xj 4x4 lever, stretched linkage maybe? - JeepForum.com
post #1 of 13 Old 04-18-2010, 07:09 AM Thread Starter
gonejeepin04220
1995 XJ Cherokee
the 4x4 lever in my xj is kind of out of wack. when its in 2wd, the lever is positioned right above 4hi and when in 4hi its right above 4lo. and i can almost get into 4lo but it pops out as soon as i put it n drive.it seems like the lever needs to be pulled back just a little more for it to stay.( but the plastic of the console is in the way)has anyone had this issue, or any ideas what i could do with it? thanks guys
95 xj,5 speed,
5" lift, 33 12.5 dessert dogs
chrysler 8.25,
"my xj is so horny, sometimes im scared itll came right up in a wheelie"
gonejeepin04220 is offline
post #2 of 13 Old 04-18-2010, 07:47 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You need to look under the jeep and see what is wrong with the linkage. My guess is that the bushing that connects the pivot rod to the t-case is bad and the linkage is seperated.
xjfever is offline
post #3 of 13 Old 04-18-2010, 11:53 AM
100dollarbill
1993 XJ Cherokee
You may just have to adjust the linkage. With the t-case in 2wd loosen the nut on the adjusting rod so you can freely move the shift lever forward to the 2wd mark then tighten up the nut. Then test it to verify you can get to N, 4hi and 4lo.
Originally Posted by Muddeprived View Post
I also have this strange jerk at the steering wheel
Originally Posted by JLC08JK View Post
P.S. please stop bringing up the CAI, Those Government Guys make me nervous!!!
'93 XJ 4 1/2" lift on 33's
'08 JK Unlimited Detonator Yellow DD
'11 Liberty Sport (the wife's)
100dollarbill is offline
post #4 of 13 Old 04-18-2010, 02:00 PM
LBLjunkie
1997 XJ Cherokee
X2
Place it in 2 wheel drive (actual). Look under the jeep. On the driver side of the transfer case is a series of levers connected to the part time handle. One of those levers has a nut you can loosen, loosen it (should be next to the running board). Push the part time handle forward it should now go all the way to the 2 wheel drive position. Tighten the nut.
97 Cherokee SE with:Locker, sway bar disconnects, 98 I6
LBLjunkie is offline
post #5 of 13 Old 04-18-2010, 02:25 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You can see the trunnion bolt on the shift rod at the end of my finger, this needs to be loosened to where the shift rod will slide freely though the trunnion. Then you can adjust the shifter to where it needs to be. I usually push the t-case into 4lo manually with the shift tab and then place the shifter into the 4lo position and tighten the trunnion bolt. This is the shift tab back next to the front driveshaft output, it needs to be all the way down and toward the rear to be in 4lo. In the first picture you can see the connecting bracket that goes from the t-case to the body that the linkage rotates on, make sure it is connected securely to both sides.
xjfever is offline
post #6 of 13 Old 04-19-2010, 02:55 PM Thread Starter
gonejeepin04220
1995 XJ Cherokee
wow thanks alot guys. XJFEVER, thank you very much for your pictures and very descriptive instructions.. i am going to get on this in the morning...thanks again everyone for all your help.
95 xj,5 speed,
chrysler 8.25,
post #7 of 13 Old 04-19-2010, 04:15 PM Thread Starter
gonejeepin04220
1995 XJ Cherokee
allright,so i did just that, i even took the nut off but it wouldnt budge..even beat it witha hammer
95 xj,5 speed,
chrysler 8.25,
post #8 of 13 Old 04-19-2010, 05:47 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You may have to hit it with some PB blaster for a few days and then if you have access to a propane torch you can use some heat to loosen the rust free from the trunnion and shift rod. If you do use heat watch out for the fuel lines, they run along the inside of the framerail there.
xjfever is offline
post #9 of 13 Old 04-20-2010, 05:28 AM Thread Starter
gonejeepin04220
1995 XJ Cherokee
alright. ill try the pb blaster first. hey xjfever,howcan i tell if i have a blown u joint? i have a lot of clunkin when i put it in 4wd, everyones says its a u joint anyways. thanks
95 xj,5 speed,
chrysler 8.25,
post #10 of 13 Old 04-20-2010, 05:33 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Grab a hold of the driveshaft and shake it up and down and side to side, ther should be no movement. The driveshaft will turn back and forth a bit due to gear wear, but the u-joints shouldn't move up or down or side to side.
xjfever is offline
post #11 of 13 Old 04-20-2010, 06:07 PM
Brg0012
1983 CJ7
i had a similar issue on my 95 xj, dont know if it will help you, but my jeep wouldnt go into 4 lo and it was bc the po put the cross member on backwards
Brg0012 is offline
post #12 of 13 Old 04-21-2010, 04:19 PM Thread Starter
gonejeepin04220
1995 XJ Cherokee
ya i got some play in the u joint hooking to the front axle. but man i can turn it back and fourth about an inch both ways.
95 xj,5 speed,
chrysler 8.25,
post #13 of 13 Old 01-26-2013, 02:31 PM
xman2yman
this will help me a lot thanks
xman2yman is offline
4x4 linkage/lever question tj40 XJ Cherokee Technical Forum 0 01-25-2010 09:28 PM
Has anyone stretched a Cherokee? tagaiz XJ/MJ Cherokee Non-Technical Forum 5 06-21-2009 10:53 AM
Stretched Jeep Paybac XJ Cherokee Technical Forum 16 04-08-2008 06:11 PM
4WD shift lever linkage question Meatroach XJ Cherokee Technical Forum 2 07-16-2006 01:12 AM
Stretched chain = noise? thuper XJ Cherokee Technical Forum 7 04-21-2003 11:13 AM
