Quantcast Writeup: Installing Airflow Snorkel on 97+ XJ - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Writeup: Installing Airflow Snorkel on 97+ XJ
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 09-15-2009, 12:39 PM   #1
bmyohn
Youngin'
bmyohn's Avatar
Installed on: 2001 XJ Sport
Approx. Time Installed: 2 hours
Tools Used:
  • 3" Hole Saw
  • Drill
  • 3/8" drill bit or 5/16" bit
  • Angle Grinder (not completely necessary)
  • Flat Head Screwdriver
  • 10mm open end wrench
  • some type of adhesive
  • tin
Here is what the fender looks like normally:
Take the included guide and cut along the dotted line and cut out the small hole. This allows you to tape the guide on to the fender and account for the contour of the a-pillar.
Tape the guide on to the fender making sure it is lined up to the edges of the fender as closely as possible. Use a center punch on all four of the holes to better guide the drill bit and hole saw/
Drill out the 8mm holes (equivalent to about a 5/16th" bit (i used 3/8" cuz i couldnt find a 5/16th in the garage))
The instructions say to remove the guide when drilling but i left it on so i didnt have to retape it all again.
Remove the washer fluid bottle from the fender, otherwise you will drill through it like i did. If you do drill through it just caulk up the hole and call it good.
Then drill out the large hole in the fender. (not as scary as it sounds).
Halfway through the cut you may need to use an angle grinder to cut out a section of the fender to remove a piece of the inner fender that the hole saw cant reach. no big deal takes three seconds.
Remove the inner wire loom from the fender before finishing the cut.
Some grinding on the outer hole may need to be done to ensure a tight fit of the snorkel. DO NOT forget to paint the exposed metal otherwise it may rust.
Remove the air box. Cut two pieces of tin to cover the hole in the front of the air box. Use a strong adhesive to bond these pieces of tin to the airbox.
On the rear of the box, using the 3" hole saw cut a hole to place the adapter into. Also use the adhesive here to attach the adapter firmly into place.
Attach the a-pillar bracket to the snorkel to get a rough estimate on where it needs to be bent.
Do this before bolting the snorkel into place. Once bracket is bent, screw the self tapping screws into a-pillar.
Then screw the threaded rods included into the snorkel and slide the rods through the fender. Add washers and the 10mm nuts to the inner side of the fender well. Fasten securely. The rearmost bolt is a pain to get to but can be done.
You will need to take out the angle grinder again and trim off the excess rod on the bolt closest to the front of the jeep. otherwise washer bottle will not fit
Once securely fastened reinstall the washer bottle and airbox. used the supplied hose clamps to fasten the hose from the snorkel to the airbox. the hose will need to be trimmed so i pulled out the angle grinder again and cut the hose down to size.
Attach the snorkel head using a hose clamp.
Final Product
Thanks for reading, feel free to ask any questions.
-Brendan
2001 Dodge Ram 2500 SLT 4x4
5.9L Cummins Turbo Diesel
"The Tow Rig"
1988 Jeep Comanche
2.5L 4cyl - 4 speed manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford 8.8" w/ disc brakes l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l 35" Maxxis Bighorns l 15 x 8 Cragar Black Soft 8s (4" BS) l High Clearance Shock Mounts l 4 - BAJA off road lights l TnT Customs D30 Truss l Hidden Hitch l ARB Front Diff Cover l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l HP D30 l JKS Mini Skids and Sway Bar Brackets l TnT Customs OTK Steering
bmyohn is offline   Reply With Quote
Old 09-15-2009, 01:16 PM   #2
5spdChopper
Did you prime/paint the edges of your fender cuts to prevent rust?
1999 Jeep Cherokee Sport 4.0L 4x4 AT 4dr
5spdChopper is offline   Reply With Quote
Old 09-15-2009, 01:18 PM   #3
Kettles
Kettles's Avatar
Seems like a nice kit like that would come with something to cover the front of the airbox... W/e. Looks nice.
So is your washer bottle still in there? I guess this won't work for us ABS guys huh?
Oh, did you fill in the hole in the airbox (the little one in the middle i see in one of the pics)? I have like 20 holes all over my airbox (factory drain holes all over i guess).. and it would be a PITA to caulk them all to install a snorkle, lol.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output Pictures Build Thread
"Live Free Or Die; Death Is Not The Worst of Evils."
-General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline   Reply With Quote
Old 09-15-2009, 01:27 PM   #4
bmyohn
Youngin'
bmyohn's Avatar
My washer bottle is still there installed in the same exact location. As for the drain holes, i was reading on go-jeeps writeup that its not a big deal to caulk them all, because if you think about when you dive in the rain the water goes down the snorkel and has to drain out of the air box in some way. Plus he was saying that if your
jeep is sitting in water it will take a while for water to fill the airbox through the drain holes. He floated his box in a bucket of water and it didnt fill up even with the drain holes in place
"The Tow Rig"
1988 Jeep Comanche
Old 09-15-2009, 01:33 PM   #5
basso4735
1997 XJ Cherokee
that looks great.
your pictures are pink though haha.
