Xj block - JeepForum.com
post #1 of 5 Old 02-15-2016, 06:29 PM Thread Starter
mdwysong14
Xj block
I have an 01 Cherokee 4.0. And I threw a rod through the block. Do I have to use an 01 and up block, or can I use any 4.0 block?
mdwysong14 is offline
post #2 of 5 Old 02-15-2016, 06:46 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Any XJ Cherokee, ZJ Grand Cherokee 4.0L engine block will interchange.
Remove and re-use ( or replace with new ) as needed or required from the original engine: Intake/Exhaust manifolds, flex plate/flywheel, cylinder head, water pump, distributor-less ignition or distributor assembly, OBD engine sensors, fan belt driven accessories, and/or mounting brackets.
CJ7-Tim is offline
post #3 of 5 Old 02-16-2016, 04:57 AM
75SV1
I would probably use a 96-99 block. They will have the dowel pins for the head. Not necessary, but nice to have. I think the difference in the 00-01 block is 'improved' main bearings.
75SV1 is offline
post #4 of 5 Old 02-16-2016, 08:37 AM
bluejunior
bluejunior's Avatar
Plus if you can get the head with it, you could dodge the 0331 with that year range.
Lifted, Locked, Stiffened
bluejunior is online now
post #5 of 5 Old 02-16-2016, 12:35 PM
Duo_Sonic
I think piston slap issues started in 96. You might want to consider that too.
Duo_Sonic is offline
