xj brake fuse problems - JeepForum.com
post #1 of 4 Old 03-12-2011, 03:55 PM Thread Starter
bortdoug
really odd light problem
i have a 1998 jeep xj. every time i hit the brakes my brake light fuse blows and there is a grinding sound coming from the rear hatch lock. but if i just hit the unlock button for the doors the brake lights go on and stay on as long as i hold the switch. is there a crossed wire? bad lock switch in the back? please help
bortdoug is offline
post #2 of 4 Old 03-12-2011, 05:07 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
You have a short circuit somewhere. The blown fuses and the sounds from the hatch are your proof. You will have to use a volts/ohms multimeter to check the wires or physically inspect the wires for chafed/burnt insulation, pinched/cut wires, or any other faults that would cause a short circuit.
If you have a trailer light adapter, removing that would be my first step.
CJ7-Tim is offline
post #3 of 4 Old 03-12-2011, 05:56 PM Thread Starter
bortdoug
not the trailer adaptor. any other spots you can think of would really help. im really lost when it comes to chasing wires.
bortdoug is offline
post #4 of 4 Old 03-12-2011, 11:58 PM
BrunoS
Most likely an internal "shorted to ground" dual filament brake lamp bulb. it would be the upper rear bulb in the back housing of our xj's.
The brake light/brake pedal switch/dash lamps are all on same circuit.
When you step on the brake pedal, a failed rear light that has the dual filament has a wire inside burned out and touching ground in the socket holding the bulb.
The current bypasses the bulb completely (or sometimes causes it to glow really bright) and is blowing your fuse since the fuse is suddenly seeing a huge rush of current.
Simply take a 10mm socket and remove the tail lamp housings and change BOTH left and right rear dual filament brake/stop bulbs.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
fuse problems wehr31 XJ Cherokee Technical Forum 1 01-20-2010 07:15 PM
96 XJ blowing 20A PDC brake fuse. Boomhauer XJ Cherokee Technical Forum 3 08-22-2009 11:42 AM
Elec problems fuse box pics maddzz XJ Cherokee Technical Forum 3 05-17-2009 12:21 PM
Fuse problems smoker9000 XJ Cherokee Technical Forum 2 10-13-2007 10:30 PM
Brake Problems on 87-Brake Booster? tyytyy22 XJ Cherokee Technical Forum 2 01-30-2006 11:36 AM
