 8pm
post #14 of 23 Old 07-06-2011, 08:01 AM Thread Starter
rlpetty43
i personally have never seen a rotor "brake" ,now I have seen them warp or get grooves in em from wore out pads. I have heard they can explode but I think that only happens if one neglects them. But Im sure it is possble I just have never seen it
post #15 of 23 Old 07-06-2011, 08:15 AM
Holder350
1995 XJ Cherokee
I have had rotors crack around the hub, to the point I did not feel safe with putting it back on....no matter how far I had to go.
If I were in a situation where I needed a new one quick (need to go to work, caliper locked up and runined a rotor on a trip to the beach.) I would much rather have off the shelf parts on such a critical system like the brakes.
Just my opinion.....plus I have had no issues with the stock setup, so I cant see upgrading where I have no issue.
Brake upgrades? jbarr2000 XJ/MJ Cherokee Non-Technical Forum 7 10-29-2009 10:44 AM
brake upgrades TwistedcaB- XJ Cherokee Technical Forum 10 08-27-2008 11:33 AM
brake upgrades Rowingfish87 XJ Cherokee Technical Forum 14 03-28-2008 09:29 PM
Brake Upgrades BigMike80 XJ Cherokee Technical Forum 11 02-10-2008 09:53 PM
Brake Upgrades rosader XJ Cherokee Technical Forum 12 12-06-2007 04:44 AM
