Quantcast XJ brake problems - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > XJ brake problems
Great deals on Mickey Thompson Tires @ Jeephut.comOfficial Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFG
Old 03-31-2009, 01:52 PM   #1
labbeJ92
1994 XJ Cherokee
XJ brake problems
i have a 94 XJ with abs. when im going even as slow as 10 mph and i hit the brakes like you would to stop not slamming on them i get a knocking noise from the front. could this be a time to bleed my system or is it something more significant
thanks
jon
labbeJ92 is offline   Reply With Quote
Old 03-31-2009, 02:23 PM   #2
JeremyXJ
Can you see your rotors through your wheels? Look for deep grooves or cracks in the face of your rotors. When was the last time you put new pads on it or bled the lines? How does it stop? Any squeaking? More info!
1996 XJ 4.0 4X4
JeremyXJ is offline   Reply With Quote
Old 03-31-2009, 10:26 PM   #3
labbeJ92
1994 XJ Cherokee
i havnt looked into it much because i was waiting for a direction to go in... lame i know but i was helping a friend out with his jeep most of the time so i havnt had a chance. i just recently bought it so i dont know when he had any of that sort of work done he told me but i dont remember. it stops fine infact perfectly exept the knocking noise is my only problem. quite as a mouse. i thinhk tomorrow im going to jack it up and pull the wheels off and see if anything is getting hung up or the such. it seems to be primarily on the left side idk if that helps you at all but let me know if you need more info
thanks
Old 04-08-2009, 10:00 PM   #4
KevinM90
sorry, i stuck a baseball card in your wheel when you werent looking.
1996 Jeep Cherokee Sport. 3" lift/31" combo. Some lights. Flowmaster. 5 different horns. Full size spare. No rust. Daily driven. Will be...forever.
KevinM90 is offline   Reply With Quote
Old 04-08-2009, 11:16 PM   #5
suprdave80
prob. your rotors, but you'll find out for sure when you pull the tires off and look at them
suprdave80 is offline   Reply With Quote
Glock Forum
