XJ 1" lift - JeepForum.com
post #1 of 6 Old 03-28-2002, 07:19 PM Thread Starter
Gacherokee
Gacherokee's Avatar
1997 XJ Cherokee
Post XJ 1" lift
Could someone give me some pointers on installing a coil spacer and shackle lift kit? I need instructions for the rear mostly and any good tips on removing the front springs and reinstalling them. Thanks in advance.
1997 Black XJ Sport 4x4, 1" Shackle/coil spacer lift, Ram Brush guard w/ 6in spot lights, Smittybilt Nerf bars, Class III Hidden Hitch, Elliptical Driving Lamps, Prime Wheels#234 15x8.5, 30x9.50r15, BFG AT's, JVC CD player, Alpine V12 Amp, 1-12in RockfordFosgate Subs, 5-1/4 Rockford Fosgate component speakers in doors & sound bar, Euro-spoiler, Pacesetter Cat-Back, Optima Red Top battery, HID Headlamp Conversion, Gabriel Hijacker Air Shocks on rear axle
Gacherokee is offline
post #2 of 6 Old 03-28-2002, 11:42 PM
jeeptrailrunner
Post
hey man..take the anti-sway bar off and then the axle should just drop down...but dowse any bolt that you will be taking off in lube. YOu can twist the spring out and will not need spring compressors. A friend will help. the rear is easy too...Take the shakles off and the use then install the front spring first and the use the lower shakle and a wrench to push the top of the shakle back towards the holes. while your at it...get a 2 or 2 inch lift. Have fun...check on the net for some installs...a 3 or 4 inch shakle and spring install nay be the same as a one...good luck...cheers
2000 TJ Sport,5spd, BFG AT 31x10.5, XM sattelite radio....more to come....when the time comes:)
jeeptrailrunner is offline
post #3 of 6 Old 03-29-2002, 01:46 PM Thread Starter
Gacherokee
Gacherokee's Avatar
1997 XJ Cherokee
Post
Thanks Jeeptrailrunner, the advice helped. I got the lift done and it looks good. Later I want to do a 3in lift but for now while the wife has it this is good enough. At least I now what to expect the next time. I post pics as soon as I get a chance to upload them.
post #4 of 6 Old 03-29-2002, 09:57 PM Thread Starter
Gacherokee
Gacherokee's Avatar
1997 XJ Cherokee
Smile
<a href="http://photos.yahoo.com/dave26_30127" target="_blank">Cherokee 4x4</a>
Here are the new photos of my lifted XJ. Notice the clearance of the fenders & tires after the installation. It took about 3hrs to complete. Not too bad for my first time. I didn't even have any bolts break either!!
post #5 of 6 Old 03-30-2002, 04:04 PM
outdoorsman02
Post
GACherokee, Your jeep looks good. I was wondering about the tire wheel well clearence. Do your tires hit when you offroad? The tires look like they stick out more(different offset). I'm just having problem with tire rim combonations hitting my fender flares.
It's an xj thing,Daimler wouldn't understand.
outdoorsman02 is offline
post #6 of 6 Old 03-30-2002, 05:21 PM Thread Starter
Gacherokee
Gacherokee's Avatar
1997 XJ Cherokee
Post
I took it offroad today for the first time ever! I didn't notice any rubbing while were there. It handled very well I thought. It rubbed slightly when hitting pot holes or speed bumps before I put on the lift. I do want to go higher but I am gonna have to wait. My wife drives it frequently so I do not want to go too high with her behind the wheel. <img border="0" title="" alt="[Wink]" src="wink.gif" />
31x10.5r15 on 7" rims with 3.75" backspacing and 2.25" lift in front: will it rub? GeologistFelix XJ Cherokee Technical Forum 6 01-02-2010 09:30 PM
Would a 3" lift in the front and a 2" lift in the rear look any good? Corndork2 XJ Cherokee Technical Forum 2 02-20-2009 03:02 PM
3" "Rough Country" Lift Kit questions cheezboy6 XJ Cherokee Technical Forum 7 11-28-2008 10:28 PM
Ride and flex of 5" lift wit 3" lift LCAs? broncofire75 XJ Cherokee Technical Forum 0 11-19-2007 11:05 AM
what's the "best"/most complete 3" full pack lift out there? BigOrangeXJ XJ Cherokee Technical Forum 24 04-19-2007 05:09 PM
