Don't know what year/engine you have to know for sure. Fill out your profile when you can.
I had an older 4.0 cherokee that I would run 20w50 in during the summers. The heavier oil cushioned a wrist pin knock, and reduced oil consumption due to bad rings. It would use very little oil between changes, but when I changed to thinner oil in winter I had to watch it close.
I think you will be fine if it is an older, higher mileage engine where the tolerances aren't to tight.
yeah its a 05 4.0 with 193,xxx runs really good, just got the wrong oil , like i hjavent even started it yet, i just wanna kbow if i should go and change it out b4 driving it? or if it'd be fine to drive around, i do alotlotlot of driving too.
For the past couple of years here in PHX, I have used 20w50 in the summer. It helps with higher idling oil pressure. Given that temperatures near the pavement can approach 140 degrees F on a typical summer day here, it's certainly not too thick for those conditions.
Now in the wintertime, it IS too thick, even for S. Arizona, and then I switch back to 10w30.
As long as you switch it out before cold weather sets in up in NJ, you will be fine.
I would say that on a cold start you could really starve the engine for oil. Chrysler does not sugest 10w30 for nothing. Oppinions very, but its your problem if it causes harm. Engines are expensive and oil is cheap. When in doubt, use the correct stuff. Just my two cents.
That answer is technically correct, BUT.....it depends on other factors, too, which are often out of the control of the manufacturer once it leaves his factory.
Bearing clearances due to age affect how much oil starvation on startup will exist. So do wear factors in the oil pump. So does ambient temperature at startup.
Finally remember than thinner oil provides less viscous drag on rotating parts, and that helps with fuel economy, so the OEM's try to use the THINNEST oil that will provide adequate lubrication.
In addition, the thicker oil will be less likely to run off the engine parts than a thinner oil. The result is more residue at startup, so even IF it takes longer to get oil pressure, the engine is protected.
i use to use 20w50 with my old mopar oil burners in north carolina with winters to 17'F.
go back to whatever weight you want when the next oil change.
me? 5w30 in all cars year round in socal with winters in mountain snow, and the mohave desert 115'F vegas runs.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