Build Thread- Includes bastard pack and cheap 3" lift info
Red 97 XJ Sport 5 Speed - Lifted 3" - Sound system - C4X4 Tow Hooks - Hella 500s
Black 96 XJ Classic - Stocker on 31s - SOLD
basso4735 is offline   Reply With Quote
Old 09-15-2009, 01:36 PM   #6
Kettles
Kettles's Avatar
Yeah.. Its so odd to have so many holes in it though.. I mean I easily have 20, lol. While it may not really fill just sitting in there, with the engine on i would think the negative pressure would draw more water through it. Glad to know the washer bottle can stay, I had the impression that it needed to be reloacted, but maybe that is with a different snorkel.. How much did this one run you?
Oh, what is the frontmost 8mm hole for, if the snorkle feeds through the fender farther back? does the outer cover just go that far forward?
I ask so many questions because I like it, and have always been considering one... Weighing pros/cons with the cowl snorkels..
_=====o000o
-General John Stark
Old 09-15-2009, 01:39 PM   #7
justanotherjpr
Great write up and nice work! Looks great!
justanotherjpr is offline   Reply With Quote
Old 09-15-2009, 01:50 PM   #8
bmyohn
Youngin'
bmyohn's Avatar
Originally Posted by basso4735 View Post
that looks great.
haha, its an old digital camera, and when i take pics in the daylight it does that for some reason lol
This snorkel ran me about 370, but the way i see it i just bought a new stroker, and every time i go wheeling i find a way to swamp the jeep so this is pretty good insurance lol.
As for the frontmost hole, its just a mounting hole, im not sure if there is any particular reason for it to go that far forward other then the fact that it looks better then if it just stopped where it entered the fender.
The ARB snorkel requires the washer bottle to be removed.
"The Tow Rig"
1988 Jeep Comanche
Old 09-15-2009, 02:45 PM   #9
housew
i wanted that snorkel, but abs has ruined my life again. can't have the arb due to flairs either
99 XJ, bds lift, 34" tsl, d30/8.8 with 4.10s & aussies
48 cj2a 31" tsl
82 cj5 4" 31", project in progress
housew is offline   Reply With Quote
Old 09-15-2009, 04:14 PM   #10
99Greenmachine
Now we're talkin...welcome to the snorkel club even tho its not an ARB haha
'99 XJ Sport MY BUILD
Thank You Hooligan!!!
XJ/TJ Heaterbox Seals for sale!!! NIB! Official Mopar made in USA!
99Greenmachine is offline   Reply With Quote
Old 09-15-2009, 04:21 PM   #11
FitchVA
Jeeper 4 Life
FitchVA's Avatar
airflow > arb
nice little writeup
you left out the step where you have to put the upper bracket in
'98 xj sport (trail toy) | specs
'98 xj classic (dd'er) | specs
'89 mj tinker toy | specs
My XJ Page | My Gallery
FitchVA is offline   Reply With Quote
Old 09-15-2009, 04:31 PM   #12
lrsmithwhaley
1991 XJ Cherokee
Originally Posted by FitchVA View Post
airflow > arb
Not when an ARB costs $30. Granted I bought it used from a friend.
Green with Silver trim 1991 Jeep Cherokee Laredo (DD and Off-roader)
March 2007 Stock Class XJ of the Month
Original Rust Jeep Club Member #2
Green Jeep Club Member #183
Air Force Jeep Club #76
lrsmithwhaley is online now   Reply With Quote
Old 09-15-2009, 05:41 PM   #13
99Greenmachine
airflow > arb
Haha nice try....
its definitely legit although I don't think it matches the body lines as well as the Safari Snorkel...whatever's cheaper is what I would go with.
I have also abused mine since that pic was taken...(2 years ago) and can tell you that the ARB is definitely durable as crap. I've hit a few trees and it is fine
Old 09-16-2009, 09:04 AM   #14
bmyohn
Youngin'
bmyohn's Avatar
nice little writeup
i mentioned bending the bracket, but it was getting late and i didnt have the time or paitence to try and take a picture of that step lol.
but thanks fitch. i may steal your picture and throw it in the writeup so people dont get too confused
"The Tow Rig"
1988 Jeep Comanche
Old 09-16-2009, 09:54 AM   #15
FitchVA
Jeeper 4 Life
FitchVA's Avatar
i was just givin' ya a hard time. but feel free to use it if ya want. i've got the bandwidth
Glock Forum
