XJ Blower Motor Resistor? - JeepForum.com
post #1 of 7 Old 05-11-2006, 01:09 PM Thread Starter
imtommorello
i need a new blower motor resistor. i called the stealership just to see ho wmuch they have it for. they hold the resistors ransom for about 42 bucks.
does anyone know of another place that may have them for cheaper, or have them at all?
i think ive heard Napa, but the dude that works there told me he only has the entire motor.
i want to use my ac again...=(
2000 Jeep Cherokee Sport
6 Cylinder Inline
As stock as they come =)
imtommorello is offline
post #2 of 7 Old 05-11-2006, 01:22 PM
russkrs
russkrs's Avatar
if it is the resistor then your blower should still blow on high...
used to be a jeep guy... sorry I crossed over to the Land Rover world. Best 4x4xfar... ;p
russkrs is offline
post #3 of 7 Old 05-11-2006, 02:06 PM
mhall02
I've wondered if this is going out on my Jeep as well. Sometimes when I'm driving the blower will cut out for a few seconds or if I flip the AC on high it cuts out until I drop it to the slowest setting or turn it off then back on. It doesn't do it that often, but thought it may be the culprit and may need replacing if it happens more often. I had a '91 Dakota that when I purchased it, the blower didn't work at all. Did some research and found out the resister board are common to go out on the Dakota, but I didn't know if the Cherokees have this as a problem as well.
Patriot Blue
2000 Sport 4X4 4.0 inline six, AW-4 Automatic, stock
Original Owner 308,000 miles
mhall02 is offline
post #4 of 7 Old 05-12-2006, 05:40 AM Thread Starter
imtommorello
yeah exactly. my blower only blows on the HIGH setting. i've come to understand that this means the blower's resistor has blown out. does anyone know of some place that sells them for cheaper than the stealership?
6 Cylinder Inline
post #5 of 7 Old 05-12-2006, 06:13 AM
russkrs
russkrs's Avatar
Ok... just making sure because you said "I want to use my AC again"... leading me to believe you can't use it... as in you have nothing from the blower.
Here is a tech link.... found in the stickies for you...
http://www.geocities.com/chmwatson/F...elink_fix.html
I am not 100% on if it will work for all years... but if not, $42 isn't that bad. Or be like me who has his blower hardwired to a switch, so I only have high and low as well.
russkrs is offline
post #6 of 7 Old 05-12-2006, 07:49 AM
JayIV
JayIV's Avatar
Well, if your blower motor resistor went out, there is a 90 percent chance that you will need to replace your blower motor as well because it is drawing to much power.
There are two ways a resistor can go out. The motor draws to much power and shorts one of the three coils on the resistor, often leaving you with only high because it completely bypasses the resistor. The other way is if the thermal fuse goes out. They can go out just because of age, wear etc. If its the resistor, its easy to replace. Check the link posted above for more info on that.
When I replaced mine, I couldn't find another place that sold the resistors, only the dealership. Also, rather than blowing another 40 dollar part, u should think about replacing the blower motor at the same time.
JC
2004 Overland
JayIV is offline
post #7 of 7 Old 05-25-2006, 10:16 AM
mhall02
Update!!
Well, I flipped on the AC yesterday, the blower went for about 2 seconds then no more. Couldn't get it running the rest of the way home so tore into it and removed the risister. It was rusty looking so went to the dealership, was $30 dollars and some change after tax. Initially when I plugged it in nothing happened so I took it back (I told them I wanted to just try it and they were ok with that). I put the old one back in and after driving around some more, it suddenly stared blowing on 4 (hi) but no other speeds, a total sign the resister has bit the dust!! Even pulled the old one off and still had hi. The guy at the dealer said (as bigsurf75 said) it bypasses the resister when it konks out, so I put the new one in, put the 2 screws in, snugged it down and it works great. I'll put the rest together this evening but hopefully this will be a complete fix and no future wiring issues or blower problems (at least for another 6 years).
FYI the blower motor at the dealership is $210 and the parts guy said they have sold 3 to date?
Patriot Blue
mhall02 is offline
blower motor resistor conrasm XJ Cherokee Technical Forum 21 06-07-2015 08:24 AM
Blower Motor Resistor RP_Offroad XJ Cherokee Technical Forum 1 11-07-2009 07:48 PM
Blower Motor Resistor drsouce411 XJ Cherokee Technical Forum 2 05-12-2008 09:56 PM
Blower motor resistor captain_ruggy XJ Cherokee Technical Forum 2 09-27-2005 02:44 PM
Blower Motor/BM Resistor juljeep XJ Cherokee Technical Forum 2 07-14-2005 09:12 AM
