*Writeup*-Installing C-Rok Inner Steering Support Brace - JeepForum.com
post #1 of 6 Old 01-19-2009, 06:13 PM Thread Starter
bmyohn
Youngin'
bmyohn's Avatar
Total Time For Install - 1 hour 30 minutes approx.
Installed on - 2001 Jeep Cherokee Sport
Tools Used - 16mm socket and ratchet, 22mm socket
Materials Needed - C-Rok support brace, 3 steering box bolts, 1 - 9/16" Grade 8 nylock nut and bolt, 3 - 5/8" dia. spacers
Notes: I did not take the tire off to do this project. With my tirmmed fenders and lift, it was no problem to get to the bolts.
Here is what the kit came with, (minus the bolts, so just the spacer and the metal cylindrical spacers, not pictured)
1) Here is what I started with:
Remove the three steering box bolts. CAREFULLY, otherwise they will snap and it will make this project much longer. Ask me how i know!
2) Once bolts are taken off, pop off the spacer that sits between the unibody and steering box
Here is the differnce, the C-Rok is just pure beef compared to stock
3)
Once all three bolts are in order to get the spacers in, you must drill out the three holes. I used about a 1/2" bit to ream out the bumper bracket and steering box bolts just enough to tap the spacers in with a mallet or hammer.
4) Slide the steering box bolts back through the sleeves and mount the spacer on the inside of the "frame". Put the 9/16" bolt through as well.
5) Tighten the steering box bolts first, going around a couple times to insure they are tight. APPLY lock-tight to all the steering box bolts
6) Finally tighten the 9/16" bolt completely.
7) You are done! GO back and tighten the bolts daily for the first week to make sure they are completly tight.
Overall the process isnt too bad at all. The steering feels much more complete and solid. Especially with AJs bumper mounts on the outside.
2014 Jeep Wrangler Sport S
3.6L V6 - Manual
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford HP D60 l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l39.5" IROKsl 17x9" Pro Comp 98sl High Clearance Shock Mounts [COLOR="red"] l Hidden Hitch l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l Sterling 10.25 *FULL WIDTHS* l JKS Mini Skids and Sway Bar Brackets l 7/8" Heim Joint High Steer
bmyohn is offline
post #2 of 6 Old 01-19-2009, 06:18 PM
srmitchell
Nice write up, but does the brace mount on the inside?
Not bad!
I work on Mopars
srmitchell is offline
post #3 of 6 Old 01-19-2009, 06:21 PM Thread Starter
bmyohn
Youngin'
bmyohn's Avatar
it mounts on the inner part of the frame rail. in between the steering box and the unibody, in place of that silver spacer pictured above
3.6L V6 - Manual
bmyohn is offline
post #4 of 6 Old 12-24-2009, 04:08 PM
praetorian
Nice writeup! Does anyone know what the three steering box bolts are supposed to be torqued to per factory specs?
I'd rather be judge by twelve than carried by six.
praetorian is offline
post #5 of 6 Old 08-14-2013, 09:31 AM
Charley3
Are the steering box bolts supposed to be torqued to factory specs?
Warning: I often edit my posts a few times to get them complete or correct errors.
Charley3 is offline
post #6 of 6 Old 10-13-2015, 03:20 PM
catman3521
So I bought the bolt kit with the spacers I have to drill the 3 holes out is what ur saying
catman3521 is offline
**Writeup** Installing Cruise Control In Your 97+ XJ bmyohn XJ Cherokee Technical Forum 159 02-18-2017 09:42 PM
Writeup: Installing Airflow Snorkel on 97+ XJ bmyohn XJ Cherokee Technical Forum 17 05-24-2011 01:36 PM
M.O.R.E. Steering Brace + RE Track Bar Brace? TheNerd XJ Cherokee Technical Forum 3 05-09-2006 10:57 PM
Steering Box Brace? Red Raider XJ Cherokee Technical Forum 11 02-01-2006 08:27 PM
steering box brace and RE HD track bar brace? conrasm XJ Cherokee Technical Forum 9 01-27-2006 11:32 PM
