XJ 2.5 TD VM Wiring Diagram - JeepForum.com
post #1 of 8 Old 02-25-2012, 09:22 AM Thread Starter
Puric
Could somebody help me with a 2.5 TD VM engine wiring diagram?
Thank you !!!
Patric
Puric is offline
post #2 of 8 Old 02-25-2012, 09:49 AM
RLE
RLE's Avatar
This is the complete service manual for the 1999 XJ. There are wiring diagrams for the gasoline and diesel versions. It is 43Mb long.
http://www.greatlakesxj.com/tech/99fsm.zip
RLE is offline
post #3 of 8 Old 02-25-2012, 09:52 AM Thread Starter
Puric
Thank you so much RLE!
I hope i find what i need in that archive.
Cheers
Puric is offline
post #4 of 8 Old 02-27-2012, 05:25 AM Thread Starter
Puric
Unfortunately i didn't find what i needed.
I need a scheme with the computer connection pins.
Thank you again!
Patric
Puric is offline
post #5 of 8 Old 02-27-2012, 11:40 AM
RLE
RLE's Avatar
There were no wiring diagrams in any searches I made. The Chrysler part number for your engine control module is 56041 996 AB. It is apparently made by Bosch and is a EDC MSA 15.5. I also found this as a corresponding part number: 0281001719.
One site I found with these numbers is in your country. Maybe someone there can give you some information:
http://www.denko.ro/index.php?class=...dex&pid=ecu_VW
Sorry I can't help with a diagram.
RLE is offline
post #6 of 8 Old 02-27-2012, 11:46 AM
RLE
RLE's Avatar
In the US the 2.5TD VM was never sold, so your questions concerning it won't get many answers.
You might try asking your question in the Australian forum below. There are a lot of VM diesel drivers there and some of them are very knowledgeable.
http://www.ausjeepoffroad.com/forum/...play.php?f=123
RLE is offline
post #7 of 8 Old 02-27-2012, 01:44 PM Thread Starter
Puric
The fact is, this engine needs to be mounted on a CJ7 and there are some problems adapting the computer.
I saw a forum member who did this engine swap and I hope to get his answer.
However, I will try my luck on the australian forum too.
Thank you again RLE !!
Puric is offline
post #8 of 8 Old 02-27-2012, 04:18 PM
Carves
Thank you again!
Patric
There should be pinout diagrams towards the end of the wiring chapter.
Wire colours and connections for both plugs and sockets are shown.
Down here most engine conversions are done to get rid of the VM2.5TD ... but theres quite a few who like and know a bit about them.
Carves is offline
Mix matched wiring harness/engine/tranny.........could use a wiring diagram dadstoy XJ Cherokee Technical Forum 1 08-15-2009 12:58 PM
Scored a Trailer Wiring Harness at Junk Yard for $0, need wiring diagram photonut13 XJ Cherokee Technical Forum 1 04-12-2008 02:39 PM
Wiring diagram TARHEELHAL1942 XJ Cherokee Technical Forum 0 08-16-2006 11:06 PM
wiring diagram i6jeep_1989 XJ Cherokee Technical Forum 3 08-14-2006 08:14 PM
Anyone have a wiring diagram for a '87 XJ? JJorda XJ Cherokee Technical Forum 1 10-28-2004 05:48 PM
