XJ Abs Light - JeepForum.com
post #1 of 3 Old 11-26-2007, 06:27 PM Thread Starter
drsouce411
2006 KJ Liberty
XJ Abs Light
My ABS light has been on for a few months. The ABS seems to be failing as well. With an inspection due in February, and the snow starting to fall, this is something I think needs attention. Any suggestions on where to start?
-Matt
drsouce411 is offline
post #2 of 3 Old 11-26-2007, 06:39 PM
XJChris98
Not sure how the ABS works on the XJ's, but I know on cars usually a bad wheel bearing will cause the light to come on.
If I had to take a guess, I would say its a bad sensor somewhere in the system. Trying pulling the codes and see what/if you get anything for ABS
XJChris98 is offline
post #3 of 3 Old 11-27-2007, 08:23 AM
trailblaze
trailblaze's Avatar
pull the fuses and relays... cheapest way!
Matt
trailblaze is offline
Drivers side brake light/running light/ blinker all not working. 2doorxj XJ Cherokee Technical Forum 6 11-02-2009 08:25 AM
Emergency Brake light, ABS light and Airbag light stay on after starting 2001 4.0. s4ryanl1 XJ Cherokee Technical Forum 5 02-14-2009 06:42 PM
Tail Light / Turn Signal / Brake Light Problem swdmus XJ Cherokee Technical Forum 1 12-03-2008 04:09 PM
check engine light/battery dummy light coming on iwishihad1 XJ Cherokee Technical Forum 4 08-23-2007 12:22 PM
Airbag Light, Check Engine light, Gauges go dead.... OhioSpyderman XJ Cherokee Technical Forum 11 09-14-2005 09:50 AM
